Question about Datacard SP75 Plus Card Printer
How replacing printheads for datacard printers sp
Sd260
Erro na Impressora Datacard D260L.
Mensagem 118: Problema com o tipo de impress?o.
Feb 20, 2014 | Datacard Group Datacard SD260 - plastic...
My datacard group SP75 color is printing cards with a white line all across it_
First, try to determine if it is printing a white line, or if an obstruction is possibly scratching the card surface; if it is an actual white line, then you probably have a pixel out in your printhead. Your printhead must be replaced.
Apr 15, 2010 | Datacard Group SP75 Color Card Printer
Displays colour streaks (mainly red)when printing
you need to make adjustments in the driver control panel color options, you may need service to calibrate the temperature, this can also be a result of poor quality PVC cards. Some card design software will allow you print parts of the card with black panel only which would eliminate this issue.
Mar 08, 2010 | Datacard Group SP35 Card Printer
Want to clean using the cleaning card.how do i do it -data card sp 35plus
You can't - the Cleaning Card supplied with the replacement ribbons is for other models of the Datacard printer, not the SP35 Plus :(
Jan 22, 2010 | Datacard SP35 Plus Printer
DataCard printer ribbon breaks
First, what color is it breaking on? Yellow, Magenta, Cyan, Black, Topcoat?
Next, I would do is clean all the rollers in the printer with isoprophyl alcohol (99% if you can find it, 91% is ok, 75% is you're in a bind). This is a common problem
Then, load the Printer Diagnostics from your print driver CD. In diagnostics, you can set the BASE POWER for YMC, K or Topcoat. The base power is totally different from intensity. As the printhead gets old, you may need to back off the intensity to keep the ribbon from breaking.
Lastly, take a look at the ribbon:
Is the image placed in the same spot of the ribbon on each panel or does it move (creep) higher or lower? This creeping action is caused by many things and would be best to be serviced by a technician.
Finally, printhead replacement. About $695 MSRP
May 26, 2009 | Datacard Group ImageCard Platinum Printer
Datacard SP35 - High Temperature
If you want to "control" the temperatur on the printhead , you first of all need to install Diagnostic program for your printer.
On the menu go to values.
Find Ymck power, which probably is on 0. and try to adjust to MAX 50 or -50.
Push the : Save current values to power on , button.
The passaword is 42360..
Dec 03, 2008 | Datacard SP35 Printer
Printing faintly
It sounds like the printhead temperature needs to be increased in the print driver. This will enhance the color and density of the ribbon transfer to the card.
For techncial assistance for id card printers by blog, visit our blog at www.safecardid.com/blog
Nov 04, 2008 | Datacard SP35 Printer
Printer Head Cleaning
It's in the blue plastic cover. Power down the SP75. Open cover to see the printhead. You'll see a green stripe. The printhead is in front of the stripe. Use an alcohol pen to run back and forth over the printhead. Do not drip alcohol onto the print ribbon. Allow a minute or two for alcohol to dry before reclosing the cover.
Nov 28, 2007 | Datacard Group SP75 Color Card Printer
Datacard SP75 Plus Card Printer Logo
22 people viewed this question
Top Datacard Office Equipment & Supplies Experts
Safe-Card ID...
Don  Farrell
Don Farrell
Are you a Datacard Office Equipment and Supply Expert? Answer questions, earn points and help others
