Question about Samsung HLP5674W 56" Rear Projection HDTV-Ready Television
The green " lamp"light blinks on & off. I have sound but no picture
  • 53 Answers
SOURCE: sound but no picture - won't stay on
you may check your lamp first. other than that i would say a faulty mains board.
Posted on Apr 23, 2009
jomabug76
  • 1148 Answers
SOURCE: Television does not have a picture. Sound goes off and on and then stays off. Lamp flickers/blinks.
CHECK ALL CONECTIONS ,,TRY A DIFFRENT ONE,,OR ANOTHER CHANNEL
Posted on May 15, 2009
video-tek
  • 150 Answers
SOURCE: just changed the lamp in my samsung 4663w. lamp
hi, leaves only 3 options
1. color wheel not coming up to 6000 rpm`s
2. no ballast strike to lamp
3. lamp door safety switch in wrong position when door was re-attatched.
highly unlikely but not impossible u got a defective lamp, did your old lamp still come on? if so put it back in, if it lights up new lamp is bad, my money is on the color wheel if you installed lamp door correctly, gl, video-tek
Posted on Jun 05, 2009
Mr_Wizardtex
  • 205 Answers
SOURCE: dlp has no picture only flickering lamp & timer lights.
Verify color wheel is reconnected, color wheel needs to get up to speed before lamp strikes
Posted on Jun 28, 2009
ladywinn
  • 5138 Answers
SOURCE: Samsung 50
Loud sound you are hearing is coming from your color wheel and has your Lamp ever been replaced? this set has 3 Fans they all must be running for set to operate correctly! Encompass Parts has Boards and Color Wheel But for Lamps Mats has them for 99.00 1-800-628-1118 and EC Parts 1-800-638-3328
Posted on Jan 21, 2010
I have a sony kdf 50e-2000 the green light goes on then it goes to thr red blinking lamp light. I have no sound or picture. If I replace the lamp light will I get sound and a picture again?
Yes, if you have not replaced the lamp since you purchased this TV.
Lamps usually last about 6000 hours.
I've seen lamps last much longer than 6000Hrs, it all depends on the usage.
Remove the lamp from the TV and do a visual inspection, see if there's a crack on the glass or the bulb.
If the TV is few years old then the Lamp may be bad.
For a new Lamp: 800 638-3328
https://www.encompassparts.com/
DO NOT BUY the lamp from ebay
Good luck to you.
Nour Sabre
www.tvservice.com
May 24, 2012 | Sony KDF-50E2000 50" HDTV
Replaced lamp but lamp light still blinks orange
I have a wd-57731 The lamp light blinked orange. i replaced the lamp turned the tv on and the timer blinks green for one minute and then the lamp light blinks orange again. It won't turn on. Can you suggest anything?
Nov 22, 2011 | Mitsubishi WD-57731 57" Projection HDTV
Red/green lights both blink and tv will on turn on
Are the red and green lights blinking at the same rate or not? If the green light is blinking every 3 seconds and the red light is blinking every 1/2 second, the lamp door is not properly secured. If both lights are blinking at 1 second intervals, try replacing the lamp. If a new lamp doesn't solve the problem, the TV needs service.
I hope this helps.
Jun 23, 2011 | Toshiba 52HM95 52" HDTV Projection...
Lamp went out & replaced it but no picture. Sound comes on!!!
you have a safty switch open most likely on the door you took off to replace lamp
Feb 03, 2010 | Toshiba 62HM95 62" DLP HDTV
Green Power light blinks for about 60 secs, then
YES New lamp needed the model number will be on old one does not take long to change if still got hand book shows how change
Nov 07, 2009 | Sony Grand WEGA KDF-50WE655 50" Rear...
Picture and sound shut off, blinking green standby
MY SONY PROJECTION TV WENT BLANK WITH NO SOUND GREEN LIGHT WAS ON WHATS WRONG
Oct 14, 2009 | Sony Grand WEGA KDF-55WF655 36" Rear...
XL 5200 bulb replace and NO Picture or Sound
3 times blink error code shows Lamp Door is not seated / fixed properly, please recheck it and make sure that door close safety switch is pressed as this switch sends error signal to system control chip.
May 30, 2009 | Sony KDS55A2000 55" HDTV
SONY KDF-E55A20 5 red blinking lights on power button
Symptom shows Lamp is weak in result and causing restart of TV again and again. Your TV requires new lamp as per following part number...
A1085447A* LAMP BLOCK ASSY XL-2200U
It is available in Sony Accessories Store for $200 and replacement procedure is written in instruction manual of TV.
Always buy Sony original lamp for TV and avoid aftermarket / cheap lamp for TV safety.
May 18, 2009 | Sony KV-36FV26 TV
Samsung HLP5674W 56" Rear Projection HDTV-Ready Television Logo
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
