Question about Fisher and Paykel Fisher Paykel Intuitive Eco Washer IWL15
Error 49 on a Fisher and Pykel washing machine, what can i do to resolve this?? Thankyou.
Error 49 on a Fisher and Pykel washing machine, what can i do to fix problem, thanx.
  • 4 Answers
Your cold valve is faulty. The rubber membrance inside the valve can damaged after certain period of time. The problem may be inside the controller if replcement valve can't fix the problem. There is a resistor on the current path to the valve. It is on the control board. Some timems it can go open. Good luck with the repair
Regards
Sarath
Posted on May 24, 2014
4 Suggested Answers
  • 27 Answers
SOURCE: I have a fisher and
Hi there. FC 49 has a few possiblities
1. the wiring connection to the cold water valve has been disconnected
2.the cold valve has failed, compare resistance with hot valve (they should be the same)
3 the motor controller has failed
I hope this helps
Posted on Oct 25, 2008
  • 713 Answers
SOURCE: Error code 136 Fisher & Pykel washing macine
Hi just read your posting.Now Error code 136 means you have a motor stall fault.This means the motor controller cannot start the motor turning.Has your machine been noisy on spin?The things that cause this fault are,seized or faulty bearings, wiring to the motor faulty,faulty motor,faulty rotor position sensor, or faulty motor controller.Do you have or can borrow an electrical test meter ?If the answer is yes I can guide you throe the testing of the components to track this fault done.Please reply with additional information about the spin cycle and if you can get a meter and I will help you further.
Posted on Jun 19, 2010
  • 713 Answers
SOURCE: error code 49 on fisher and paykel 8kg aqua smart
Hi just read your posting.Error code 49 means the computer has measured a voltage from the valve diagnostic circuit that indicates the cold valve is faulty.Would you like help in confirming that the cold valve is faulty?You need an electrical test meter.Please reply and I can guide you thru the testing procedure.Looking forward to your reply.
Posted on May 16, 2011
Fisher @ Paykel GW 712 washing machine error code 49?
My sister discovered her cold water was turned down,,however a plug or pinch hose could give the same code on fisher/paykel. Check your owners guide for your model.
Jul 27, 2015 | Fisher Washing Machines
What does the fault code 66 on a fisher and pykel
The problem with the washer is that the motor controller has sensed the lack of water in the machine as so to speak, hence the error.
If you disconnect your water hose off the backside of the washer there may be screens behind them. I would start there. Good Luck
Oct 18, 2014 | Washing Machines
Fault 49
The main board is displaying the wrong error
for the problem your machine has.
Fault 49 is water valves error.
The most common problem with AquaSmart is pump faulty
and damaged your motor control board,
Pump and motor control board need replacing.
Jul 31, 2014 | Fisher and Paykel Washing Machines
My fisher & pykel is showing error 40 does any one know how to fix this ,,,Thanks
Error 40 means it is a clutch problem. If you can take the inner bowl out and see inside for a forign object preventing engaging the clutch. If water over flowing check the pressure tube. It probably disonnected or damaged. Pressure transducer inside the control board also can be faulty. If you are mechanically competent this problem can be easily fixed.
Mar 21, 2014 | Fisher and Paykel Fisher Paykel Intuitive...
Fisher and pykel EcoSmart won't start
You can find a service manual at the link below to assist in repairing your machine.
Download the smart drive mw511 manual
Link:
Mar 10, 2012 | Fisher and Paykel GWL11 Top Load Washer
Error Code 49 Fisher and Paykel Washing Machine
the code error (49) is telling you that the inlet valve is not working make sure the hoses are not blocked. if you have fitted the valve and is still not working then i would try using the unit on cold if it still does not work then there must be a short in the p.c.b control board.
hope this helps a little more
Jul 12, 2010 | Fisher and Paykel Fisher Paykel Intuitive...
Jun 19, 2010 | Fisher and Paykel (IWL12)
Error Code 49 on Fisher & Paykel Intuitive Eco
Fault 49 usually points to the cold inlet valve, either open circuit or not connected correctly. I often come across machines that the motor controller is the problem too.
Jan 06, 2009 | Fisher and Paykel Fisher Paykel Intuitive...
Washing Machines Logo
241 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Dan Webster
Dan Webster
Owen Barnes
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
