Question about PfaFF Tiptronic 2030
Pressure foot lifter is broken how to repair it
Pfaff creative 7570 embroidery unit error message 'raise the presser foot lifter' won't clear even though it is raised?
I had this problem, but ignored it, go through the advised listing on the machine's screen, under 'pressure foot lifter' and see if anything can be adjusted.
Dec 08, 2016 | PfaFF Creative 7570
How to fix a pressure foot lifter on a singer tradition
You can get a replacement Lifter from Sewing Parts Online here:
http://www.sewingpartsonline.com/presser-bar-lifter-singer-v880153000.aspx
Most likely, the screw end on the machine has broken off.
Jan 18, 2016 | Singer 2250 Tradition
Singer SM MN 93234--pressure foot lifter won't stay lifted, falls down. What to do?
sorry can't help you there may be you need it check by a sewing machine mechanic may be a screw is lose and need to be tight.
Apr 14, 2014 | Singer 7422
Pressure foot won't stay up
The presser foot lift lever on many newer janome sewing machines will wear out with use. It can easily be replaced by a sewing machine repair shop or Janome dealer. Or you can look online for a "presser foot lifter" or "presser foot lift lever" making sure to find the correct one for your machine.
Mar 03, 2014 | Janome Sewing Machines
Presser foot lifter
foot pressure needs adjusting
Feb 10, 2014 | Bernina Sewing Machines
Hi, the presser foot is stuck in the down position. The presser foot lever has no effect at all. As I have a project underway, I'm having to lift the foot by hand while I get the fabric under the foot but...
You need to get access to the pressure foot bar area. Open the side cover if you can and look to see where the pressure foot lifter lever meets the pressure foot bar lifting block. Maybe the block has sliped upward. You'll need to loosen the screw, slide the block down a bit, tighten the screw, and check to see if this works. (Not knowing what machine you have)
Apr 25, 2011 | Sewing Machines
My husqvqrna rose is telling me that the presser foot is up, and won't sew. but, the foot is down.
There is a micro switch next to the pressure foot lifter lever, and a lot of time the tab that activates that switch breaks off the lifter lever. A Viking dealer should be able to replace it for you.
Apr 24, 2011 | Husqvarna Rose
The presser foot lifter on my machine is not engaging this allows the needle assembly to spin - is there a way to fix this?
Your question is not clear. The pressure foot lifter only lifts the pressure foot. It doesn't make the needle spin.
Apr 23, 2011 | Singer 5062 Mechanical Sewing Machine
I need a replacement pressure foot release lever for a Simplicity BH600 blind hemmer.
Supposedly, Simplicity is made for Tacony. I would start there to ask about parts.
Is this a presser foot lifter?
I do not recall ever seeing a pressure foot lifter.
Mar 04, 2010 | Simplicity Sewing Machines
Faulty presser foot lifter on a singer 2110/2112.
I have seen these machines with broken presser bar clamps (something inside the head). If it is just a bind then some oil on the presser bar may work, if the clamp is broken then it is probably not worth fixing.
Jan 10, 2009 | Sewing Machines
Sewing Machines Logo
Top PfaFF Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Irene Tulloch
Are you a PfaFF Sewing Machine Expert? Answer questions, earn points and help others
