Question about Bosch Washing Machines
Stabilizer Adjusting feet and
My serger will not sew light fabricssuch as light weight cotton or flannel
is it an industrial serger or for the home?
try different needles
also try adjusting the tension
Mar 11, 2016 | Sewing Machines
How long is 13 cu feet like how many foot is that
One cubic foot is a cube one foot long, one foot high, and one foot wide. How long is 13 cubic feet is is not answerable because it could be any number of lengths depending on the lengths of the other two dimensions.
May 16, 2015 | Office Equipment & Supplies
My front loader shakes when in the spin cycle. It shakes a lot! I am not overloading the machine, and the floor is level help?
Hi from retired Englishman in SW France @20:54 Sat evening 'cos there's nothing on TV!!
Please don't take offence BUT- the floor might be absolutely level BUT the feet on the washer might not be adjusted absolutely perfectly- honestly!
Always shows up most during spinning of course.
I would strongly suggest that you, or a helper, with the machine not working, push STRONGLY at one of the front corners to see if the washer rocks even the tinyest bit. If not one corner then the other.
The back feet do not need to be adjusted, just the one under whichever corner rocks.
It needs adjusting (downwards of course) until it is tight on the floor, really tight but without lifting the machine at that corner. This will ensure stability for starters.
If the machine stills rocks it is possible, although a bit unlikely, that one of the shock absorbers which assist in the suspension of the drum might be malfunctioning. It would need chanmging of course but do check the feet first.
Hope this does cure your problem.
John C
Jan 29, 2011 | Frigidaire Affinity ATF7000E Front Load...
Clunking noise and something feels loose underneath my feet when going over bumps
very common for the stabilizer bar bushings to get loose on this model. check the bushings by trying to move the stabilizer bar up and down and left and right, if there is any movement, they need replaced. Also check the stabilizer bar links, by holding the bar and moving it up and down and also holding the link to see if the joitn moves or not
Jun 10, 2010 | 2005 Ford F 250 Super Duty
My Kenmore Dryer drum is vibrating after running for a while with and without clothes. What Maybe the issue, 110.76972130
Could be that the unit is not level. If the unit has self adjusting front feet, make certain the unit is level from left to right, by adjusting front legs, then pull the rear feet and inch or so from the floor, by leaning unit towards front, set back down evenly. Unit should be level.
Mar 24, 2010 | Dryers
Washer shakes bad after relocating
There are leveling feet under the machine. By turning the feet, you can stabilize and level the machine.
Dec 26, 2009 | LG Washing Machines
Base moves too much and only spins for awhile before dispaly ul
The washer needs to have the auto leveling legs reset.
The message you're getting "ul" means "unbalanced load" and usually results when washing lots of towels or lots of jeans, etc., basically large fabric that holds quite a bit of water.
In order to get the washer leveled, you will need to stand at the front of it and reach to the back sides and tilt the washer towards you, keeping the front of the washer on the floor and tilting/lifting the rear of the washer about 4-5 inches off the floor. Once you've got it up, just let go of the washer and it will hit the floor and self level the rear legs.
You can then use the adustable front feet to get the washer stabilized so it doesn't more all around when doing laundry. Try not to lift the washer much when adjusting the two front corner feet. The goal is get the washer stable and solidly planted on the floor so it doesn't move around when running.
Hope this was very helpful and best regards!
Aug 07, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Washer virbrates but is level
Ok, first check level at front, left to right should be level, then tilt the machine forward moving rear feet off the floor, dont use the console as it is fragile, grapple at the steel frame below. You should hear a sound of racheting, This is the rear feet adjusting, do this twice. Now if you dont hear this sound and the machine is new, check for a yellow plastic tab, shipping pin to remove, or you have a Cabrio or Oasis. If this dont work you will need to support the floor to stabilize the machine.
Aug 08, 2008 | Kenmore 22422 Top Load Washer
Need feet for 20" box fan
you can purchase the feet at lasko.com go to there parts dept. i think i paid 2.00 plus s+h.
Oct 16, 2007 | Lakewood 200I Floor / Box Fan
Washing Machines Logo
13 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
