Question about LG Televison & Video
Lg rz 32lz55 firmware update - LG Televison & Video
SOURCE: Where do I find the firmware update for LG kc550
find B2CAppSetup.exe,its program from LG to update firmware of your phone
Posted on May 01, 2009
SOURCE: LG Arena won't turn on after firmware update
I downloaded the LG Mobile Support Tool at http://www.51spsoft.com/Download.asp?ID=34522, which easily downloaded and installed the right firmware for me.
Posted on Aug 08, 2009
SOURCE: are all rz-32lz55 hd ready
hi I have the same TV and have been tring for the last year to find someone that know's how to set up the HD. I can get the Picture but no sound for the HD have been told many way to get the sound but does not work. if you find out let us know.
Posted on Nov 13, 2009
caroldon
  • 17129 Answers
SOURCE: Rz-32lz55 when tv gets warm it crackles then will
This is a common fault solution which can be checked and corrected by you assuming that there is no component failure. There is a high possibility that the components over a period of heating and cooling, tend to bring on a problem of dry soldering. So my advice is to check the set for some loose joints that have played on to give you these erratic shut downs or poor performance.
The best way to check for loose connections is to tap lightly when the set is powered on , If there is change while tapping then it seems that there are DRY solder joints. Remove main plug, the covers - with caution of high voltage, check for dry joints, use a good soldering iron to solder all suspected points.
Sometimes the fault occurs when the set warms up, if so you can simulate the heat using a hair dryer on the suspected areas, try with the power supply, distribution, Processor controller, driver controllers on the A/V related sections. Also the use a FREEZE-IT spray can simulate the components to cool and show up the fault.
Based on the above method you must be able to locate the area of fault and solder the sections. Sometimes large IC's- ones with more pins- tend to have drying in some pins and so cause faults related to the IC's protocol.
In this case please check on the AUDIO SECTION/ POWER AMP and the associated sections for the fault.
Posted on Aug 20, 2011
How to connect dvd player to LG RZ-32LZ55 in LCD TV
This 'TV' is really more of a video monitor. It has one DVI input, 2 SCARTS (1 RGB); component video input; composite video input; S-video, and stereo audio and RF inputs. Best picture would be using the component inputs if your DVD player has the outputs. If not you'll have to consider the S-video or composite (yellow) plugs. (Neither is HD capable....)
Jan 20, 2015 | LG Televison & Video
Need a user manual for lg32lz55 32inch LG tv
Do you mean the LG RZ-32LZ55 TV? If this is your TV, go to http://www.lg.com/ae/support-product/lg-RZ-32LZ55 . The manual is available in English and French as a DjVu file. There is a link to the DjVu reader software above the link to the manuals. I've found that this format is best accessed with Internet Explorer.
I hope this helps.
Dec 14, 2014 | LG Televison & Video
How to change aspect ratio on lg rz-32lz55?
Any chance you are using a box with this set for signal?
Dec 17, 2012 | LG RZ32LZ55 32 in. HD-Ready LCD Television
Are all rz-32lz55 hd ready
Sep 30, 2009 | LG RZ32LZ55 32 in. HD-Ready LCD Television
RZ-32LZ55
You didn't mention what your signal source is but if it is one of the two satellite services, the problem is probably with your receiver, not your set.
Just put your on-screen menu on the screen and if it times out, bring it up again and again.
If the menu continues to display each time, your set is OK.
Call the service provider, Dish or Direct TV.
May 29, 2008 | LG RZ32LZ50 32 in. LCD Television
Televison & Video Logo
49 people viewed this question
Computer Repairing
Computer Repairing
