Question about LG WFT1071TP Top Load Washer
LG Top Loader will not turn on
Worked perfectly, now will not switch on
    New Friend:
    Problem Solver:
  • 15 Answers
Did you check power connection?...if power is there we have to check main PCB Power piuse,,,,
Posted on Apr 23, 2014
The door on my lg washing machine will not open even when indicator light goes out
top loader or front loader
faulty door lock safety switch
unplug from wall .. if no luck
going to have to force it and replace the damaged parts
Jan 22, 2017 | LG Washing Machines
Where is the door latch located on the LG top loader washer turbo drum model T6755pp
How to Troubleshoot a DE Code for an LG Washer ' eHow
www.ehow.com > Home & Garden
Although sometimes the only way to correct the DE error is to hire a professional to check and fix the washer, there are a few at-home troubleshooting efforts you .
Aug 05, 2015 | LG Washing Machines
Where can you find the presure switch lg wf- t1233TP
where can I find a display board for my lg wf-t1233tp top loader washing machine
Jul 04, 2012 | LG WFT1071TP Top Load Washer
Require an owners manual for L G -H950 top loader
Do you mean the LG WT-H950 top loader? LG' s Australia site had the manual for the washer on their support site: http://www.lg.com/au/laundry-floorcare-appliances/washing-machines/LG-top-loader-washing-machine-WT-H950.jsp . Click on the Support tab and the link to the PDF of the manual is on the right hand side of the page.
I hope this helps. If you have a different washing machine, please add a comment with the full model number.
Feb 28, 2012 | LG Washing Machines
I have an NEC nwtl656 top loader. It will not perform any function as every attempt at choosing a wash setting results in it sounding a beep and flashing all lights on the panel. No washing settings make...
Hi Mark, my friend has one of these machines and we had troubles like that, in the end i found out the "out of balance switch" was a little sticky. You find the switch by opening the back panel and it is lockated on the right side in the top corner. I flicked the switch a few times to hear the klick-klack, and that was it. Turned it on and it worked perfectly. Maybe it helps, good luck. Hebie
May 05, 2011 | Washing Machines
I have a brand new LG 8KG top loader washing machine
Thank you for coming back to me, yes I have had the problem solved today. A technician came around to my home and made a slight adjustment to the Lid and said it should never give me trouble again. It was a free service as my washing machine was brand new and it started up perfectly and went through it's full cycle with no hicups!
Many thanks,
Billie. South Africa. ( Durban)
Jan 04, 2009 | LG WFT1071TP Top Load Washer
When I turn on LG 1888H dvd recorder, it just says please wait but nothing happens. Can it be a HD problem?
Your DVD loader (DVD player) has some kind of malfunction. (dirty lens, bad build, etc...)
Just stick a new PC IDE DVD player in it and it will start working. I had the same problem.
I used a lite on made in 2004 and the RH1888 works prefect, but does not look perfect. The drive is won't work in conjunction with a it's original face panel.
I blue tacked the display on the top of the chassis, and got the big ol' lite-on drive sticking out front, but it works perfectly.
Good Luck!
-Pro Hack
Apr 29, 2008 | LG Televison & Video
Help i can't wash and have no manual and have a hairdressers shop
the switch is faulty that is supposed to engage when lid is closed .replace switch under lid.close Ireland bye bye
Nov 23, 2007 | Washing Machines
LE code on LG front loader
Switch off machine, unplug, turn the heat setting on the water down. Plug it back in and select your wash setting. Good luck.
Apr 16, 2007 | LG WM-2277HW Front Load Washer
LG WFT1071TP Top Load Washer Logo
Top LG Washing Machines Experts
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
