Question about Freezers
Cannot turn off defrost mechanism
I'm trying to turn off the defrost mechanism on my hotpoint 8232 slimline model. (the little button inside the temperature control dial). I don't have the instruction manual (It's second hand), any help please!!!
    Sergeant:
  • 340 Answers
You need to have a defrost or the freezer will not work unplugging the time clock then the compressor will not work.if it is staying in defrost their is a manual stem you have to turn.Tom
Posted on Jun 18, 2009
How is it best to defrost this as it is very clogged up with ice?
Hello Cathy,
the best way to defrost that little refrigerator is obviously turn off the unit and use a blow dryer and use it to melt the frost.
GENE
Nov 30, 2011 | Hotpoint 3.6 cu. ft. / 102 liter Upright...
Ive got an upright Whirlpool freezer that doesnt want to defrost. It takes about two weeks for the evaporater and defrost coils to totally ice up and then I have to take all the covers off and throw warm...
Fixing the defrost circuit is relatively simple. It made of three things, the defrost heater, the thermostat and the timer. The usual parts that fail are the heater and the timer. The first thing to check is the defrost timer. It looks like this:
slamfix_25.jpg It can found either near the compressor or in the little box inside that controls the temperature. What it does is that it powers the compressor for about 8 hours and then turns off the power for 45 minutes to allow the defrost heater to melt the frost buildup. The timer is run by a little motor. Often the motor stops working and the freezer is either stuck running the compressor continously or the defrost heater.
On the side of the timer is a little cam that you can turn with a straight blade screwdriver. Turn it until it clicks. When it does, the compressor should shut off and the heater should start to heat up. If you hear the crackling of ice melting, then the problem is with your timer not working. If the ice is not melting then the problem is either with the heater/thermostat. Check to see if the heater is burned out or use a meter to check continuity between the heater and the thermostat. If it is open then replace the heater and thermostat.
Any of the defrost parts should be available from an appliance supply house or online. Hope this helps you.
Jan 11, 2011 | Whirlpool 19.6 cu. ft. Commercial Freezer...
I have a hotpoint freezer which is self defrosting but its icing up and warning message keeps flashing up
There is defrost timer, that will shut off the freezer and turn on a heating element that quickly defrosts the cooling fins. then it cycles back on. If any part of that system goes out the freezer will not defrost.
Sep 21, 2010 | Hotpoint 6.92 cu. ft. / 196 liter Upright...
Hotpoint freezer, High temp light on & all food thawing
It's probably the defrost timer is getting stuck in the defrost mode. What it does it it periodically interrupts power to the compressor and sends power to the defrost coils to allow any frost on the cooling coils to melt to keep them clear of ice build up. This is typically a mechanical timer and sometimes the motor fails and it stop turning and if it fails in the defrost mode, the compressor never turns back on no matter how warm the freezer is.
You can confirm it is the timer, by tracing the wires from the compressor to a little 2 by 2 inch box which is the timer. On one side there should be a round hole with a plastic cam. You should be able to turn that cam with a flat screw driver or a coin. Just give it a slight turn until you hear a click. After you turned the cam, the compressor should start. If it does, then it is the timer.
Jun 29, 2010 | Freezers
My Upright freezer Hotpoint Product code 755703
My FZA 84 regularly has to be defrosted as it overheats.We do this by taking off the back panel - as shown by the Hotpoint service man here in Dublin. We use lukewarm water or a hairdryer to defrost the buildup of ice. Why its building up is anyones guess.The repairman suggested we might be leaving the door open but we certainly aren't. I'm very disappointed with the product and I wouldn't be purchasing Hotpoint again.
Jul 21, 2009 | Hotpoint Freezers
Deforst mechanism
you need to have a defrost or the freezer will not work unplugging the time clock then the compressor will not work. Tom
Jun 18, 2009 | Freezers
The compressor works for a few seconds but then stops. The freezer is over temperature.
Check the condenser fan motor (next to compressor) make sure it is running. Next change relay (inside black box) on compressor.
Apr 27, 2009 | Hotpoint 3.6 cu. ft. / 102 liter Upright...
Hotpoint FAZ50 Frost Free Freezer
If this is a frost free unit as I received it posted you may have a problem in that it is not frost free. The cooling coil may be frozen over stopping air circulation. There would be a defrost timer located somewhere in back. Located the clutch head screw and turn it clockwise SLOWLY until you hear one audible click. That should put the system into the defrost mode. Wait about 30 minutes in which time the system should return to the cooling mode (usually 18-22 minutes). If it does not restart the compressor after that time turn the clutch head screw clockwise again and it should restart. If you had to turn the screw the second time it would indicate a bad defrost timer. In this case replace the timer.
Jun 14, 2008 | Hotpoint 4.87 cu. ft. / 138 liter Upright...
Frigidaire Freezer Model FFU20F9FW1 defrost problems
you say when you advance the defrost timer , id assume turn it ever so slightly the machine kicks on ad begins to freeze again?? then prior to advancing timer i would expect the unit to be totally dead(stuck in defrost mode).no fans,compressor or anything. that suonds like a bad timer or chck the wires going into the timer
Mar 05, 2008 | Freezers
Freezers Logo
158 people viewed this question
Top Freezers Experts
Dennis Boxerman
Charles T Nevin
Charles T Nevin
AJMAL KHAN
Are you a Freezer Expert? Answer questions, earn points and help others
