Soniq 55 inch tv manual
My tv leans forward on the stand how do I adjust it so it stands upright
  • 15 Answers
SOURCE: tv stand screws
Check the kitchen drawer next to the fridge for the screws !!
When you get new screws, use lengths 1/2".. any longer and you might hit something inside.
Don't know why this is posted under IS-LCDTV26.. I would pull a screw from my 26" and measure it, but it's most likely different than your 42"
Posted on Sep 06, 2008
  • 54 Answers
SOURCE: I can not remove the stand from my aquos 46 inch tv.
you will find 4 screws at the back of the tv about 4" inches from the bottom. lay the tv set flat on your bed. you will need a metric allen wrench to remove the 4 screw. once the 4 screws are removed slide the base away from the tv.
Posted on Jan 19, 2009
SOURCE: Can not remove the stand to mount it on the wall
If the Aquos 46 is anything like the Aquos 42, the monitor is attached to the base with machine screws (bolts). They are located in the lower back portion of the monitor, probably need an Allen wrench to loosen and remove. Once that is done, the base can be removed from the monitor. Best way is to lay the monitor face down on a tabletop padded with foam, a quilt or blanket, etc to protect the screen as you work. Remove the stand from the monitor, not the monitor from the stand; it is easier and safer that way.
Posted on Jan 24, 2009
  • 27 Answers
SOURCE: Lost Screws for stand for Insignia IS-LCDTV32 32
they are couse scews your best bet is go to lowes or home depot and get a few of each 1/4 inch screws to see which one fits they only cost about .03 each
please rate my answer it is much apreceated
Posted on Feb 13, 2009
welcomejee
  • 10594 Answers
SOURCE: replacement table top stand for sony bravia 32
OK, Following is part number of Stand of KDL-32S3000 TV
A-1259-944-A STAND (M_WS) ASSEMBLY (KDL-26S3000/32S3000 ONLY)
It is available in Part Store.
Thanks.
Posted on May 18, 2009
How can I use headphones wit a Soniq S55UV16B-AU Smart TV?
You have to use wired headphones and plug them in.
https://www.jbhifi.com.au/tv-home-entertainment/hd-televisions/soniq/soniq-s55uv16b-55-uhd-smart-led-lcd-tv/316772/
Component Inputs - 1
RCA Inputs - 1
RF Input - True
Headphone Output (3.5mm) - True
Energy Star Rating - 3.5
Product Height with Stand (mm) - 782.7
Product Width with Stand (mm) - 1240.6
Soniq S55UV16B
Sep 23, 2017 | Televison & Video
Cost to replace plasma on Sansui 42 inch TV
Hi Richard,
An original Sansui stand could be expensive try to find a universal stand to suit your TV here are some that should accommodate your TV: MISC STAND 3755BB 37 55 Lcd led plasma Stand
Jan 24, 2016 | Sansui Televison & Video
Where can I find the piece that holds the tv for vs91350-01
Walmart and others have the universal "jimmy stand" for about 90 bucks. This will mount to the TV (on the back like a wall mount) but also includes a base so you can simply set it on a table.
http://www.walmart.com/ip/ShopJimmy-sj-Stand-3755BB-Universal-TV-Stand-Base-Plus-Wall-Mount-for-37-inch-55-inch-Flat-Screen/36774428
or search
sj-Stand-3755BB
Oct 26, 2014 | Televison & Video
I have no sound in my TV 55 inch sony
Did you check the mute? Its possible it was muted.
Aug 02, 2014 | Bernards 55-inch TV Surround Sound...
I just purchased a 52 inch phillips tv and the stand that the tv sits on adds 2 inches which doesn't allow the tv to fit in my entertainment center. What can I do?? I need a shorter stand...
Just take off the stand altogether if you can lay the TV close enough to a solid vertical support.
My 47'' Philips spent about a year without a stand sitting on a desk and leaning on a wall.
It's heavy enough and as you approach to completely vertical position its main force will be pointing down, not forward.
If you can't lean it on anything solid or if it doesn't sit well while in an entertainment center...not sure what I'd suggest....short of adjustable wall mount stands...
Nov 07, 2009 | Philips 52PFL3603D/27 52 in. LCD HDTV
LG - 32LG20 - Excellent LCD TV, but the stand is junk
there are four screw holes at the back, you might want to make use of it for anchoring. I guess these models are designed for TV-like installations and not for computer desktop monitors. The base takes a lot of space too.
Aug 16, 2009 | LG 32LG30 32 in. LCD HDTV
The best ways to move my 55 inch Mitsubishi TV to another home?
Move it with an appliance hand truck and do not lay it on it's side. When transporting, always keep unit standing upright. Good Luck
Aug 14, 2007 | Mitsubishi WS-55819 55" Rear Projection...
Televison & Video Logo
Top Televison & Video Experts
