Question about Topeak Cycling
Wedge bag How to use
Need wiring diagram for a Maytag washing machine . Model #LAT9306AAE
That information is found in your form guide. It's generally located in a waterproof bag affixed to the inside wall of the washer. You need to open the the top to gain access to it. Locate two spring loaded clips approx. 6 inches in on either side between the top and bottom of the machine with a 2 inch putty knife/scraper. Once located, take the putty knife out and push in and up on the clip. I use a wood wedge to hold it up until I release the clip from the other side. The back of the machine top has a hinge so don't put it back too far. The bag should be on the left side. Just push the rubber seal on the top back a bit. If the bag is empty due to a previous repair, it maybe located under the back panel. Remember to always unplug the machine before you attempt any repairs.
Jan 03, 2017 | Maytag Washing Machines
How to unlock doors if key or remote won't work?
Hi - Failure of both items (key and remote) is unusual, but one sure way in is the method used by most tow companies or AAA. By inserting a wedge, sometimes followed by a mini air bag, they spread the space between the door frame (or glass) just enough to reach in with a long, bendable bar and unlock or simply open the door from inside. Find a friend with AAA membership - the person is covered even if it is your car! For more information on what I am attempting to describe, you can see several images by Googling "car door wedge open kit" or simply click on this incredibly long URL. Good luck! - https://www.google.com/search?q=car+door+wedge+open+kit&client=firefox-a&hs=igL&rls=org.mozilla:en-US:official&channel=sb&tbm=isch&imgil=p4B26oxi9XCpeM%253A%253Bhttps%253A%252F%252Fencrypted-tbn2.gstatic.com%252Fimages%253Fq%253Dtbn%253AANd9GcRDsGCwtS3tJBAUUTAbOgA2CQm8WXFfxl55Js4YdoapTq2wjoVY%253B500%253B500%253BSYbGmtWkK3dwzM%253Bhttp%25253A%25252F%25252Fwww.spyemporium.com%25252Fcar-lockout-tool%25252Fwedge-inflatable-car-door-opening-tool%25252F&source=iu&usg=__wbzqeRAHuz5SYmce1FnyBj3FQ2Q%3D&sa=X&ei=PbmsU67QKMbN8wGAyIHgDg&ved=0CE8Q9QEwAA&biw=1296&bih=729#facrc=_&imgrc=p4B26oxi9XCpeM%253A%3BSYbGmtWkK3dwzM%3Bhttp%253A%252F%252Fwww.spyemporium.com%252Fimages%252Fproducts%252Fst-af-p.jpg%3Bhttp%253A%252F%252Fwww.spyemporium.com%252Fcar-lockout-tool%252Fwedge-inflatable-car-door-opening-tool%252F%3B500%3B500
Jun 26, 2014 | 1999 Mitsubishi Diamante
Just trying to figure out how to install the topeak aero wedge pack
Search engine "install the topeak aero wedge pack" takes you right to it - immediately.
http://www.topeak.com/products/Bags/AeroWedgePack_large_Quick
The manual is there to download.
Fixya experts need not be in the loop. You could have had your answer, um, 6 hours ago.
Aug 03, 2011 | Topeak Cycling
Locked out of my mustang. Have a slim jim. how does it work?
Lots of things inside your door that a slim Jim can destroy. But basically slide it between the window and the rubber seal at the bottom of the glass. The idea is to hook onto the door lock linkage and pull up or push down. I'd really recommend letting a professional do it with modern lockout tools. Very easy to break stuff with that tool.
Mar 06, 2011 | Ford Mustang Cars & Trucks
Splitting the shell on Electrolux Epix 6500
With the vacuum on flipped on it's top and the bag door open, wedge a screw driver between the rear cover and the bumper. Gently tap the side of the screw driver blade toward the front of the machine. Make sure you pay very careful attention to where everything goes. It is very specific inside for reassembly.
Dec 24, 2009 | Electrolux Guardian Bagged Canister Vacuum
99 buick century headlights
u changed the multifunction switch or the main head light switch?
Sep 09, 2009 | 1999 Buick Century
Need to open the electrolux vacum
The locking key on the side of the vac has a tightening wedge on it so it doesn't slide easily. Spray the entire key top and bottom with WD40 or similar. Grasp at the bag door area with vise grips and pull the key straight forward.
If the key will not slide, you will need to take a large flat bladed screwdriver and lay the blade flat at 90 degrees against the back end of the key. then strike the side driving the key forward toward the bag chamber door. Do not twist.
Aug 22, 2009 | Electrolux UltraLux 2000 Bagged Canister...
Air bag depolyed, I want to dis-able dash light 2001 Ford Ranger
for obvious reasons, it is not recommended to do so, there is no way "disable system" but you can remove instrument cluster and it has a small twist and pull light socket behind it. remove the wedge bulb from holder and reinstall holder with no bulb.
Mar 11, 2009 | 2001 Ford Ranger Regular Cab
Can't open my EPC 6500 Electrolux
What you do is open the bag cover, then lay the machine on its side. Wedge a flathead screwdriver in between the bumper and the rear plastic guide. With a mallet, strike the flathead towards the bag cover. (The front of the machine.) Until the guildes come off. After both sides are done, close the bag cover and roll the machine so it rests on its back. With 2 fingers inside of the opening where the cord comes out, pull up firmly with the other hand holding the machine in place. TA-DAH.
I wouldn't bypass the bag sensor if I were you. It's there for a reason. It sounds like your control valve is out. Change that and your problems are over. Quick and super simple fix.
Oct 18, 2008 | Electrolux Epic 6500 Vacuum
Cycling Logo
27 people viewed this question
Top Topeak Cycling Experts
numbers819
Level 1 Expert
dante
Donald Ayers-Marsh
Are you a Topeak Cycling Expert? Answer questions, earn points and help others
