Question about Philips 42PF7320 42 in. EDTV-Ready Plasma Television
My 42pf7320/10 tv,cannot get no picture ,jus sound ,av leads good ,pls help
    President:
  • 563 Answers
I have over 10 years experience in electronic tech support.
I know this isn't what you want to hear, but the problem you've described can't be fixed with troubleshooting. Your TV will have to be repaired. There is a part that has developed a defect and needs to be replaced. If you're still in warranty, the TV will be repaired at no charge to you. The warranty would likely be at least one year from the date of purchase from the manufacturer. If you purchased an extended service plan they will repair the TV at no charge as well.
If the TV is no longer in warranty, the repair will likely cost a minimum of $300 parts and labor. This is assuming that you only need one circuit board or the board itself can be repaired at the component level. If the problem requires more than one of the video circuit boards to solve, the price of repair could go much higher.
I hope I've provided you useful assistance and that this information allows you to make an informed decision as to how to proceed from here. Please be sure to vote on my response. I hope I've earned a good rating from you today.
Please let me know if I can be of further assistance.
Posted on Jun 18, 2009
I have a samsung smart tv, i hook the hdml and usb to tv and other end to cellphone, beautiful picture no sound, all is good but no sound. Pls help.
Hi the usb and hdmi will not transmit sound due to the fact that some micro HDMI do not transmit sounds.
Your best option is t go out and buy a new male to male audio jack that has AV on the one side and a audio jack on the other side.
plug it into you tv audio in, and then into you phone
Feb 08, 2016 | Samsung Televison & Video
When xbox is pluged in you can hear the sound but no picture is showing
Try jiggling/ twisting around the yellow av cord lead. I have the same problem with mine but you just need to spin the yellow av lead around untill you get a picture. If you still cannot see the xbox screen then i recomend you try on another T.V as it might be the av imput is not working. =]
Nov 07, 2010 | Microsoft Xbox 360 Console
My Samsung TV picture is supplied via a HDMI lead
yes you need to connect audio out from the tv to audio in on the dvd surround. you need the red/white phono to phono leads, simply connect together and select audio (av,au) on the input selection.
Feb 20, 2010 | Samsung LN46A650 46 in. LCD HDTV
Hi I have a Philips 32inch ambilight TV about
No a lot of HDMI does NOT send the sound signal through the HDMI cable & must be run AV to AV, the RED WHITE & YELLOW plugs Color to color for RED & WHITE, the YELLOW is Composite Video. . The SCART should indeed have it "All in one" however that signal is only RGB, or Composite Video, a lower quality, than HDMI. Just use HDMI & AV. you'll be all good.
Feb 06, 2010 | Televison & Video
How do I conenct player to tv
  1. Yellow wire is picture and the 2 red is sound
at the dvd player plug in the picture wire by av out, at the tv plug the yellow wire in av in.
The sound is the same sound out at the dvd player look for a L R this means left and right at the tv there should under av in next to the picture wire you pluge the soun in
hope this is clear to you
Jan 04, 2009 | RCA DRC220N DVD Player
Has sound but no video picture for game playing
try changing the av to another channel or if you have access to a front panel or side panel on the tv set, try using this for your av leads 'red' 'yellow' and 'white'. Also check that the av lead is correctly inserted into the back of the wii
Oct 25, 2008 | Nintendo Wii Console
DVD in, have sound but no picture???
Initially, a couple of ideas:
  • check the cables from the DVD to the VHS to the TV (I am assuming that the sound is likewise connected to the TV and not to a home receiver system or an amplifier);
  • I am assuming again that you are using RCA and not RF, if yes pls pay special attention to the yellow RCA on both the DVD to VHS and VHS to TV;
  • diagonal roll often indicates a loose ground or a defective cable/RCA connector;
  • verify settings/configurations in all three; DVD, VHS, TV. TV should be set to AV or Video, VHS likewise to A/V INput;
  • try playing a known good VHS tape, if normal playback, problem is between DVD and VHS, if likewise no video, problem is between VHS and TV.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Sep 13, 2008 | KLH DVD8350 DVD Player
Bad connection?
Cant get picture, sound working. new cables has 5 plugs
Feb 23, 2008 | Microsoft Xbox 360 Console
Pls more info; what do you mean tv on, picture froze? you are watching on tv chanel, do you use cable? I can help you but need more details.
Aug 29, 2007 | JVC AV-32D305 32" TV
JVC AV-28GT1SJF
you have to get into the tv to do the adjustment. take the cover off and then look for the CRT tube and follow the yoke cables that will lead you to the printed circuit. you should see some small tiny knobs there. something like vertical phase or horizantl Phase..you need the verital to adjust the vertical size of the pic..good luck
Feb 24, 2007 | JVC AV-28-BD-5-Bl 28" TV
Philips 42PF7320 42 in. EDTV-Ready Plasma Television Logo
689 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
