Question about HP Office Equipment & Supplies
Hp color laserjet cp6015 keeps on calibrating how do I solve the problem
Calibration problem
SOURCE: HP Color LaserJet 4600 Keeps Calibrating
Replace the Jet direct card in it. I had a similar problem and replaced the Jet Direct card, all was good never had that problem again.
Posted on Apr 28, 2009
iron_luiggi
  • 91 Answers
SOURCE: have a Color Laserjet 3600n printer. It keeps on calibrating without stopping when I switch it on. why ? thank sin advance.
600 Hp Continuous Calibration 1 Votos
This is an answer to most of the problems of "continuous calibration" in the HP 3600.When the printer begins to constantly calibrate and falls in line so we have a problem, there are several causes for that problem and must be discarded from the simplest solution to the most complex.
Let's begin:
SOLUTION 1: The first thing to do is turn off the printer, and remove the cartridges, toner dirty or if the internal parts of the printer remove the excess, if there is dirt in the transfer belt clean.then close the front cover and turn on the printer without cartridges. then open the lid, place the magenta cartridge, and close the lid again, and so putting the four cartridges. If the problem persists try the next solution.
Solution 2: We must be alert to any strange noises in the printer, it is likely that one of the sticks is failing, if we are a strange noise came from, and replace the cartridge.
SOLUTION 3: There are times that it is software problem can be solved with a "COLD RESET" to do this we must turn the printer, and press the green button several times in the main menu until you see some options, navigate to the Down Arrow button until COLD RESET appears, press OK. the printer will restart and initialize. then restart and probably reached OK status.
SOLUTION 4: Sometimes by changes in temperature and environment where the printer is out of calibration sensor, to do a need to upgrade the firmware of the printer, usually ends the problem here. To download the firmware of the printer with the improvement due to "Countermeasure for multiple Successive Causing Environmental Sensor Calibrations." Is in the following link:
http://h20000.www2.hp.com/bizsupport/TechSupport/SoftwareDescription.jsp?lang=en&cc=us&prodTypeId=18972&prodSeriesId=501044&swItem=lj-44336-1&prodNameId=501046&swEnvOID=54&swLang=8&taskId=135&mode=4&idx=0
SOLUTION 5: If any of these options serves, it is likely that the mirrors of laser printer are dirty, this requires us to print a sheet to observe defects in print (moved, blurred, misplaced shadows), if any of these defects appear we disassemble the printer for cleaning the laser ... in this link are instructions
http://ingenioysoluciones.wordpress.com/2010/04/12/limpiar-espejos-de-la-impresora-hp-3600n-para-corregir-impresion-defectuosa/
Posted on Apr 15, 2010
CreativeTECH
  • 1719 Answers
SOURCE: at a startup performing calibration
Calibration bypass
During certain diagnostic procedures, you will need to bypass the automatic calibration that is
performed whenever the printer is turned on.
To bypass calibration
1 Turn the printer on and watch the control panel display.
2 When the display begins showing the memory count, press and hold until all three lights on
the control panel are lit.
3 Press .
4 Press PAUSE/RESUME. The display should show SKIP DISK LOAD.
5 Press until SKIP CALIBRATION is highlighted.
6 Press . The printer will skip calibration and then continue its power-on sequence.
Please refer here for further details if required
Let me know if any further clarification is required. Hope this helps!
CreativeTECH
Posted on Nov 26, 2010
CCWS
  • 66 Answers
SOURCE: I installed/ changed all the
Having dealt with this issue only once before on a similar model I would say that the problem is one of the toner cartridges. After it calibrates for a few minutes open the front door and look at the Electrostatic Transfer (ETB) Assembly. There should be smudges/evidence of all colors on the belt and if any are any missing then that toner cartridge for that color is probably the issue.
I'd inspect the toner in question to ensure that it's seated properly, all the stickers/shipping protection is removed, and that it isn't so old that the toner might be one big clump and unable to be pulled by the pritner.
Hope this helps!
Posted on Mar 13, 2011
seeker5211
  • 1089 Answers
SOURCE: hp laserjet 3600 won't stop calibrating
Probably a DC Controller problem.
Have a tech check it out.
Posted on Nov 18, 2011
How to solve the problem of hp laser jet cp1525n color printer blurry or fuzzy picture problem
run full calibrate few time and test, if still the same change tonner, calibrate and test
Sep 29, 2015 | HP Laserjet Pro Cp1525n Color Printer...
Is there something I can clean on my HP Laserjet 2600n. I've done the recalibration and things that are built into the menu system. The colors appear faded, especially red. There's an echo-type of...
Using the REPORTS MENU print the "color supplies status". Make sure everything is good.
Select SYSTEM SETUP. Select PRINT QUALITY. Select CALIBRATE COLOR. Select CALIBRATE NOW.
Check the Transfer Belt(ETB) which is inside the front door. Make sure that it is free of your "racing stripes".
You can use HP TOOLBOX to troubleshoot.
You are using HP cartridges???
Dec 12, 2010 | HP Color LaserJet 2600n Printer
My HP color LaserJet 2500L printer will only print yellow or black. All the toners are good and the machine has been re-calibrated and cleaned but it will not print full color
Print cartridges might be improperly installed. Remove the print cartridge for the color that is printing inconsistently and reinstall it. im sure you tried this already, but thats from the manual. also check your settings in the computer verify greyscale is not selected. also. Re-calibrate anyway To calibrate the printer from the HP Color LaserJet 2500 Toolbox 1 Open the HP Color LaserJet 2500 Toolbox in one of these ways: • On the desktop, double-click the HP Color LaserJet 2500 Toolbox icon. • On the Start menu, point to Programs, point to HP Color LaserJet 2500, and choose the HP Color LaserJet 2500 Toolbox. 2 On the Troubleshooting tab, click Diagnostic Tools (on the left side of the screen). 3 Click Color Calibration. Then try a test page. if all else fails Try this The NVRAM reset is done by powering off the machine. Press and hold the Go button. Turn the printer on and continue to hold the Go button. After the Go, Ready, and Attention LED's tuirn on, continue holding for at least 20 seconds. During this process, the Attention, Ready and Go LED's will each turn off. Release the Go button. The device LEDs will begin cycling from front to back. The NVRAM init process runs unitl the printer is in the Ready state.
Aug 27, 2010 | HP LaserJet 2500 Printer
HP3500 all colors are printing too light - black is gray, blue is light blue, red is pink, etc. All cartridges are full, no error message on printer
Calibration is a printer function that optimizes print quality. If experiencing any print quality problems, calibrate the printer.
  1. Press (Select) to enter the MENUS .
  2. Press (Down arrow) to highlight CONFIGURE DEVICE .
  3. Press (Select) to select CONFIGURE DEVICE .
  4. Press (Down arrow) to highlight PRINT QUALITY .
  5. Press (Select) to select PRINT QUALITY .
  6. Press (Down arrow) to highlight CALIBRATE NOW .
  7. Press (Select) to select CALIBRATE NOW .
  8. Wait for the printer to calibrate.
that should solve your problem
Aug 12, 2010 | HP Color LaserJet 3500 Printer
HP LaserJet 1500... prints color yellow ONLY
It's possible that the toner in the cartridge is not evenly distributed. You can redistribute toner if you gently shake the cartridge from side to side, then reinstall it to see if this affects performance. Please also see this article.
You might wish to use the guided troubleshooting option available from HP support here. Or have a look at the troubleshooting section in the user manual here. Then clean the engine & calibrate the printer, as described pg. 88.
If that's no help, please see this forum post and the linked attachments within.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Sep 01, 2009 | HP LaserJet 1500L Color Printer
Apr 15, 2009 | HP LaserJet 4600dn Color Printer
Very Light Printer on HP Color LaserJet 3500
Table 7-33. Causes for distortion or blurring
Cause Solution
Transfer unit is defective. Replace the transfer unit. Calibrate the printer
after replacing the transfer unit. See Calibrate
Now, later in this chapter.
Defective secondary transfer roller If it does not rotate smoothly or it is deformed,
replace the secondary transfer roller.
DC controller PCB is defective. Replace the DC controller PCB. Calibrate the
printer after replacing the DC controller. See
Calibrate Now, later in this chapter.
Calibrate Now
Use the following procedure to calibrate the printer whenever you replace the DC controller,
the formatter, the color misregistration sensor (PS12), the transfer unit, or the laser/scanner.
1. Press to enter the MENUS.
2. Press to highlight configure device.
3. Press to select configure device.
4. Press to highlight PRINT quality.
5. Press to select PRINT quality.
6. Press to highlight CALIBRATE NOW.
7. Press to select CALIBRATE NOW.
hope this helps
pdouglasss
Dec 17, 2008 | HP Color LaserJet 3500 Printer
I changed the trasfer kit on my HP Color LaserJet 3500 and now the print is very light. I used and OEM transfer kit and followed the instructions provided by HP. Help
Calibrating the printer
Calibration is a printer function that optimizes print quality. If you experience any print quality
1. Press MENU to enter the MENUS.
2. Press to highlight CONFIGURE DEVICE.
3. Press to select CONFIGURE DEVICE.
4. Press to highlight PRINT QUALITY.
5. Press to select PRINT QUALITY.
Hope this works for you
pdouglasss
Printing quality off? 2550 HP laser jet?
When installing new cartridges, it's always a great idea to perform a cleaning and recalibration of the machine. Below are the steps needed to do just such a task. You may want to print these out or save them somewhere for future reference as well. They are directly from the HP website.
Please rate the tip accordingly and thanks for using Fixya.com.
Cleaning the printer
  1. Verify the printer is turned on and in the Ready state.
  2. Open the HP Color LaserJet 2500 Toolbox. Click Cleaning Page on the Troubleshooting tab, and the click Print (HP Color LaserJet 1500 or 2500) or Cleaning Page (HP Color LaserJet 2550). A page with a pattern prints from the printer.
  3. Remove any paper that may be in tray 1.
  4. Remove the page that printed and load it face down into tray 1.
  5. At the computer, press Clean .
Calibrating the printer There are two methods of calibrating the printer manual: at the printer or from the Toolbox on the computer. From the printer Turn the printer off and then on again. From the HP Color LaserJet 1500 or 2500 Toolbox on the computer
  1. Open the HP Color LaserJet 1500 or 2500 Toolbox in one of the following ways:
    • Double-click the HP Color LaserJet 1500 or 2500 Toolbox icon on the computer desktop.
    • Select Start , Programs , HP Color LaserJet 2500 , and then HP Color LaserJet 1500 or 2500 Toolbox to open the Toolbox from the Windows desktop.
  2. Click Diagnostic Tools on the left side of the screen on the Troubleshooting tab.
  3. Click Color Calibration to perform the calibration procedure.
From the HP Color LaserJet 2550 Toolbox on the computer
  1. Open the HP Color LaserJet 2550 Toolbox in one of the following ways:
    • Double-click the HP Color LaserJet 2550 Toolbox icon on the computer desktop.
    • Select Start , Programs , Hewlett-Packard HP Color LaserJet 2550 series , and then HP LaserJet Toolbox to open the Toolbox from the Windows desktop.
  2. Click Print Quality Tools on the left side of the screen on the Troubleshooting tab.
  3. Click the Calibrate Now button to perform the calibration procedure.
Nov 04, 2008 | HP LaserJet 2550Ln Printer
79 people viewed this question
Seeker5211
Seeker5211
