Question about Radio Communications
The long soft bit at the back of my throat is swollen and seems to be filled with a watery blood fluid
I thought I had a large piece of flem in my throat when trying to cough it up it felt iike it was attached to something then noticed that the long bit at the back of my throat was swollen and filled fluid or blood this has been around 4 weeks now and its making me feel sick have you any idea what it can be
    Master:
  • 623 Answers
You have uvulitis. Go to a Doctor and get treated.
Posted on Nov 07, 2014
Health benefits of figs
Health benefits of Figs-
Full of fiber for digestive health.
Rich in vitamin B6 to promote a healthy brain and nervous system.
Contain potassium for a healthy heart.
Help to lower high blood pressure.
Aug 24, 2017 | Cooking
I want to no what causes swollen feet
poor blood circulation, weight problem,
talk with your doctor as there can be other more serious concerns involved and fixya site is not a medical site
Apr 22, 2017 | Televison & Video
My left leg from knee to toes swells daily at least an inch. I sleep it goes to normal
Swelling of the leg may involve a noticeable distension of the shin or calf, ankles, feet or toes. Foot swelling may be a common occurrence which most of us will experience at some point in life after a long day of standing or sitting but may also be an indication of a more serious pathology as in certain cardiovascular disorders.
Recurrent or persistent swelling of the feet should be investigated by a medical practitioner especially if you have a history of cardiovascular disease or have noticed a change in color, sensation or mobility of the leg, foot or toe.
Blood rich in oxygen and nutrients flows through the arteries to the target area. Blood carrying deoxygenated blood returns to the heart via the veins where it is quickly routed to the lungs to be replenished with oxygen.
Blood flowing to the leg has to return to the heart through a group of veins with intermittent valves located throughout the course of the vein. This venous blood (blood in the veins that is returning to the heart) has to flow against gravity and since the pressure is usually lower at the feet, other muscles of the leg assist with 'pumping' this blood back to the heart. This muscle pump is most active when we are walking and least when we are standing stationary or sitting. Blood travels short distances up the vein and backflow of blood is prevented by a series of valves in these veins.
Working alongside the blood vessels are the lymphatic vessels which return lymphatic fluid (lymph) back up the body to empty into the blood system.
Swelling of the leg usually occurs as a result of an inadequate flow of blood or lymphatic fluid back up to the torso of the body. However other localized causes may further contribute to swollen feet, ankles or toes.
Apr 20, 2017 | Knee Health & Beauty
Can I cause a bleed from my throat if my nails catch a one of the blood vessels in the back of my throat
other words can you scratch your throat if you stick your hand down it ----YES you can
Apr 17, 2017 | The Health & Beauty
I took the throat plate off to clean my Imagine serger. When I try to put bak on it has to be pushed back down and is against a small piece, seems to be too close.
THROAT PLATES ARE HELD ON EACH SIDE WITH A SMALL PIECE OF METAL (SPRING). 1. PLACE THE PLATE AT AN ANGLE OF THE THROAT. 2. AT THE SAME TIME CAREFULLY PUSH EACH SPRING UNDER THE PLATE. 3. SLIDE THE PLATE TOWARDS THE AREA WHERE THE PLATE SHOULD FALL INTO THE LOWER POSITION.
Feb 26, 2015 | Baby Lock Imagine
Fluidmaster instructions
Turn off water at valve. Drain tank. Remove fill line that goes to bottom of tank. Remove large nut from underneath tank holding in old fill/float valve assembly. Clean area around hole in tank above and below. Get large black washer from kit put onto bottom of fluid-master pipe (lip side down). Place fluid-master into hole from top of tank to check height. Top of fluid-master valve should be even or just a bit below top of tank. To adjust hold head of fluid-master and turn pipe ccw to lengthen, cw to shorten. Once adjusted put into tank. Using large flat nut in kit tighten to tank, making sure its centered in the hole, no part of the float touching the sides of the tank, and that the small nipple on the side where the small black hose will attach is facing towards the overflow pipe. Make it nice and tight, but don\'t break it.Then re attach water supply line you removed earlier, hand tight only. Place pipe clip onto top of overflow pipe (funny looking plastic clip with metal piece attached). Attach small black hose to fill valve nipple on side of valve, other side to funny clip. You may need to cut it shorter so it doesn\'t kink. Tun on water and adjust float if required. Level should be 1/2" below top of overflow pipe.
Aug 23, 2014 | Home
What is advantage of two tubes over one?
see friend .
we have two tubes .
1 one is for pumping the air so bag fills up.
2second contains the tube for telling pulse rate .
it is easy as we have systolic as well as dystolic pressure.
through two tubes we can have better reading.
Mar 27, 2009 | Welch Allyn Large Adult Two Tube Durable...
1996 Nissan Sentra Idles Roughly, Cuts Off, Engine Light Stays On
if this is an automatic there will be a dip stick if it is a manual you do not use transmission fluid to find out what sencor is bad take car to advance auto parts they have a digatal reader and can tell wou what sencer went bad and where it is located
Dec 05, 2008 | 1996 Nissan Sentra
Radio Communications Logo
99 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Are you a Radio Communication Expert? Answer questions, earn points and help others
