Question about Sony FD Trinitron WEGA KV-21CL10 21" TV
Sony tv KV-28CL10U no sound and its from the board but i cant identify the exact part to fix If anyone has any idea about what I should do than please let me know about it!!!!! many thanks calid
    Top Expert:
  • Sony Master
  • 74,136 Answers
Check the speaker/s first. If found OK; check and replace the damaged component/s at its audio output section circuit board. If needy, replace this board as card basis. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy. Surf the site with patience. Pull up older posts. Surf the site with patience.
Posted on Apr 15, 2014
sonysonyman
  • 68 Answers
SOURCE: vertical fold over
if the set has a previous vertical line problem and a white horizental line only comes in the cross of the screen and you turned the tv on for a time while the problem is solved that mean you have make a burnt line to the screen , but if you are the tv owner and nothing of that happens so you have a problem in faulty dried capaciter in the vertical live part search for 33uf 160 v or 22u 160 v and alter regards please don't forget to rate thx
Posted on May 03, 2007
MikeNJ1964
  • 398 Answers
SOURCE: sony tv no pic or sound
Sony error codes usually only go up to 7. If the LED blinks 11 times, this usually indicates that either the clock or data line is shorted and this needs to be serviced by someone with experience with Sony sets.
Posted on Jun 28, 2007
SOURCE: SONY KV-XF21M80
maybe the bytes of the memory are not enough for this case^_^
Posted on Feb 27, 2008
SOURCE: sony kv-21x1u
Press and hold for a few Seconds the 2nd Button from the left on the front of the TV. The auto tune menu will appear on the bottom right of the screen. Wait until it disappears and then check the channels by using the buttons on the remote.
Posted on Oct 04, 2008
stonephoenix
  • 563 Answers
SOURCE: Hi I have a sony Wega tv model # KV-27FS12. When i
G'Day!
The TV can be fixed as long as the parts needed are still available from Sony. However, as far as trying to determine what part(s) are needed, I wouldn't listen to anyone other than a tech who's actually taken a look at the set or has worked on one with the exact same problem. If you make a call to a local repair shop, especially one that advertises repairing Sony, a nice guy will at least give you a ball park figure as to what the repair will cost you.
I hope I've provided you useful assistance and that this information allows you to make an informed decision as to how to proceed from here. Please be sure to vote on my response. I hope I've earned a good rating from you today.
Please let me know if I can be of further assistance.
Posted on Jul 11, 2009
Sony Trinitron KV-27FV310 won't stay on, standby button flashes around 10 times, help please?
Check Q8014 and Q8013 for shorts, leakage, or bad solder connections on the " D" board. If the transistors are bad, check R8051 and IC8005, also on the "D" board
Jun 18, 2012 | Sony FD Trinitron WEGA KV-27FV310 27" TV
I have a Sony Trinitron model kv-a2921b. The TV
HELLO MIKE
I don't think your TV is totalled! It's more than possible that a speaker connection on the main board has come adrift and just needs pushing back in. Check connections on the speakers themselves and when you trace back the cables there will one or two push in connectors.
It may be a good idea to get the speaker connection plugs checked and resoldered. It is also possible that the fall could have jolted the audio IC and this should be checked for dry joints or cracked print on the board too.
Hope this helps (:-)
Oct 03, 2009 | Sony FD Trinitron WEGA KV-27FS100 27" TV
Hi I have a sony Wega tv model # KV-27FS12. When i turn the tv on this is clicking sound and the tv has no picture. The tv automatically turns off after ten seconds or so. The sand by light flashes 4...
G'Day!
Jul 11, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony KV-28DX30U TV - No picture, only sound.
5 times flash code shows problem with AKB (white balance of CRT)
Please adjust RGB gain and screen volt of this TV.
Feb 14, 2009 | Sony FD Trinitron WEGA KD-34XBR2 34" TV
SONY WEGA PROBLEM
That doesn't make sense. When you state that the TV comes on 5 minutes later, doo you mean that you get sound right away but hte picture comes on later? If so, a :power board" won't help. Please update this so we can narrow down the problem and get you a solution.
Thanks,
Dan
Aug 20, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
No Power on Sony TV Model KV 36FS120
Hiii....
The sympthon 9 blinks :
Check at G board : D6301 D6116 ( replace with new one !!!! ).Voltage around +/- 12 -13 v .
Thank's
[Vrya]
e-mail : be_cek@yahoo.com
Mar 01, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony KV-36FS17 36" TV
Check video out, Q705, 732, 761 and other components on the C board, also check Q218, 219, 220 on the A board.
Hope this helps.
Jan 22, 2008 | Sony KV-36FS17 36" TV
Sony KV-28CL10U TV
Those blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://homenol.blogspot.com/
If blinks continue without any pause, the main board is faulty.
Search the site by type in the "brand name" to your device, in the "Search box at the top right of the display window of the Homepage" to get gathered related posts
Mar 08, 2017 | Sony FD Trinitron WEGA KV-21CL10 21" TV
Sony Trinitron kv-32fq75b
Sounds like the either the connection from the cable/sat box is loose or the board connecting the cables to the tv is loose. If you try unplugging and then reconnecting the cables and hold the cables in tight that might give you and idea. If you hold the cables in tight and the tv works right, then you know its your board. If thats the case the Tv needs to be serviced. Otherwise you might try using some other cables.
Aug 26, 2007 | Televison & Video
Sony KV-36XBR250 - no picture, good sound
This is a common failure mode (which I now share), and has nothing to do with the picture tube or surge protection. From the forums I have searched to-date, it appears to be a failed component in the flyback circuitry, but Sony will not admit to an inherent defect. If anyone has ACTUALLY FIXED this problem, please post a reply. Guessing won't help anyone. Thanks.
Oct 24, 2006 | Sony KV-36XBR250 TV
Sony FD Trinitron WEGA KV-21CL10 21" TV Logo
35 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
