The top screw is very loose (about to completely come off) and the bottom screw is becoming loose, how do I either tighten the screw or take the handle off. Any help would be much appreciated.
SOURCE: Loose refrigerator door handle
weavie, this is one of those ugly little problems. Get hold of a small screwdriver, a pointy knife blade or similar and stick it into the gap, however small, between the cap and the handle. You may be able to find a small indent or similar near the bottom side of the cap. Gently pry up. It will yield. Be patient.
SOURCE: Loose door handle GE two door freezer/frig model TFG 22JADAWW
Called and watched mechanic who clipped of top and bottom covers with a screw driver then tightened both screws and replaced covers. Cost was $100 but I could have wrecked the door. Needs a special little star shaped screw driver head with ratchet fitting. Now equipped for next time.
SOURCE: Fisher Paykel fridge door handle loose
Yes hello, I had the same problem - similar fridge model. Mine was the fridge (not freezer) door handle ie. the upper door. There are no small holes on the bottom of my fridge handle. Working from the outer door edge, I gently prized loose the plastic trim located under the door. I didn't take it completely off, just loosened about one quarter of the length, enough to flex the trim downward so that I could then access the phillips head screw that secures the fridge handle from the inside of the door. The trim will prevent you from using a conventional screw driver to tighten the screw. I used a screw driver bit which is only 25mm long. It has an hexagonal end to which I applied a small spanner and voila - the handle is once more secure. Good luck.
SOURCE: Amana AFI2538AEW bottom freezer door handle is loose?
My dad's freezer handle is loose, model ABB2224DEW. Went to partselect.com and located drawing of freezer door parts. Found a link to a "do-it-yourselfer" that describes removal and replacement of the handle. Hopefully this helps.
Replacement of freezer door handle.
1. Removed freezer door handle. First I read the freezer door handle removal instructions in the Amana refrigerator user guide. Removing the handle requires inserting a plastic card at least 1.5 inches under the left end of the right side of the handle so it releases the butterfly clip latch on the freezer door. Next I pulled the right side of the handle to lift it away from the freezer door. Then still holding the handle away from the door, at the spot that is 1.5 inches from the inside of the right side of the handle, I held the plastic card vertically and slid one corner of it between the handle and the freezer door and worked the card down until it released the butterfly clip latch. Keeping the card at the same space under the handle so the latch was released, I then turned the card to the left until it was horizontal and was lifting the left end of the right door handle away from the freezer door. I then slid the handle across the card to the left until it cleared both door butterfly clip latches and it lifted off the door.
2. Installed freezer door handle. First I read the freezer door handle installation instructions in the Amana refrigerator user guide. The handle is curved on one edge and must be installed the curved side down. Correctly installed, the outside ends of the handle curve upward and the handle curve is down so it looks like a frowning mouth. Next holding the handle curved edge down, I turned it up so I could see the brackets and held it against the door. I lined up the handle brackets slightly to the left of the butterfly clips on the freezer door. Next I turned the handle with the brackets against the freezer door and slid it slightly to the right until the left side of the handle held onto the door butterfly clip by itself but was not latched. Then I lined up the right handle bracket with the right freezer door butterfly clip and carefully slid the whole handle to the right until I heard the left butterfly clip latch click. Next I slid the handle back slightly left once more and then slid it back to the right until I heard the right butterfly clip latch click.
Parts Used:
HANDLE, DOOR (WHT)
Level of difficulty:
Difficult
Time to do repair:
30 - 60 mins
SOURCE: refrigerator door handle is loose how do I fix it?
some come off when you pull straight up if there are no visible screws. then tighten the screws on the inside of the handle that fasten into the clips on the door.
