Question about Radio Communications
Why wont my remote open my gate - Radio Communications
  • 1 more comment
  • BRad_WIlls Apr 22, 2014
    Hi billie munoz, I want to help you with your problem, but I need more information from you. could you let me know the make and model of the remotes and controller if possible the age?
  • Michael Jun 08, 2014
    Check the battery's and assess if there is remote interference. Need more specific information to further answer the question including remote frequencies and type of transmitters you are using.
    Add particularly look at any environmental change in conditions including short wave transmitters or powerful aerials that neighbours may have installed. Primarily check and replace battery tx.
    Spread the Word:
    An expert who has shared 5 answers on their Facebook wall.
  • 23 Answers
Agree with Brad. More info needed. Gate Brand and Model as well as Remote model and make.
Posted on May 14, 2014
Gate will open pushing open button but cant use remote
General answers only, sorry. Look for loose or corroded connections, especially where wire nuts were used. Reprogram the remote receiver. Disconnect power to the receiver for a short time. Reconnect and reprogram. I hopes that any of this helps. I have operators to the much like witch craft, a black science!
May 10, 2016 | Elite Gate Opener Sl3000 Slide Gate...
Sliding gate wont always open
Since there are few details on the circumstances of when it won't open provided I will try to guess what is happening.
Usually this is related to the strength of the transmitter (clicker or remote) signal. If you have radio interference from ham radios, air fields or other government agency, it will affect the reception or your gate receiver. Other common issues include the distance from the operator, how long you hold down the button, and the age of the battery in the transmitter.
You might try extending the receiver antenna up higher. If this makes it worse, you may need a directional antenna like the Linear EXA 2000.
We have also found the Linear SMDRG narrow band receiver to work well when we have interference issues.
May 18, 2015 | L A Ornamental Security Electric Driveway...
I have a 2010 jeep liberty the gate light is on in the dashboard and rear gate wont open with remote or push button on rear door
the gate lock has issues, get it serviced.
if a DIY person? get the FSM and read that page. under body chapter.
Jan 11, 2014 | 2010 Jeep Liberty
Myhouse gate
There is a switch in the housing that tells the controller if the gate is open or closed. The switch is bad or out of adjustment.
Aug 21, 2013 | Home Security
I have a 2014 Audi 5. I have had no problem programming my garage opener but cannot seem to program my security gate key. I follow instruction with negative resutls. I even go to the gate and park in...
I had the same problem with my 2014 RS5. The solution was to keep pressing and releasing the gate remote until it was picked up by the Audi, instead of just pressing and holding the gate remote button. My gate has a Mighty Mule gate opener but the remotes are the same for most makes of gates.
Aug 20, 2013 | Audi A5 Cars & Trucks
Power liftgate will not open with remote, instrument panel control or button in rear cargo on lincoln mkx
It can be faulty switch or its issue with lift gate latch.Its got stuck up hard or cracked inside.It has to be inspected.-----------
There are few help links with proper solutions for these problem.I suggest you to refer the links.
Click the link below:----
2007 Mercury Mountaineer: Liftgate will not Unlock or Open? http://whoisbyme.blogspot.in/2012/06/2007-mercury-mountaineer-liftgate-will.html
Adjust Hydraulic Lifters? http://schematicsdiagram.blogspot.in/2012/04/adjust-hydraulic-lifters.html
How to open rear lift gate? http://repairhelpcenter.blogspot.com/2011/12/how-to-open-rear-lift-gate.html
--------- Power Liftgate Shuts Down http://whoisbyme.blogspot.in/2012/07/power-liftgate-shuts-down.html
------------ Power Lift Gate Will Not Remain Open http://whoisbyme.blogspot.in/2012/07/power-lift-gate-will-not-remain-open.html
----------- Power Lift-gate will not Operate http://whoisbyme.blogspot.in/2012/07/power-lift-gate-will-not-operate.html
------------- Liftgate will Not Stay Up Open? http://whoisbyme.blogspot.in/2012/07/liftgate-will-not-stay-up-open.html
---------------- Rear Door will not open http://whoisbyme.blogspot.in/2012/07/rear-door-will-not-open.html
------------ 2000 Toyota Corolla: Rear Door wont open from outside or inside? http://whatisbyme.blogspot.in/2012/05/2000-toyota-corolla-rear-door-wont-open.html
These details will help.
Thanks.
Nov 25, 2012 | 2007 Lincoln MKX AWD
It seems that I have a short in my wires. My tail lights wont stay on. My problem is the lift gate is stuck and I cannot access the lights. When u use the remote to open the doors it makes a funny sound....
You should be able to remove the trimpanel on the lift-gate. then at the location of the striker in the middle-bottom of lift-gate you should be able to access a rod. Grab the rod with pliers, if pliers won,t fit the rod connects to a metal lever attached to the striker assembly, pry the lever away from the striker and this should release you gate....Good Luck!!!
Oct 15, 2009 | 1999 Jeep Grand Cherokee
Gate wont open, lock and unlocked still wont open
it may be that the gate has dropped on it's hinges, try lifting as you open. (i assume a side opening gate)
Oct 01, 2009 | 2002 Ford Escape
Radio Communications Logo
556 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you a Radio Communication Expert? Answer questions, earn points and help others
