Question about Mushkin Atlas mSATA 240GB SATA III Internal Solid State Drive SSD, TRIM Suppor
Format Mushkin Atlas mSata 240gb
How do you get theis drive recognised and formatted
SSD installs but does not show in "Computer"
if its new, you may need to format it (external disk i mean)
go to disk management under computer management under administrative tools in control panel. you should see all disks there, the one you want may be 100% unallocated space, put new partition over entire disk and so on...
Sep 07, 2014 | PNY 240GB OPTIMA SSD SATAIII 2.5IN 7MM...
Remove password from msata ssd
You cannot until the password is typed in correctly. The hdd will not even format!
Feb 02, 2014 | Dell Ultrathin Xps 13 L321x I7-2637m...
I have a 1tb Buffalo HD-PCU2 ministation. I want it formatted as Fat 32 to use on my Humax recorder but Windows vista or 7 don't recognise it? Is it fixable?
FYI: fay32 doesn't support files larger than 2GB so if your putting movies than do NTFS.
To format as FAT32 you have to open an command prompt as admin. Window Button > All Programs > Accessories > Right CLICK command prompt and run as admin.
<VOL> = your drive letter ex E:
Command to format as FAT32
format <VOL> /FS:FAT32 /X
Dec 22, 2012 | Computers & Internet
My glyph harddrive dont show up on my mac why?
If the hard drive was formatted on a PC computer in NTFS file format then the MAC will not recognise this hard drive.
If you want to transfer data between the PC and MAC then you need to format the hard drive with a PC in FAT32 file format. The MAC can read and write to a FAT32 formatted hard drive
Aug 08, 2012 | Glyph GT 050Q Hard Drive
I have the Iomega model GDHDU 2 and I want to reformat it from being formatted for a mac to being formatted for windows. I purchased it because it is compatible with Mac and PC. I already managed to...
this should just be a matter od plugging in the drive, if recognised, right click on the drive icon and format to ntfs.
If not recognised. Control Panel / Admin tools/ computer management / storage/ disc management.
Locate the drive (which will appear unallocated) right mouse click on it, then new simple volume and format
Jan 25, 2011 | Iomega (33600) 160 GB USB 2.0 Hard Drive
Hiiii i lost ma manual for sony handycam..model no. hdrxr 520v..240gb hdd.. its internal memory is 17mb so its just recording 41sec video...wat abt the hdd... which can record upto 96hrs..
Here is the main support page for your camera:
http://esupport.sony.com/US/perl/model-home.pl?mdl=HDRXR520V&LOC=3
There are several links including the Handycam Handbook. You might want to try formatting your HDD. Make sure there is nothing on it that you want because formatting will delete everything. Instructions for formatting are on page 72 of the handbook.
Thanks for using Fixya.
Dec 28, 2009 | Sony Video Cameras
Maxtor SCSI 36GB hard disk drive was removed from
if you are using raid go into the perc hardware utlity as it boots,try formating the drive there.maybe this will work.If you are using the dell open manage software you can probably format it there in windows.If you are not using raid enter the scsi utlity and do a format there.
Good luck
Sep 09, 2009 | Maxtor Atlas 10K III 73.4 GB SCSI Ultra320...
External hard drive not recognised on my ps3??
Ok. Well this is easy! your hard drive is formatted in NTFS, ps3 wont recognize that. it needs to be fat32 find an XP machine not a vista machine.
download Swiss Army Knife and format the drive in fat32. you will loose ALL information in your external. you will need to back up anything you want to save and put it back after the format.
good luck!
Feb 09, 2009 | Maxtor Hard Drive
Seagate Barracuda 7200.7 160GB
You don' t say what OS or even type of computer (PC, Mac, Windows XP, 98, vista etc) you are running, or whether the drive has been used before. If it's a new drive then it probably needs formatting, so you can allow the OS to do that. If it contains data that you need then DO NOT allow the OS to format it.
If you know it is formatted & contains data, then it sounds like the OS is not recognising the format. Windows 98 typically won't recognise NTFS disks formatted on Windows XP for example or Linux Ext3/4 format disks won't be recognised by Windows. In the latter case, you can download a free driver which will do that for you - google Ext 4 and Windows.
Aug 26, 2008 | Seagate Barracuda 7200.7 160GB 7200rpm...
Mushkin Atlas mSATA 240GB SATA III Internal Solid State Drive SSD, TRIM Suppor Logo
Top Mushkin Computers & Internet Experts
David Payne
David Payne
Are you a Mushkin Computer and Internet Expert? Answer questions, earn points and help others
