Question about Lands Phones
Commander NT40 Telephone problem
Cannot get one handset to ring when receiving incoming calls. Have cancelled all Do Not Disturb and Call Forwarding codes. Rings when called from other internal extensions, however nothing when external lines are calling.
Another handset will not hang up when returned into receptor, forcing user to press the End Call key manually each time. Causes problems when other people use this phone and don't know to do this, walk away and have the line open all day until someone else realises this has occurred. Same handset won't allow Handsfree function either. Must pickup handset to hear anything.
Have a manual from original installation tech which is not worth the paper used to print it on. Other companies charge or manuals that may not even help with these problems, and tech has advised he is happy to make service call, which I am not happy to pay for if the matter can easily be resolved by programming a few numbers.
Please help!
  • 43 Answers
SOURCE: Internal Call "Voice Call" and does not ring
You can toggle each individual phone extension as to whether or not it recieves a "voice" call or a "ring-first" call.
At the extension, press "SPEAKER - 60" it will display the mode. Press the * (asterick) key to toggle between the modes. Then press SPEAKER again to set.
Posted on Feb 12, 2008
cnavarro
  • 2460 Answers
SOURCE: Incoming Call not Ringing
Either call line 3 first, or make your phone ring :-)
What might be the easiest is to swap modular plugs in the back room between 2 and 5. That way, you get your old extension back and everything will work as it did.
If you can't do that, then you're going to have to do some system programming to turn on the ringing on your phone. If you have a TA series system, you should be able to do it from either the PC or a phone connected to jack $1. If you have another model, you should have a system manual on how do make programming changes.
Carl
Posted on Sep 04, 2008
  • 13 Answers
SOURCE: Can't answer direct line calls
This sounds like a programming issue on this telephone. There are 2 areas in programming that would cause this. If you have recently had a technician out to do some programming then it is possible that he made a mistake and needs to be called back to correct his mistake.
Posted on Dec 08, 2008
SOURCE: Incoming calls only ring once then hangs up. Can call out/not in
reset your mobile
Posted on Jan 29, 2010
  • 825 Answers
SOURCE: NEC Dterm80 phone, Model DTH-16D-2.
You can change these settings by logging into the phone's ip address from the computer that is connected to the same network.
You can also try to enter into the menu of the phone directly from the interface and look for these settings..
Posted on Apr 22, 2011
How can I setup forward call to my cel from VTECH CS6649-2
Call forwarding typically can redirect incoming calls to any other domestic telephone number, but the owner of the forwarded line must pay any toll charges for forwarded calls. Call forwarding is often enabled by dialing *72 followed by the telephone number to which calls should be forwarded. Once someone answers, call forwarding is in effect. If no one answers or the line is busy, the dialing sequence must be repeated to effect call forwarding. Call forwarding is disabled by dialing *73. This feature requires a subscription from the telephone company. Also available in some areas is Remote Access to call forwarding, which permit the control over call forwarding from telephones other than the subscriber's telephone. VOIP and cable telephone systems also often allow call forwarding to be set up and directed via their web portals. https://en.wikipedia.org/wiki/Call_forwarding
Jul 14, 2015 | Vtech CS6649-2 Digital Answering System,...
The intercom on my AT&T MLS-12 will not ring when called.
Your ringer volume may be down or you may have call forwarding or do-not-disturb active. Try adjusting the volume button while not making a call (with the handset on hook). check if any button indicator lights are active on the phone such as call forward or do no disturb.
Jan 08, 2015 | ATT - Avaya - Lucent AT&T Partner MLS-12...
Call foward
Actually it's your telephone company forwarding the calls. With many phone companies, you dial *73 on your home phone to cancel the call forwarding. If that doesn't do it, contact your telephone company for their instructions regarding call forwarding.
Nov 22, 2013 | Uniden DECT 6.0 Cordless Telephone...
Panasonic KX-T7730, we have a 824 phone system and cordless handsets (kx-tg1711) we cannot make outgoing calls on these handests but can take incoming calls and can transfer calls. how do we programme
  • Locate the program and auto-store button on your telephone. You will be using these to customize many of the features on your KX-T7730. The program button is used to enter or exit programming.
  • 2
    Program your outgoing line preference, i.e., the line you prefer to seize when you go off hook. Press "Program" "1" "1" "store" for no line. Press "Program" "1" "2" "Store" for an idle outside line. Press "Program" "1" "3" "Outside Line Number" "Store" for an assigned outside line. The outside line number will be a single or double-digit number that is set through your phone system.
  • 3
    Program your incoming line preference, i.e., the line you prefer to answer when you go off hook. Press "Program" "2" "1 "Store" for no line. Press "Program "2" "2" "Store" for ringing line. Press "Program" "3" "Outside Line Number" "Store" for an assigned outside line.
  • 4
    Program your flexible CO buttons. These are the inner row of 12 lighted buttons. Your outside lines need to be programmed to these--you can choose any of these 12 buttons in any order. Press "Program" "CO Button" "0" "Outside Line Number" "Store." The outside line number will be a single or double-digit number that is set through your phone system.
  • 5
    Program any other unused flexible CO buttons for an extension number or any frequently dialed phone number. Press "Program" "CO button" "1" "Extension Number" "Store" or "Program" "CO Button" "2" "9 + Phone Number" "Store". A "9" must be entered at the beginning of a phone number to tell your phone system to seize an outside line before dialing, e.g., "9-1-212-555-1234."
  • 6
    Locate the programmable feature buttons (the row of 12 solid buttons on the right). These buttons are basically one-touch buttons that can be set for extension numbers or phone numbers. Press "Program" "(PF) Button" "Extension Number" "Store" or "Program" "(PF) Button" "9 + Phone Number" "Store." Remember to press "Program" again to exit programming.
  • 7
    Locate your "FWD/DND" button. This button is used for setting "Call Forward" or "Do Not Disturb" on your telephone. To set call forwarding, go "off-hook" either by lifting the receiver or pressing speakerphone. Make sure you go to intercom and not an outside line. To forward all calls, go off-hook, press "FWD/DND" "1" "extension number" (the extension number that you wish to forward all your calls to) "#". After you hear a confirmation tone, place the receiver on-hook. The steps to set call forwarding for busy/no answer are the same as above, except you will press "2" in place of "1". To cancel call forwarding, press "0" in place of "1".
  • 8
    Program "Do Not Disturb," which stops your phone from ringing--any callers will just hear a DND tone. To program, go off-hook, press "Program" "4" "#" on-hook, to set. Press "0" instead of "4" to cancel.
  • 9
    Locate the message button--this works in coordination with your message light at the top right of your telephone. If the light is lit, press "message" to hear a message left to you either by another extension or a voice mail system. The message button can only be programmed as a message or one-touch button. To program as a message, press "Program" "Message" "3" "Store." To program as a one-touch, press "Program" "Message" "1" "Extension Number" or "Program" "Message: "2" "9 + phone number."
  • 10
    Return your KX-T7730 to its default settings by pressing "Program" "#" "*" "Store."
  • Read more: How to Program a Panasonic KX T7730 ' eHow.com http://www.ehow.com/how_7159736_program-panasonic-kx-t7730.html#ixzz1eYPzbevZ
    Nov 23, 2011 | Panasonic KX-T7730 Corded Phone
    How do I program the phone to ring on an incoming call? The ringer is on.
    The solution will depend on why the phone is not ringing. Do you have a good cable? (Can you get a dial tone and make outgoing phone calls?) If you don't have a dial tone, use another phone to check if the phone is the problem or if the jack is at fault.
    Next is the phone forwarding calls or in the "do not disturb" mode.
    If the problem is one of the above, which model of the Main Unit do you have, KX-TA624 or KX-TA1232?
    If the unit is in the "do not disturb" mode, to cancel: pick up the handset, press Program then 0 followed by # with the TA624. For the other model, press Program followed by 0 . Then hang up the handset. For this the manual says press the FWD/DND button not the Program button. I'd check both.
    To cancel Forwarding, except for Follow Me Forwarding, pick up the handset, press FWD/DND and then 0 and # (TA624) or 0 (TA1232) then hang up the handset. To cancel Follow Me Forwarding: pick up the handset, press FWD/DND then 8 followed by the extension number. Then press # for the TA624 and hang up; just hang up the handset for the TA-1232.
    I hope this helps.
    Sep 23, 2010 | Panasonic KX-T7730 Corded Phone
    I'm able to make calls but can't receive incoming calls, the phone doesn't ring! I'm not an idiot, I've turned the volume up high, no call forwarding on, etc etc etc... it just doesn't ring
    one of two things. A problem with the phone or a problem in the telephone lines. Call your phone service provider and ask them to run a test on the line. If the test shows a problem they will likely dispatch out a technician to repair the problem. This is a common problem usually stemming from a ground on the ring side of your cable pair. I'd check with a corded phone at your telephone interface first because if it's an equipment or inside wiring problem the phone company will likely charge you for dispatching out a technician.
    Aug 28, 2009 | Uniden DECT 6.0 Cordless Telephone...
    Mitel 5212 no dial tone and goes straight to voicemail
    Not too sure about the no dial tone issue, but you can check to see if the DND is turned on...
    Press the Blue Superkey and scroll thru till you see DND (Do Not Disturb) is on and shut it off.
    Jul 20, 2009 | Mitel 5212 IP Phone
    Canon MP530 receive fax issues
    Receive Mode Settings Select from the following receive mode options to suit your needs. Once you've decided on which receive mode to use, follow the below instructions to set the receive mode using the operation panel. Receive Mode Setting
    1. Press the <FAX> button to enter Fax mode.
    2. Press <Menu>.
    3. Press the right or left arrow button to select [Receive mode settings], then press the <OK> button.
    4. Press the up or down arrow to select the receive mode that best suits your needs, then press <OK>.
    Types of receive mode
    Select the receive mode according to your needs.
    Receive mode
    Purpose
    FAX/TEL AUTO SW When you want to receive faxes automatically as well as voice calls. FAX ONLY MODE When you want to receive only faxes automatically with your machine, or have a dedicated telephone line for FAX use only. DRPD When you have subscribed to a DRPD service with your telephone company. MANUAL MODE When you receive mainly voice calls and sometimes faxes, or want to receive faxes manually. ANS.MACHINE MODE When you want to receive voice messages on your answering machine and receive faxes automatically. FAX/TEL auto switch
    FAX :
    The machine does not ring but will receive the fax automatically. Voice call :
    The phone attached to the machine will ring. Pick up the handset to answer the call. Note:
    • Ring start timing and Telephone ring length can be specified in FAX/TEL auto switch in the Receive mode settings.
    • If you want the telephone to ring when it receives a fax, connect a telephone to your machine and enable the Incoming ring settings in RX settings.
    • The phone attached to the machine may not ring depending on the telephone type you are using.
    FAX only
    FAX * :
    The telephone does not ring. The machine will receive the fax automatically. Voice call :
    You will not be able to answer the call. * If you want the telephone to ring, connect the telephone to your machine and enable the Incoming ring settings in RX settings menu.
    DRPD
    FAX :
    Your telephone line will ring according to the ring pattern you have chosen and receive the fax automatically. Voice call :
    Your telephone line will ring according to the ring pattern you have chosen. Pick up the handset to answer the call. Note: Specify the FAX pattern in the DRPD: Set FAX ring pat. in RX settings menu.
    Manual RX
    FAX :
    The telephone attached to the machine will ring. Pick up the handset and if you hear a beep tone, press the <Color> or <Black> button on the machine to receive the fax. Voice call :
    The telephone attached to the machine will ring. Pick up the handset to answer the call. Note: If you are far from your machine, you can use the remote receiving function to receive faxes. Pick up the handset of the telephone connected to the machine and press 25 (the remote receiving ID).
    Ans. machine connect
    FAX :
    First the answering machine connected to your machine will respond to an incoming call, and then the machine will receive faxes automatically. Voice call :
    The answering machine connected to your machine will respond to an incoming call. Note:
    • Set the answering machine to answer on the first or second ring.
    • The entire message should be no longer than 15
    Nov 24, 2008 | Canon PIXMA MP530 All-In-One InkJet...
    Lands Phones Logo
    455 people viewed this question
    Top Lands Phones Experts
    Marvin
    Marvin
    David Burbee
    David Burbee
    Are you a Lands Phone Expert? Answer questions, earn points and help others
