Question about Maxtor Personal Storage 3200 (U01E200) 200 GB Hard Drive
Solid green light.
Bought the drive, reformatted it for my mac - worked fine.
Then, suddenly, nothing. The light, when inactive was dim, stayed bright (is if drive were in use). After a few days, the problem fixed itself.
Now, the problem is back. I'm looking for a way to fix it, so I can remove my files from the drive and replace it with a better, more reliable model.
The Drive shows up in system profile.
Any suggestions?
Re: solid green light.
Disk Warrior.  I had a similar problem and it worked like voodoo.  Plus, a) you can download it direct from the company and b) if it can't fix it it won't screw it up any further.
Posted on Dec 31, 2007
0 characters
3 Points
Rocstor pro 850 doesn't show up on mac desktop
Did you use this drive on the Mac previously? I've had problems with some drives formatted under windows that were not seen on the Mac.
If you previously used it on a windows machine you may have to reformat it with the Mac.
Hopefully, You still have a Windows machine available to you. First Place the data on the drive onto a Windows machine. Reformat the drive on your Mac. Copy the information back on the drive. It should now work for you.
Nov 07, 2014 | Rocstor Rocpro 850 2TB eSATA/USB...
My hard drive is not recognized in my mac. The light is blue, neve turns to green
Have you tried to connect the drive to a different computer? You can also try to open Disk Utility (use spotlight search to find it). My guess is it doesn't show up there which means there is a problem with the Buffalo device. The disk is most likely fine, just the Buffalo casing needs to be replaced.
Apr 23, 2014 | Buffalo Technology Buffalo 1TB MiniStation...
PC won't see my glyph drive after I have installed Mac Drive 8
Take it back to where you bought it, and exercise the warranty, to get it replaced or repaired.
May 07, 2010 | Glyph GT 050Q Hard Drive
My mac G4 not recognize my 500GB external FantomDrive. HD light is on but Mac can't see it!
If you bought it from a friend, then ask them to reformat it for you as a FAT32 partition. Mac can not see NTFS, which most Windows users use since you get more space on the drive.
If it is brand new and your G4 isn't recognizing it, then I would return it for a new one. I don't trust things that aren't working out of the box, especially when they charge so much for things.
Dec 16, 2009 | Fantom Titanium II (TFD500C16) 500 GB USB...
I cannot copy files FROM my Western Digital 500GB
Check the file system of your hard drive. If your PC is recognizing it, check if its a FAT or NTFS. If it is NTFS then you have to reformat it using your Mac and choose FAT. Mac OS recognizes NTFS as a read only drive. If you plan using it with your PC and MAC you should format it using your mac and choose MS-DOS in disc Utility. You cannot format the drive using your PC Computer with a FAT file system because of the capacity. Only Mac can format it with a FAT file system.
Aug 23, 2009 | Western Digital My Book Essential 500GB...
LaCie BIG HD suddenly invisible to my Mac
from the description either th drive or the 1394 logic board has failed. Try having the technicians at you local PC shop swap the actual hard drive from the Lacie enclosure into a new enclosure and test it. If it works, buy the enclosure and you're back in business, if it oesn't and you need the data on the drive comment back with your Country, State & City and I'll refer you to a good Data recovery specialist in your region.
Hop this helps FixYa,
Jun 27, 2009 | LaCie Big Disk Extreme with Triple...
DaneElec 4GB suddenly stops working?!
Hello, Likely the saulders on the circuit board are broken. If you are very skillfull and own a fine tipped sauldering device it's possible to repair it yourself although not highly advisable. If you'd prefer to have a pro look at it for you, just comment back with your region(country and city) and I will recommend an appropriate facility. Chris
Jun 04, 2009 | Dane-Elec DaneElec 4GB USB Drive Copper...
Spinning, then nothing
hate to have bad news, but it's sounding like the drive may have gone bad...the restarts prior were warnings that it was on the way out... I would make sure you've got another drive, hook them both up and if you power up the suspect drive, you may get lucky enough to boot it up for a short while and maybe long enough to transfer some files to the newer drive.... good luck... Also, be sure that all your computer and periferals are connected to power via a power surge protection device... I've lost a few tv's and printers becuase I was too lazy or in too big a hurry...then a voltage spike trashed my stuff... Hope this helps..
May 08, 2009 | LaCie Hard Disk 1TB Desktop with Hi-Speed...
Maxtor Personal Storage 3200 (U01E200) 200 GB Hard Drive Logo
222 people viewed this question
Top Maxtor Hard Drives Experts
Brian Sullivan
Brian Sullivan
Mark Taylor
Mark Taylor
Are you a Maxtor Hard Drive Expert? Answer questions, earn points and help others
