Question about Nokia Cell Phones
How to turn off data roaming
Nokia 206, turn off data roaming
How do I turn off roaming when abroad.
not sure if this is what you are after..
Before you head off abroad, check your network settings. To do this, go to Settings > Mobile Data. Next to Mobile Data Options it will say either Roaming On or Roaming Off. If it says On and you want to make sure you don't spend any extra cash on data while you're abroad, tap this and set it to off.24 Jul 2017
How to avoid iPhone data roaming charges, and how EU rules affect ...
https://www.macworld.co.uk/.../how-avoid-data-roaming-charges-iphone-while-abroad-....
or go to this link.
How do turn off roaming when abroad Google Search
Oct 30, 2017 | Cell Phones
Why is my phone not roaming, after i have selected data roaming
Do you have data roming included in your mobile package? Might also be worth trying to turn on location service on your phone so it can tell where you are
Jan 17, 2017 | Cell Phones
Please can you tell me how to turn off roaming? I'm using pay as you go.
To turn off roaming go to your settings app, wireless & networks, mobile networks, data roaming, and turn data roaming off. How to turn data roaming and data services on off on my Samsung Galaxy...
Dec 03, 2015 | Samsung S5600 Cell Phone
What is data roaming
Data roaming is simply cellular internet data but using out of your country. For ex. when you go on holidays to Spain you can use cellular internet from roaming. Roaming is for calls and sms too. And important thing is that roaming is much more expensive then normal in your country
Jan 08, 2015 | Cell Phones
How to disable roaming on a Samsung phone model# SPHM9SO ? Im using virgin mobile service.
Hi Cyndi,
I have this site for you on how to do disable roaming. It includes image on how to do it. Hope it helps.
How to turn data services and data roaming on off on my Samsung Galaxy...
May 02, 2014 | Cell Phones
Stop roaming
If you need to stop Roaming phone signal,You should keep in mind the following instructions
1.Turn your voicemail off
2.Just switch Data Roaming off with a help of your service provider.
3.Try to access network through Wi-Fi while visiting abroad.
4.You can also avoid roaming by use the local carrier sim card,which is available in that country.Before put local carrier,Make sure your phone is unlocked or not.If it's restricted by some network,try to unlock your phone using
WickedUnlock.com
Mar 02, 2014 | Nokia 5800 Cell Phones
Turn off data roaming on Nokia 6300
Apps> Settings > Data Usage > Button > On or Off
Aug 09, 2013 | Nokia 6300 Cell Phones
How to turn digital roaming off?
  1. On the Home screen, click the Manage Connections icon.
  2. Click Mobile Network Options.
  3. Perform one of the following actions:
    • To turn on or turn off data service, change the Data Services field.
    • To turn on or turn off data service when roaming, change the While Roaming field.
    • To receive a prompt when roaming that allows you to turn on or turn off data service, change the While Roaming field to Prompt.
  4. Press the Menu key.
  5. Click Save.
Apr 20, 2012 | Samsung Cell Phones
My phone is saying digital roam mode when i make an outgoing call, how do i take it off so i can make outgoing call with no problem.
This is pretty much what you need to do. Just turn off all the roaming features. However when you roam it typically means you dont have service through Sprint so dont be surprised if when you turn off roaming capabilities your phone doesn't get ANY signal. Here's the link to your phones manual page 112 is about roaming.
Setting Roam Mode
Your phone allows you to control your roaming
capabilities. By using the Roaming menu option, you
can determine which signals your phone accepts.
Choose from two different settings on your phone to
control your roaming experience.
1. Press > Settings > More... > Roaming > Set Mode.
2. Highlight an option and press .
n Sprint Only to access only the Sprint network and
prevent roaming on other networks.
n Automatic to seek service on the Nationwide Sprint
Network. When Sprint service is unavailable, the
phone searches for an alternate service.
Call Guard
Your phone has two ways of alerting you when you are
roaming off the Nationwide Sprint Network: the
onscreen roaming icon and Call Guard. Call Guard
makes it easy to manage your roaming by requiring an
extra step before you can place or answer a roaming
call. (This additional step is not required when you make
or receive calls while on the Nationwide Sprint Network.)
To turn Call Guard on or off:
Call Guard.
2. Select On or Off.
To place roaming calls with Call Guard on:
1. From standby mode, dial 1 + area code + the
seven-digit number and press .
2. Read the message and press .
Note Call Guard is turned on by default on yourphone.
To answer incoming roaming calls with Call Guard on:
1. Press .
Data Roam Guard
Depending on service availability and roaming
agreements, yourphone may be able to access data
services while roaming on certain other networks. You
can set your phone to alert you when you are roaming
off the Nationwide Sprint Network and try to use data
services such as messaging.
To set your Data Roam Guard notification:
Data Roaming.
n Always Ask (default mode) sets your phone's Data
Roam Guard feature on. You will see a prompt that
will require you to respond anytime you access
data services while roaming.
n NeverAsk turns your phone's Data Roam Guard
feature off. Your phone will not notify you of your
roaming status when you access data services.
Touse data services when Data Roam Guard is active:
© When a notification appears informing you that data
roam charges may apply, press ROAM (left softkey)
to connect.
Note If the Call Guard feature is set to On, you need to
take extra steps to make and receive roaming calls.
Mar 08, 2011 | Sanyo SCP-2700 Cell Phone
Cell Phones Logo
15 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
