Tronic LD8132 lcd wall clock keeps resetting itself
I set the clock to the correct time for BST and during the next 12 hours or so it resets itself to one hour later, usually overnight, how can I make it stay on my time?
  • 3 Answers
SOURCE: how do you set the clock for 12 hr time, not 24 hour ??
On most clock radios, there is a Time button. Usually, just hold it down while adjusting the Hr. or Min. I have not seen too many clock radios that do not use that kind of setup.
Posted on Oct 28, 2009
  • 3 Answers
SOURCE: Starck clock wrong time zone
-Make sure clock is in radio sync mode. This is in the manual so won't repeat here.
-Press & release SELECT. Clock time numbers should flash
-Press & hold SELECT. It should enter clock settings mode
-Bottom of screen next to moon phase you should see the current time zone. PST after reset
-UP & DOWN will move through time zones.
-Press & release SELECT when done.
-Each time SELECT is pressed will move to a new setting like 12/24 hour etc.
-Press SELECT until clock numbers stop blinking or leave it alone to return to normal mode
-This should also work on the other Oregon Scientific Starck models.
Posted on Dec 21, 2009
BillB-SA
  • 2761 Answers
SOURCE: Oregon Scientific Model 323a--Atomic clock...the
Make sure that the clock is set for the correct time zone and that the DST (Daylight Saving Time) function is ON. Also, although not mentioned in the manuals, these clocks will typically jump and hour ahead or behind when the batteries get weak. Replace your batteries if they are more than a year old.
Bill B
Posted on Aug 01, 2010
  • 11 Answers
SOURCE: 12 hour vs 24 hour read on clock
Push the "mode" button twice to enter the time change function. Once the display is blinking keep pushing the mode button until you see the "pm" icon on the LCD display. When that happens set the clock as you normally would using the 1-4 keys.
Remember to check if the 12 hour clock is set to AM or PM.
Good luck.
Posted on Jan 07, 2011
  • 2418 Answers
SOURCE: I found my Seth Thomas
  • Place your Seth Thomas atomic clock face-down on a table or desk and locate a series of buttons labeled "PST," "MST," "CST" and "EST" on the back of the clock. Press the appropriate button to set the time zone.
  • Posted on Jul 04, 2011
    How do you set the minutes on the clock?
    There are two ways to set the clock on your coffee maker. 1- When you initially plug in the coffee maker, the unit will beep and "12:00" will flash on the LCD display for a few seconds. Press immediately the h/min button (o) to set the current hour. If "12:00" starts to flash, press the PROG button (n) for a few seconds until the "12:00" flashes again. Then press the h/min button (o) to set the current hour. There are AM and PM indicators on the top right side of the LCD screen. To set the current minutes, press the PROG button (n) and then press the h/min button (o) until the correct minutes appear on the LCD display. After 5 seconds, the unit will beep and the time will stop flashing. 2- At any other time, you can set the clock or change the set time by pressing and holding the h/min button (o). The unit will beep and "12:00" will flash on the LCD display. Use the h/min button (o) to set the current hour. There are AM and PM indicators on the top right side of the LCD screen. To set the current minutes, press the PROG button (n) and then press the h/min button (o) until the correct minutes appear on the LCD display. After 5 seconds, the unit will beep and the time will stop flashing. Notes: Your clock has now been set and will continue to keep the correct time, even after the coffee maker has been shut off. Unplugging the coffee maker or a power failure will reset the clock to 12:00 AM. Repeat the instructions above to reset the clock
    Source : Krupsusa.com
    Link to manual : http://product-support.groupeseb.co.uk/Download/Pdf/366/km730
    Mar 21, 2016 | Krups KM730D Breakfast Set Coffee Maker...
    Radio controlled Barolo Clock with hands keeps resetting an hour behind.
    It sounds like it is receiving a DST signal instead of an MSF signal or vice versa depending on your country, they are one hour apart.
    Unless this clock has a choice of signal settings the best way is to gently remove and reset the hour hand to the correct hour.
    Mar 04, 2014 | Trenkle Uhren Cuckoo Clock Quartz-movement...
    Clock Manuals
    leave it running when it gets to 12 oclock it wiil reset itself
    May 02, 2013 | Watches
    Wolf ovens getting err message after power outage
    I had a Wolf 30F wall oven with a similar problem
    after power outage. It wouldnt stop beeping with error message related
    to temperature control. My solution was to turn power of at circuit
    panel, then reset by pressing and holding the clear button for 5
    seconds.
    Also note: in my case I had to close the display
    before switching the panel off. When I tried to the reset process with
    the panel showing, it wouldn\'t reset.
    To reset other
    various parts of the control panel Instructions said:
    Time-of-Day Clock
    Immediately after the oven is installed, set
    the 12-hour clock to the current time of day. It may need to be reset
    after a prolonged power failure. The clock is visible on the control
    panel during all modes. If the upper oven timer is set, the clock will
    not be visible in the upper oven control panel display.
    SETTING CLOCK
    1) Touch CLOCK.
    2) Touch number pads to
    set current time of day.
    3) Touch CLOCK or ENTER to start
    clock.
    24-HOUR CLOCK
    The time-of-day clock can be
    changed from a 12-hour clock to a 24-hour clock. After the clock has
    been set, touch TEMPERATURE for three seconds, touch CLOCK, and then
    touch ENTER. Follow the same sequence to change back to the standard
    12-hour clock setting.
    Fahrenheit to Celsius
    The
    oven can be changed from Fahrenheit (°F) temperature to Celsius
    (°C).
    Oct 26, 2012 | Wolf Range Ovens
    Our Skyscan atomic wall clock will not stay at the correct time since we had the daylight savings time. I replaced the battery because each day at noon it would randomly reset it self to the old time (1...
    take the batteries out and leave them out for at least a minute. when you put the (new) battereis back in be sure that you have the correct time zone pushed and if there is a DST button or switch make sure that is pushed/set as well. place the clock with its back facing colorado and leave it overnight, it should reset itself ok.
    Mar 17, 2011 | SkyScan 86709 Atomic Wall Clock
    Feb 08, 2009 | Oregon Scientific Starck Large Music...
    S10Scan atomic clock model 87310 time is 4;pm should be 10:am
    Hi
    Time zone setting
    Language Setting
    The weekdays can be displayed in LCD1 with the pre-set languages: US English, French and Spanish.
    1. Set the desired language for the weekday display in LCD 2 by use of the + key.
    2. Press the SET key to enter the mode “Manual Time Setting”.
    Manual Time Setting
    In case the Skyscan Atomic Clock is not able to detect the WWVB-signal (disturbances, transmitting distance, etc.), the time can be manually set. The clock will then work as a normal Quartz clock.
    Note:
    In 12 hours mode the time will be displayed with an additional “PM” for the time from 12:00 noon until 11:59.
    1. The hour digits will start flashing on LCD1. Set the desired hours by pressing the +key followed by pressing the SET key.
    2. Now the minute digits will start flashing. Set the desired minutes by pressing the +key . If the + key is held, the units will increase by 5.
    3. Press the SET key to move to the “Year Setting”.
    Note:
    The unit will still try and receive the signal every day despite it being manually set. When it does receive the signal, it will change the manually set time into the received time. During reception attempts the WWVB tower icon will flash. If reception has been unsuccessful, then the WWVB tower icon will not appear but reception will still be attempted the following hour.
    WWVB time reception takes place from 12:00 am through 6:00 am each day (attempts WWVB reception every full hour within this time frame). When the time signal is received for example at 1:00 am, the Skyscan Atomic Clock will not attempt to receive the WWVB signal for the remaining hours until 6:00 am. Therefore, the next signal attempt will take place between 12:00 am and 6:00 am the next day. The other times WWVB reception takes place, are upon setup and after manual time set exiting mode. Reception is generally not possible during daylight hours due to the interference of the sun.
    for more details see user manual...
    Thank you
    Dec 12, 2008 | SkyScan 86709 Atomic Wall Clock
    SkyScan 87801 how to reset time
    Keep pushing the set button until dst shows on the date window then see the clock window it will read on or off press the + button for on or off.
    Sep 15, 2008 | SkyScan 86709 Atomic Wall Clock
    Good luck.
    Sep 09, 2008 | Sharper Image SI686 Clock Radio
    Date changes wrong time
    thats because analog watches don't know the difference between AM/PM. First reset the time, moving the hour and minute hands another 12 hours will let you know exactly what mode its in (am/pm) first allowing you to set the date correctly.
    Nov 12, 2007 | Watches
    111 people viewed this question
     Grubhead
    Grubhead
