Question about IBM Office Equipment & Supplies
Everything works except for spacebar & key advance
I recently got this typewriter out of storage (has been stored with dust cover on) after several years of inactivity. Everything works great except for some reason the spacebar will not advance the element (ball) and the element will not advance when the keys are striked. In other words, when you press a key it strikes correctly on the paper but will not move to the next position for typing the next key - instead it strikes the next key over the first. It also stays in the same position when the spacebar is pressed. The two problems are probably related. All other keys work fine and all letter and number keys type as they should. Thanks for any help with this.
  • shyorchid Jun 18, 2009
    Tab key works perfectly. Correction key works perfectly. When pressing the space bar, it makes noise as though it is moving along but it stays in place. The element (ball) moves forward (to the right) when I press the tab button and returns to the left margin when I press the return button - or it can be physically pushed back to the left margin but it will not go forward (to the right) either by typing any of the letter or number keys or by pressing the space bar.
  • Anonymous Mar 25, 2014
    will advance using the space bar but will not type any letters or numbers
  • IBM Master
  • 3,594 Answers
The T/W is probably just gummy. Will it tab? If so the correction mech. is probably the trouble, if not try some WD40 on the silver shaft that the s
carrier slides on.
DickyO
Posted on Jun 18, 2009
The return key does not work. When I press it nothing happens. The rest of the keyboard works.
Return key has a bad solder joint, it's not that hard to repair if your so incline, try to get the cover off and we can go from there, ( be leave it or not getting the cover off is much more difficult than the repair??good luck, Bret
Mar 06, 2015 | IBM Wheelwriter 5 Electronic typewriter P...
Can someone advise why a IBM Wheelwriter 15 by Lexmark typewriter keys "1, Q, A & Z" will not type? Everything else on the keyboard works except for these keys.
Sorry it took a while to respond. The keyboard is failing due to age, very common problem. I get refurbished keyboards from EBM, ph.# 800-832-6522. that should take care of the problem.
Sep 09, 2014 | IBM Wheelwriter 1500 by Lexmark Electronic...
Standard manual corona typewriter: spacebar not working
There is an escapement type mechanism in the back of the typewriter, chances are, the escapement mechanism is out of movement or misaligned. Check the spacebar if something is caught underneath or over one of the linkages.
Jan 16, 2014 | Office Equipment & Supplies
How can I edit an address I already have stored in my IBM Wheewriter 6 without deleting it entirely and retype it in and storing it again?
You do not have to purchase a manual for this one job. There is a free copy at http://images.lexmark.com/publications/pdfs/2007/index/en.html
Just go to the bottom of the page for "Typewriters" and choose your model. I believe the answer you are looking for is on page 3-25. I have looked at it myself. Here are the steps.
Always open the storage before making a revision.
- The store light must be on.
Pressing Store + the number (1 to 99) always opens storage at the beginning of a job.
If you play back too far or want to start over:
1. Press Play to stop playback
2. Press Store + the number (1 through 99)
3. Press Play. (Playback starts again at the beginning of the job.)
Use the Correction key to erase unwanted carrier returns from Stored job:
1. Press Play or Play+Spacebar until the carrier return playb
2. Press the correction key.
After making a revision hold down Play while you press and release the Spacebar several times to make sure the next few characters play back correctly.
When revising indented jobs, be sure to stop playback at the word or character you want to revise. Remember, you cannot use the Correction key to erase characters typed before you press Code+Tab or Code+Crtn. Therefore, if you play back too far, you may need to start playing back again from the beginning of the job.
Let me know if there is anything else needed.
Apr 07, 2011 | IBM Wheelwriter 6 Typewriter
Sticky Keys?
hold the code key and press either the x or l key depending onthe age the term lahg will be on it in green, this will turn off the language mode.
DickyO
Mar 31, 2010 | Lexmark Wheelwriter 6 Series II Typewriter
IBM Wheelwriter 10 Series II Typewriter 6783. Spacebar suddenly does nothing. Everything else functions fine. Removed spacebar key and vacuumed dust underneath. When investigating possible problem we found...
you will need to replace the keyboard. we see this alot,keyboard starts to fall apart due to age. batteries are only used to hold tab and margin positions in memory. machine works fine without batteries.
Dec 15, 2009 | Televison & Video
Need directions to store keystrokes in Xerox 610 Memorywriter
you can store phrases by -
1 - turn on the AUTO RETURN button above the keyboard
2 - hold down the button on either side of the spacebar, type a titile (any character from a - z)(SPECIAL ENTRY light will turn on)
3 - hit the +/= key (if you hear a beep, it means this title is already used. Press STOP and start over with another title.)
4 - type the phrase
5 - hold down the special key on either side of the spacebar and hit any key (a - z) to store the phrase (SPECIAL ENTRY light will turn off.
to re-call a phrase
1 - hold down the key by the s/b and type the title (SPECIAL ENTRY light turns on)
2 - press the SPACEBAR one time
Nov 12, 2008 | Olympia Mastertype 3 Typewriter
241 people viewed this question
Top IBM Office Equipment & Supplies Experts
James Cagle
James Cagle
Don  Farrell
Don Farrell
jasbo
jasbo
Are you an IBM Office Equipment and Supply Expert? Answer questions, earn points and help others
