Question about Xerox WorkCentre Pro 416 All-In-One Laser Printer
Is it possible to reset pro 416 out of this problem.
Pro416 showing call for service
  • 239 Answers
Limited information provided.<br /> Pressing 8 start may give you a error code. Or a 8 plus stop button.<br /> If the machine has a C4 code, this may require machine software to be installed on the machine in order to correct problems. The scanner will not operate correctly even with a new scanner. The software needs to be installed by the service representative in order to align the correct software to main board, to correct laser heas assay.<br /> Good luck.<!-- from fixya rte -->
Posted on Aug 12, 2010
Whats i have to do when my dash show me service required with orange trangle
once the car has a service the workshop should reset the service indicator using an electronic scan tool via the on board diagnostic socket OBD if the light shows up before its next service is due there is a fault which needs to be diagnosed ,could be a lot of things,Airflow meter dirt , bad airtemp sensor or water temp sensor it will automatically store all errors in the DME or ecu.
Jul 31, 2016 | 2007 Mitsubishi Outlander XLS
Show how to service transaxle in 2006 2.4ltr camry altise limited
what service, just main axle, lube>?
be specific.
what prompted this?, issues. problems or just the operators
guide list of service points>?
Feb 07, 2015 | 2006 Toyota Camry
Codes for samsung
*#06# - IMEI number
*#0*# - Enter the service menu on newer phones like Galaxy S III
*#*#4636#*#* - Phone information, usage statistics and battery
*#*#34971539#*#* - Detailed camera information
*#*#273282*255*663282*#*#* - Immediate backup of all media files
*#*#197328640#*#* - Enable test mode for service
*#*#232339#*#* - Wireless LAN tests
*#*#0842#*#* - Backlight/vibration test
*#*#2664#*#* - Test the touchscreen
*#*#1111#*#* - FTA software version (1234 in the same code will give PDA and firmware version)
*#12580*369# - Software and hardware info
*#9090# - Diagnostic configuration
*#872564# - USB logging control
*#9900# - System dump mode
*#301279# - HSDPA/HSUPA Control Menu
*#7465625# - View phone lock status
*#*#7780#*#* - Reset the /data partition to factory state
*2767*3855# - Format device to factory state (will delete everything on phone)
##7764726 - Hidden service menu for Motorola Droid
You can find more of these spread across the internet, and they're usually very handy to have, even if just to show off your geekiness to your social circle.
Update x1: More codes!
*#*#7594#*#* - Enable direct powering down of device once this code is entered
*#*#273283*255*663282*#*#* - Make a quick backup of all the media files on your Android device
*#*#232338#*#* - Shows Wi-Fi MAC address
*#*#1472365#*#* - Perform a quick GPS test
*#*#1575#*#* - For a more advanced GPS test
*#*#0283#*#* - Perform a packet loopback test
*#*#0*#*#* - Run an LCD display test
*#*#0289#*#* - Run Audio test
*#*#2663#*#* - Show device's touch-screen version
*#*#0588#*#* - Perform a proximity sensor test
*#*#3264#*#* - Show RAM version
*#*#232331#*#* - Run Bluetooth test
*#*#232337#*# - Show device's Bluetooth address
*#*#7262626#*#* - Perform a field test
*#*#8255#*#* - Monitor Google Talk service
*#*#4986*2650468#*#* - Show Phone, Hardware, PDA, RF Call Date firmware info
*#*#1234#*#* - Show PDA and Phone firmware info
*#*#2222#*#* - Show FTA Hardware version
*#*#44336#*#* - Show Build time and change list number
*#*#8351#*#* - Enable voice dialing log mode, dial *#*#8350#*#* to disable it
##778 (+call) - Show EPST menu
These codes are specific to HTC devices only:
*#*#3424#*#* - Run HTC function test program
*#*#4636#*#* - Show HTC info menu
##8626337# - Run VOCODER
##33284# - Perform field test
*#*#8255#*#* - Launch Google Talk service monitor
##3424# - Run diagnostic mode
##3282# - Show EPST menu
##786# - Reverse Logistics Support
Mar 14, 2014 | Samsung Galaxy Cell Phones
) What feature of Powerpoint 2010 helps in broadcasting slides to remote audience
Dear Anand,
To broadcast your presentation, do the following:
  1. On the Slide Show tab, in the Start Slide Show group, click Broadcast Slide Show.
The Broadcast Slide Show dialog box opens.
  1. Do one of the following:
    • If you want to host your slide show on the service listed under Broadcast Service, skip to the next step.
    • If you want to use some other service to host your slide show, click Change Broadcast Service. Under Choose a broadcast service, select the service that you want to use. For more information about broadcast services, see Choosing a broadcast service.
Note If you do not see the service that you want to use, select Add a new service, and then in the Add Broadcast Service dialog box, enter the network address of the service you want to use and then click Add.
  1. After you select your broadcast service, click Start Broadcast. PowerPoint then creates a URL for your presentation.
PowerPoint creates a unique URL for your slide show.
  1. To send the URL for your presentation to your audience, do one of the following:
    • To send the URL for your presentation by email, click Send in Email.
    • To copy the link, click Copy Link.
  2. When your audience receives the URL for the slide show, click Start Slide Show to begin your broadcast.
The audience follows your slide show in their browser while you present within PowerPoint 2010.
  1. After you finish presenting and are ready to end the broadcast, press ESC to exit Slide Show view and then click End Broadcast.
After you begin broadcasting a slide show, the Broadcast tab appears in the PowerPoint 2010 ribbon.
Regards,
Tech_Comp
Feb 23, 2011 | Microsoft PowerPoint 2010
Nokia phone 3120 showing contact service
NOKIA 3120 contact service display on lcd after switch on
Dec 13, 2009 | Nokia 3120 Cellular Phone
Samsung mobile Model SGH X620 shows ''Limited Service''!!!???
samsung mobil SHG-X620 LIMITED SERVICE SOLUTION<!-- from fixya rte -->
Oct 12, 2009 | Cell Phones
Showing contact service
you need to bring that in service center to fix the service...
Sep 12, 2009 | Nokia 5130 Cellular Phone
Couldn't register service provider. Display shows ''LTD. SERVICE''
Its purely network problem. Dont try again and again with the same solutions. Switch off the mobile for some time, remove battery, and sim card, and put them again after some time and switch it on. In samsung, while switching on, it will show the service providers name in the start up screen. if it shows, then it should work. If it doesnt work, some problem with the sim card. try to replace it. or otherwise general operation in selecting the network shud help.
Aug 10, 2009 | Samsung Cell Phones
Xerox WorkCentre Pro 416 All-In-One Laser Printer Logo
238 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Philip Hughes
docukaaf
Level 1 Expert
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
