Question about Hotpoint Refrigerators
Money grabbing companies
I have help a friend by selling her American style freestanding fridge freezer, big mistake, the bottom draw of the freezer was missing. I called Indesit and explained that I didn't have the freezer at my house and that I had looked through there website and got the make and model number and even the order number from the site. I spoke to a lovely lady who checked twice that the part she was sending was the correct one. The part took over a week to arrive only to be the wrong size. After many phone call back and forth we finally established that a mistake was made upon ordering. She even admitted on the phone that she had written a letter S instead of a K from the model number. With that established I went on to discuss retuning the part and getting the correct part only to be told that I had to pay for it to be returned, not only that I would have to pay postage again for the new draw and that I wouldn't get a refund until the part was back in the wearhouse and that I would have to pay again. All parties concerned are skint until the end of the month yet the fat cat of Indesit just get richer!!! Morel of the story is never be involved in selling anything unless it for yourself!!
  • 833 Answers
SOURCE: Samsung Fridge Freezer Model RS20
Renee,
There are a few things we need to look at. The likely cause is frosting up of the coils. This will also stop the fan. The best thing to do is to defrost the unit completely. The easiest way to do this is to shut it down and leave the doors open for 24-48 hours. You'll have to mop up a surprising amount of water. Now, why did it happen? Probably humidity due to 'window shopping', not closing the doors/bad/dirty gaskets, leaving liquids in the box which are uncovered. If this doesn't fix it...and you'll know after a week or so, it may be that the unit is low on gas or has a defective defrost timer...but that is getting ahead of ourselves.
Posted on Jan 23, 2008
SOURCE: Samsung fridge freezer
Hi I have same problem as gordon. fridge 5 years old.
Posted on Mar 02, 2008
farfield
  • 462 Answers
SOURCE: GE freezer/ bottom refrig won't turn on after short power outage
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Does it have a light inside? Is the bulb good? does the light go out when you push the button in? Why was power off? To change over to your name doesn't require the power co to kill power. At least it doesn't here. Try plugging in a lamp or other appliance to the outlet. Does this work?
It may have went into defrost and will take up to 30 minutes maybe longer with power applied before it comes back on.
Checking power inside the box next power to the compressor.
Yes power to compressor?
. To Decide if Either your compressor is broken inside or the start components are not working properly.
Parameters’ are as follows and must MUST be true before continuing:
1 Condencer coil (outside coil) Clean and open for a ir flow
2 Condensor Fan motor is running and turning at enough speed and correct direction.
3 Voltage to the compressor is correct and supplied.
4 Decide if the compressor is Hot or warm or cold to the touch for future reference.
Cold or Hot
Could it be the compressor not running or that it has overloaded?
If you suspect the compressor try to follow this to decide your next step:
These little helps allow you to get the compressor running or decide that it needs replacing
1 Ohm the compressor terminals to ground and across to each other.
A. If any read anything to ground the compressor is bad. No Need to go further.
B. If the compressor is hot and you read through some points on the compressor motor (pins or terminals) but not through others wait up to 24 hours for an internal over load to reset. Internal type, usually AC and larger Refrigeration Compressors. Smaller refrigerator type compressors have an external over load. After 24 hours off or yours has an external overload re-ohm and see if all have readings to each other. If these read open IE No resistance between each other the compressor is bad.
Results your looking for:
Your readings between the compressor terminals should all be different and you should have 1 low 1 medium and 1 high resistance reading.
Add the low and mid reading together and the sum should be close to the highest reading. If it reads say 20% more or less then retest it a couple of times to confirm your not slipping on the terminals.
After 3 or 4 tries if the results don’t add up the compressor motor is bad. Replacement is required. Is this machine worth a new compressor? Is it still under warranty? Is the labor and all parts covered?
2 Assuming the above checks out:
Get a new Start relay (start capacitor if so equipped) relay and overload (and run capacitor if it has one) In other words everything that is external and attached to the wires or terminals on the compressor, and replace them on to the compressor. Then if it starts problem solved if it still does same thing the compressor is bad (broken mechanically inside the compressor) and you have to decide to replace compressor or replace the refrigerating compressor be it AC or Refrigeration..
A few times I have gotten a compressor to start after leaving it off for 6 to 12 hours then retrying it. See the compressor unless left off for 6 to 12 hours and sometimes as long as 24 hours Is tight due to linear expansion from heat. And about 1/2 the time it is ok after new start components are installed. The other 1/2 the compressor will be ok for a day or 2 then stop again. Most likely from a “hard spot” in the movement of the internal parts in the compressor.
No Power to compressor decide if you have a thermostat or a sensor. Thermostats have a knob and a small metal tube extending into the air on the refrigerator side. An electronic controls type has a sensor and a board that require a sheet of instructions to check out.
A thermostat type is easy to check put the wires together temporary and see if the compressor starts has voltage to it then, if so replace the thermostat.
I recomend if you have an electronic board and decide to replace it replace the sensor as well.
30 years of doing refrigeration and this has not changed.
Please rate me as high as you can and ask me to clarify anything you don’t understand.
Posted on Apr 18, 2009
SOURCE: Replacement glass shelf required
Not too sure what your glass shelf looks like, but if you can't find replacements it might be easier to just get a sheet of plexiglass and glass cutting tool from a home depo (or the like) and cut it to the correct measurements. That's what I did for mine.
Posted on Jun 16, 2009
SOURCE: Samsung american style fridge/freezer needs repairing
Spray a good quantity of WD-40 on the spindle of the fan motor where it enters the motor itself. This should get the fan working smoothly with no noise. This will probably solve the other problems, as the fan prevents various components from overheating and shutting down.
Posted on Sep 20, 2009
Manual for Lamona American style Fridge/Freezer (model hja6110)
Try this link and see if this is what you need..
Sep 17, 2014 | Refrigerators
Fridge/freezer freezing up
common issue on uk samsung rsh1 american style appliances
easy cured - diy repair kits been on the market a few years now
watch this youtube video for some extra help
Jun 10, 2014 | Samsung RSH1DTMH American Style Silver 524...
Where can i find the model number on my whirlpool fridge freezer, American style?
open fridge door and pull out second from bottom draw - the sticker is on the righthand side
Jan 03, 2011 | Whirlpool Refrigerators
American fridge not getting cold in fridge part but freezen over bottom draw
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp ..The fan needs to circulat the air to prevent the freezing at the bottom.
Aug 14, 2009 | Frigidaire FRT17G4B Top Freezer...
Fridge side of American Fridge/ freezer not cooling down.
does the fridge have 2 motors or 1 if it have only 1 motor the gas level in the system are low. if it have 2 motors check if the fridge side motor runs
May 17, 2009 | Samsung Refrigerators
Apr 01, 2008 | Refrigerators
Open Questions:
Refrigerators Logo
Top Hotpoint Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Sal De
Are you a Hotpoint Refrigerator Expert? Answer questions, earn points and help others
