Question about Kitchen Ranges
Frigidaire range model #fgfl67dcf needs to be calabrated, too hot for setting
  • 111 Answers
OVEN CALIBRATION Set the electronic oven control for normal baking at 350°F. Obtain an average oven temperature after a minimum of 5 cycles. Press CANCEL or CLEAR to end bake mode. TEMPERATURE ADJUSTMENT 1. Set EOC to bake at 550°F. 2. Within 5 seconds of setting 550°F, press and hold the bake pad for approximately 15 seconds until a single beep is heard (longer may cause F11 shorted keypad alarm). 3. Calibration offset should appear in the display. 4. Use the slew keys to adjust the oven temperature up or down 35°F in 5°F increments. 5. Once the desired (-35° to 35°) offset has been applied, press CANCEL or CLEAR. Note: Changing calibration affects both Speed Bake and normal bake modes. The adjustments made will not change the self-cleaning temperature.
Posted on Jun 18, 2009
The cooling fan for the stove top stays on due to a burner showing HE but not on or hot
Hello Chris Lowman, thanks for your inquiry!
I understand that your Frigidaire range, FGES3065KFC, is flashing the error code "HE". However, it appears "HE" is an invalid error code. We should try resetting your range. You can do this by unplugging it or flipping the household circuit breaker to the off position for roughly ten minutes. This usually clears false error codes.
If resetting the power does not correct the issue and you continue to receive an "HE" I would recommend reaching out to a professional. He or she could come out and perform an accurate diagnosis on your range to assure the repair is completed properly. I hope this information is helpful. -Matt
Nov 04, 2014 | Frigidaire Kitchen Ranges
Turned on oven to 325 degrees it kept heating till very hot and now oven will not turn off
Good Morning Friend,
I understand that your Frigidaire electric oven will not shut off. I also see that it gets very hot, way past the set temperature of 325 degrees. I suggest resetting your appliance, by shutting the power off at your home's circuit breaker, for 3-5 minutes. Once power is restored, you will need to set the clock before starting any cycle. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your range status has changed successfully. If further troubleshooting is needed, please leave me the model number of your range. Typically this number can be found on the back of the door or possibly in the bottom drawer. Hope this is helpful.
-Best Regards-
WP
Jun 13, 2014 | Frigidaire 30" Self-Cleaning Freestanding...
My oven wont shut off and gets very hot way past set temp what up with this.
I understand that your Frigidaire electric oven, model# es 200/300, will not shut off. I also see that it gets very hot, way past the set temperature. First, make sure you have not put it into the self-cleaning cycle. If it is not in the self-cleaning cycle, I suggest resetting your appliance, by shutting the power off at your home's circuit breaker, for 3-5 minutes. Once power is restored, you will need to set the clock before starting any cycle. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your air conditioner status has changed successfully. Hope this is helpful.
-Best Regards-
WP
Left front range top burner temerture control issues
I understand that you are having trouble with the left front burner on your Frigidaire range, model# FEF355. I see that the burner heats up to a glowing red hot temperature, no matter what you set the dial to. I suggest resetting your appliance, by either unplugging it or shutting the power off at your homes circuit breaker, for 3-5 minutes.
When power is restored, the first thing you will need to do is set the clock. You will do this by pressing the "Clock" button, then within 5 seconds press and hold the up or down arrows until the correct time of day appears.
Once you have set the time, turn on the left front burner, on the lowest setting. If the burner is still glowing red hot, I suggest contacting your local authorized technician for further assistance. They will be able to diagnose your range and determine what is causing the burner to glow red hot on all settings. Hope this is helpful.
-Best Regards-
WP
May 15, 2014 | Frigidaire FEF355 Electric Kitchen Range
Frigidaire cookstove model no. fgf316wgta oven not getting hot enough
Hello - Does it reach the temperature and then back down, or does it take too long to get to your set temperature? Either you have a faulty element or a bad communication error with the main control board.
Sep 25, 2012 | Frigidaire Kitchen Ranges
How do I use my self cleaning oven model # FEF357BAWC
just set it to clean then it will lock the oven and let it get really hot it will loosen the spilled food by burning it off and just wiping it off when the oven cools
Oct 29, 2009 | Frigidaire FEF352 Electric Kitchen Range
Frigidaire gas range broiler element does not light.
glow plug needs to draw 4 amps to open gas valve even if it red hot ...not drawing 4 amps replace glow plug
Aug 22, 2009 | Kitchen Ranges
Frigidaire Gas Range Oven not getting hot - FGF376CEFP
DEAR CORDLESS TRY CHANGEING THE GLOW IGNITER THE GLOW IGNITER GOES BAD AFTER A FEW YEARS AND YOU HAVE TO CHANGE THEM YOUR BURNER SHOULD LIGHT IN 30 TO 60 SECONDS IF YOUR GLOW IGNITER IS NOT DRAWING ENOUGH AMPS YOU WILL SMELL GAS BUT NOT IGNIGHT THANKS GEORGE
Oct 29, 2007 | Frigidaire FGF376 Gas Kitchen Range
Kitchen Ranges Logo
506 people viewed this question
Top Kitchen Ranges Experts
Oloyede Monsuru
Marvin
Marvin
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
