Question about Biostar G31-M7 TE Motherboard
Motherboard not reconsiged usb - Biostar G31-M7 TE Motherboard
Hello! my problem is that my two USB ports is blown. Now I want to connect more USB port on the motherboard via cable, but none matches the port that the USB or sb_link, jp1... Can you tell me which port...
You will need to get a usb expansion card. These can be found at Best Buy, Newegg.com, tigerdirect.com, pc-connection.com etc...
Some manufactures ship with newer motherboards a usb expansion slot using the motherboard jumper configuration but your motherboard must first be able to support this type of expansion.
I recommend the pci usb expansion. They plug into your PCI slot and give you 2-4 extra USB slots in the back of your computer.
Mar 01, 2011 | Quadrant Slot 1 QM-6VABX2 (QM-6VABX2-1664)...
Where do I plug the 2.0 USB on the board
you have a USB 2.0 enabled motherboard or USB 2.0 pci card? if you are plugging into motherboard and windows says that the device is not plugged into a USB 2.0 port, your motherboard does not support USB 2.0, and you need a USB 2.0 pci card. (try plugging into the rear USB 2.0 ports if you are plugging in the front) Hope this helps! Max
Feb 10, 2011 | Computers & Internet
P4p800 se motherboard. usb doesn't work
you can purchase add-on p[ci usb cards for around $25 at a store such as best buy or online.
May 24, 2010 | ASUS P4P800 SE (890552603657) Motherboard
Find the correct connections on motherboard for usb ports
frist you have some port of usb on front pannel of cpu . connect the wire of usb . u can plug the usb card from on board pci slot then you need to enable your usb in bios
Apr 10, 2010 | EliteGroup K7S5A Pro Motherboard
Why does the keyboard not work when I start up motherboard. all devices and memory are found but then asks to press F1 or DEL but keyboards (usb and ps2) aren't working :( Motherboard is ABIT KN8 Ultra
Hello
Try this.
Unplug usb key board.start pc.plug usb keyboard in.should work.
Try reinstalling usb drivers or chipset drivers for motherboard if above does not work.
Feb 05, 2010 | Abit KN8 Ultra Motherboard
Problem with USB port on Asus P5KPL-AM SE Motherboard
Older motherboards have USB 1.1 ports;
newer motherboards have USB 2.0 ports,
which are over 10 times as fast.
It is Windows (not your motherboard) that should do the "Plug-and-Play" thing for devices connected to your USB port(s).
Note that some devices are USB 2.0, and will *NOT* work when plugged-in to a USB 1.1 port.
Either get a newer motherboard, or get a PCI add-on card that adds USB 2.0 ports.
Sep 10, 2009 | ASUS P5KPL-AM SE Motherboard
P4 Titan GA-8ST800 Motherboard USB Power Failure
You can also install a PCI USB add-on card in your machine, that will give you more usb port, it happens a lot that the usb's fail on a motherboard, there is no fuse to reset them...soryy
Hope this is helpfull...Good luck
Cheers
Techmor
Jun 18, 2009 | Gigabyte GA-8ST800 Motherboard
Usb
Please check the other two USB panel, it may be dedicated or worked properly with lower versions of USB devises(v.1). Check BIOS also if necessary and USB voltage in your motherboard but please refer your motherboard manual. Hope this helps.
May 28, 2008 | Albatron KX18DS Pro Motherboard
USB device problem
Fiend your solution direct from mercury. Here is your solution.....
http://www.mercury.com/motherboard/prob676ijt65/solution
aamknr-2
Mar 20, 2008 | Mercury P4VM800M7 Motherboard
Usb fault
Did you run the motherboard cd? The usb drivers are on it. Also, make sure they are enabled intthe BIOS.
Please let me know how this works for you.
thanks
Feb 08, 2008 | Gigabyte GA-965P-DS3 (0818313003027)...
Biostar G31-M7 TE Motherboard Logo
26 people viewed this question
Top Biostar Computers & Internet Experts
Jayburt
David
David
Jerry Umali
Are you a Biostar Computer and Internet Expert? Answer questions, earn points and help others
