Question about W90-Ru-B Rapide Ultra Upright Carpet And Upholstery Washer
My vax wont deliver water to the carpet when i pull the trigger
    New Friend:
  • 124 Answers
Check the delivery system for kinks in the hoses or clogs in the tank.
Posted on Apr 16, 2014
a 6ya Mechanic can help you resolve that issue over the phone in a minute or two.
click here to Talk to a Mechanic (only for users in the US for now) and get all the help you need.
When i press trigger for water,It wont dispense water when hose is attached but i get a water flow when hose is placed over the side,ive checked for blockage in pipe ? Vax135u rapide
Vax135u rapide... UK: carpet cleaner, 4+ stars
Hello Jet Black,
Check the bottom of the clean water tank to make sure it is fully seated... and the hose connections...
Else you have a loose/broken fitting from your "trigger"
VAX Rapide 135U Carpet Washer Cleaner
Vax Rapide Spring Clean Carpet Cleaner 135U
Aug 06, 2016 | Heating & Cooling
My vax rapide w89 will not spray water from the bottom
Hi s_hall9800,
We bought a Vax Rapide Carpet Cleaner and were disappointed with it's performance as we couldn't see it spraying the cleaning soltion onto the carpet. I found there was no pump and gravity was all that put the solution on via a sparge pipe, controlled by a trigger-operated valve. So, all that happened was an intermittent sort-of dribbling. The cleaner picked -up quite well, though and we sprayed the carpet using a separate hand-held sprayer.
Nov 21, 2014 | W87-Rh-P Rapide Ultimate Clean Upright...
Vax carpet washer problem
if its new...contact the manufacturer or the seller? just a thought.
May 31, 2014 | W87-Rh-P Rapide Ultimate Clean Upright...
Carpet cleaner vax
did it work before? if so then you could have a blockage from the outlet (where the pipe connects to the water tank which model do you have ? and was the filter present when you was working with the trigger only?
Apr 15, 2014 | Vacuums
Vax rapide
I brought a rapide ultra carpet washer today , cleaned half of my front room brilliant then stopped spraying water using the trigger on the handle, as the handle comes off for easy storage I took it off, and what\'s happing is when you pull the trigger to release water a piece of plastic pushes on another piece ov plastic to release water and it was not working only by me pushing my finger on the other piece of plastic in side the handle bit, so mines going back ,
Aug 14, 2013 | Vacuums
How do you use vax 2000 to shampoo carpets. do not have a manual
Set up is complicated unless you are patient.
Remove the paper dust bag from the bottom of the canister and then filter ring. Then put in the recovery bucket of which 4 litres of warm water should be added and a capful of floor cleaning solution.
Then remove the pump wire on top of the Vax motor where the blue filter circle is (keep the filter in, do not remove it!).
If the 2000 has a separate pump notch on the rim of the Vax motor head on the outside then you should plug the black cord in that has a washer screw type metal connector. Push, twist and lock in. Then the black cord which eventually leads to a clear pipe with the older clip on wash handle that has to be clipped to the main hose handle has to have the black and see through cord clipped to the main hose and eventually down the extension pipes until you get to the floor head. If you have the older style T shaped floor head the cord should slip into the floor head easily. Then either squeezing the trigger to release the cleaning solution in, switch the Vax on and hit the secondary pump button. This will pump the cleaning solution and water into the carpet. To stop the pump you can either lock the wash trigger to stop the liquid or squeeze the trigger to make sure no other liquid comes out. Generally you can see the foamy carpet solution flowing through the see through rubber hose and eventuallly through the floor head.
To **** up the rest of the carpet solution, stop the pump button and the Vax can be used to **** out all the dirty solution/water in the carpet. Its a big and tedious task generally!
See an alternative manual for the Vax 1000 which is an older model but similar to the 2000. It is free and in pdf downloadable form:
http://www.vax.co.uk/downloads/pdf/VaxGuideNo8a.pdf
Jun 15, 2009 | VAX Appliances 2000 Canister Vacuum
Vax problem
Could be a bad pump.
Feb 07, 2008 | Vacuums
W90-Ru-B Rapide Ultra Upright Carpet And Upholstery Washer Logo
248 people viewed this question
Top Vax Vehicle Parts & Accessories Experts
Bigaitch
Level 1 Expert
seanwalters1
Level 1 Expert
David Grady
Level 1 Expert
Are you a Vax Vehicle Part and Accessory Expert? Answer questions, earn points and help others
