Question about Welding Tools
Gdlite charging lite does not go off
My DS Lite wont charge! Help!
Try another charger, yours may be faulty. Alternatively,the battery may need replacing as it is no longer holding charge, these can be obtained very inexpensively from Ebay and you will just need a small cross head screwdriver to remove the cover on the back of the DS lite, then tap the unit in your hand to dislodge and remove the battery.
Dec 22, 2013 | Nintendo DS Lite Console
My ds lite just switched off and it was charged
Hi, so if you try switching on the ds lite, nothing at all happens ??
Does the green light flash even if it is for like a split second.If it does then it is more likely top be a blown fuse. If 1 of your screens flicker also, this could be your problem as the ds will not start up with a broken screen. Please advise
Jul 31, 2012 | Nintendo DS Lite Console
My ds lite has stopped charging. we bought a new
theres problly internal problem! maybe some cable connection inside the system is not working!
Apr 08, 2010 | Nintendo DS Lite Console
My ds lite won't charge.. the orange light appeared blinked
We had this problem with a brand new DS Lite...turns out it was a bad charger. If you have access to another charger, try that first. Good luck!
Apr 03, 2010 | Nintendo DS Lite Console
The kids' DS Lite will not come on and when plugged in to charge the charge lite stays on for only a second. I tested working battery from newer machine in it and the charging lite still flickers out. What...
Sounds like your charging fuse has blown... I have a guide on how to change your fuses as well as how to take them apart.
fuse repair guide
DS lite dismantling process guide
If you need any further help feel free to message me via my profile page.
Regards,
SOD69
Feb 22, 2010 | Nintendo DS Console
Ds LITE WILL NOT STAY ON EVEN THOUGH FULLY CHARGED!
Well the reason behind that is if you left it plugged on all night it will take some battery life
Jul 20, 2009 | Nintendo DS Lite Console
DS lite cannot be charged
  • ok, i will go to school!
  • yes, very good!
May 23, 2009 | Nintendo DS Lite Console
Will not charge
no you just need to go to a store and but a new DS lite battery cell, it comes with the screwdriver necessary for the battery switch
May 05, 2009 | Nintendo DS Lite Console
Charging idiot lite remains lit.
Check all connections. You may have a loose wire or defective alternator
Jul 17, 2008 | 1997 Ford Ranger SuperCab
Welding Tools Logo
351 people viewed this question
Top Welding Tools Experts
Bill Boyd
Are you a Welding Tool Expert? Answer questions, earn points and help others
