Question about Dymo LabelWriter Thermal Printer
Label stuck and making noise - Dymo LabelWriter Thermal Printer
How can i avoid label sheets getting stuck in phaser 8560
1. Make sure you are feeding the labels from the bypass tray, not from the cassette.-
2. Make sure the labels are for Laser printers, not Inkjet printers.
3. Do not try and re-use a label sheet that only was half printed on.
4. When you put the labels in the bypass tray, set the paper type to labels...this slows down the print process so they won't get jammed.
Jun 02, 2014 | Xerox Phaser 8550DP Printer
I have a label stuck in a Brother QL650TD
You will have to take off whatever component you can to get to the label and pull it out. Make sure to clean off the roller it is stuck on or you will get stuck again.
Oct 05, 2012 | Brother P-touch Ql-650td Thermal Label...
Hi, I can't get the magazine out and it reads CD ERROR on the stereo. i've tried to eject it using the button and can hear it making noises as though it is trying but it doesn't come out. i...
It seems so that the disc or the loading mechanism has jammed . Sometimes CD's which have labels or even warped ones( spurious types) can be stuck up as it will not move freely in loading thereby getting stuck in the mechanism.
Also sometimes the loading motor can slip on the pulley with a higher torque or the gear or belt can slip off-- since you can hear the noise when eject is pressed.
The best way is to remove power, open the covers and use a soft tool like a screw driver to push the struck up disc or manually rotate the gears to release the loading and thereby eject the tray out. Now inspect all the disc before you put then back inside as one of them is a suspect.
Aug 04, 2011 | Sony CDX-T69 6-Disc CD Changer
STUCK LABEL IN THE P-TOUCH QL-500 LABEL MAKER, This is now the third printer I have purchased and replaced because of stuck labels on the rubber roller, this is a great printer until this happens. Any...
I downloaded service manual
You need to remove the top cover
Remove the curved cover 1st , has 2 plastic pins to press inwards
Lift the curved cover upwards
Remove the darkcover beneath the labels
At the back 5x self tapping screws
At the from 2x machine screws, left hand one is under a label
Prise off the cover by inserting a screwdriver at the back edge
Voila
Remove the stuck label
Reassemble
Apr 01, 2011 | Office Equipment & Supplies
Little gray box electric timer. the clock dial seems stuck. makes a humming noise and is not moving. started happening after a power outage.
You may need to replace the timer motor. I believe you can purchase this part directly from the little gray box company - not their name, as you know - Find the company name on the label inside the box.
Thanks for your question at FixYa.com
Please vote when given the opportunity.
thanks
Dec 20, 2009 | Computers & Internet
Printer print one-third of the label and then stuck. After pressing button on printer goes empty label (sometimes one or two, sometimes more) and just after that goes good label. Often printer stuck on a...
You need to calibrate your printer to the label stock and clean the photo eye that the label passes over right before it goes into the printhead. Make sure the eye picks up the light. They MUST be in perfect alignment, normally about 1/2" from the side of the label. You should also make sure you have the correct label size AND orientation selected in the program you are running. Running a 6" X 4" label with the program set for a 4" X 6" label will stop the works.
Oct 02, 2009 | Intermec EasyCoder F4 Printer
Remove stuck label
THIS IS COMMON FAULT WITH PEOPLE WHO USE LABELS ON TYPEWRITERS. U MUST NEVER TURN THEM BACKWARDS OR U WILL GET ONE STUCK IN MACHINE. THE ONLY WAY TO GET IT OUT IS TO REMOVE PLATEN AND CLEAN THE JAMMED LABEL FROM THE FEED. AND ON SMITH CORONA MACHINES THIS IS NOT EASY TO DO ONESELF.
Mar 18, 2009 | Smith Corona Wordsmith 200 Typewriter
DYMO DUO LABELWRITER
The labels have a 2 yr warranty, so contact Dymo customer support and if they can't help you return the printer to the retailer you purchased from for a new printer. The Dymo LabelWriter DUO is an expensive printer that Dymo stands behind.
Feb 16, 2008 | Dymo LabelWriter 400 Turbo Thermal Printer
Printer is not working.
There are several things in the front that could be making that noise.The transfer roller,paper guide/top ublique roller and front obligue roller which is on the left side front. It is hard to say. I guess the printer is printing OK. If not what is the printer doing? Do you get any paper jams? Printing light? Can you rub the print off the paper? Any labels stuck? Please answer questions so I can help you. My guess is a roller problem. Which one is hard to say since I can't hear the printer myself.
Jan 13, 2008 | HP LaserJet 4L Printer
This is where I get stuck in trying to make Labels in Microsoft Works
Create a mail merge label with the Address Book
On the File menu, click New.
In the Works Task Launcher, click Templates.
In the Letters and Labels category, click Mailing labels.
Click Use this style.
In the Labels dialog box, click Mailing labels.
Click OK.
The Label Settings dialog box appears.
Under Printer Information, click the option for the printer you are using.
Under Label Information, select the label product and style.
If you're seeing 30 of the same label, try adding <<Next Record>> to the beginning of each label (including the < > characters as shown). If you need more help please simply reply to this by posting comments, and I'll be notifited right much faster than happening across a request for help by chance; the system will send me an e-mail to make me aware of your comments.
Hope this will FixYa!!!
Thanks,
Aimiel
Jan 05, 2008 | Microsoft Works 8.0 for PC
Dymo LabelWriter Thermal Printer Logo
119 people viewed this question
Top Dymo Office Equipment & Supplies Experts
Jax Planet
Jax Planet
jdthefixer
Are you a Dymo Office Equipment and Supply Expert? Answer questions, earn points and help others
