Question about Sony Televison & Video
My sony strde725 says pcm, the light used to say digital optical.
I ran a digital optical cable from my tv to my receiver not there is no blue light and it says stereo pcm, it used to be blue and say digital optical
  • 1 more comment
  • dave2085 Apr 15, 2014
    I had the tv connected to the hopper via hdmi and from the hopper to my sony receiver via digital optical cable. I bought a blueray that only has hdmi so that is conneted it to the tv via hdmi as well. The light on my receiver used to be blue and say (digital optical 3/2) now that I ran the optical from my tv to the sony receiver it says stereo pcm. If I connect the optical cable back to the hopper, the light turns blue and says digital optical 3/2. Am I doing somthing wrong here? there is a slight audio difference, how do I get the digital 3/2 back? Thank you for helping.
  • dave2085 Apr 17, 2014
    Is there a spitter I can buy? My 42' lcd has a optical out, my Toshiba blueray has a coaxial audio out and my Dish Hopper has an optical out. My Sony strde725 receiver has 1 optical in, no place for a coaxial cable only RCA in/outs. Can I run them all together? I've attached a pic of the ports. Thank you!
  • Steve K Apr 18, 2014
    They do make a two-to-one optical splitter but I have heard of people having problems when using them. It might be worth a try if that is your only option
    Genius:
  • Sony Master
  • 1,054 Answers
Unfortunately, most tv's will only put out a stereo signal from the optical output. The receiver would then have to convert it to surround internally.
Posted on Apr 15, 2014
3 Suggested Answers
  • 11 Answers
SOURCE: unable to properly connect sony dvd to tv to play movie
DVD-3 RCA phono outputs(red & white=audio,yellow=video
I have a DVP-NS700,the same happens on mine.Turn it on,goes green to red(standby),then press eject,it will then power up properly.
Posted on Jan 08, 2009
  • 57 Answers
SOURCE: My new BluRay player has HDMI output for both
Yes, you can connect the HDMI Cable from the Blu-ray Player to the TV directly and then, connect the Digital Optical cable from the Blu-ray Player to the Receiver.
Posted on Feb 24, 2010
Yamaha RX-V595 Receiver will play Dolby Digital 3/2.1 audio Blu-Ray disc with player set to bitstream but will not play DTS-HD 3/2.1 unless output is set to PCM. Is this an issue with the Yamaha Recei
The optical connection (SPDIF) doesn't have enough bandwidth to transfer DTS-HD audio. To use DTS-HD, you must connect the blue-ray player and receiver via HDMI cable.
Each DTS-HD audio track on blue-ray includes also "normal" DTS audio, which is probably used when you select PCM. Player decodes it and sends decoded (non-HD) audio via optical cable to receiver.
Nov 17, 2014 | Yamaha RX-V595 Receiver
No Audio
cant use both hdmi and opti outs try sum setting in blue ray but u nee dto plug all blue ray dish directto samsung hdmi then 1 master digital out form tv to sterio digital i n ok tell samsung your output also
Jan 20, 2008 | Sony STR-DG510 Receiver
It's not the optical cable or the optical port in the tuner, since I used the cable to connect my blue ray player to the tuner and the tuner could recognize the cd and played the music. But there is...
The presence of light is not proof of the presence of data (music, in this case).
There has to be another unmentioned piece to this puzzle - like a receiver. Is IT configured to use that optical signal? It's PCM, by the way, not mutichannel or Dolby Digital as the Bluray might be.
Jul 05, 2011 | Sony MegaStorage CDP-CX355 300-Disc CD...
I am trying to setup my receiver with my TV and Comcast cable box using HDMI cables (TV-OUT and HDMI-1) but for some reason I don't get any sound from non-HD channels. Am I missing something?? I've read...
I'm thinking there might be a setting in the cable box that may be sending the wrong bit rate for PCM 2-channel audio but usually the receiver decodes that stuff fine. Just the same, I'd give Comcast a call.
I run the video from my cable box directly to the TV (HDMI) and the coaxial digital audio to my receiver so each one can do what it does best with the best possible un-modified source data.
Dec 25, 2010 | Sony STRDH810
Technics SA-DX940 Digital optical audio input
When you say you have sound from the BD prior to disc load... where (TV and/or receiver)? Initial wake-up audio is usually 2-channel.
Describe the optical audio connection input to the receiver and any other audio paths that are attached.
Do you have other multichannel sources you could use to test this, like a cable TV box?
There's an obscure setting in the receiver called PCM Fix (on Page 21). Give that a look.
Jun 07, 2010 | Technics SA-DX940
Audio output from amp stopped working on 1 input but others fine
you most likely need to assign the digital input "your optical" to a certain input on the amp like tv/sat
Feb 18, 2010 | Sony STR-DH500 A/V Receiver
I cannot get sound from a sony BDS350 (Blue ray
This must be configuration problem on the BD player. In this case receiver just outputs the signal it receives digitally. If it displayes PCM 2ch, that means it receives only 2 channel audio from BD player.
You can try to configure the BD player not to decode audio and to output the RAW stream over coax cable to the receiver. Then the receiver should get raw Dolby Digital encoded data and be able to decode it into 5.1 channels. It should also display Dolby D instead of PCM in such case.
Feb 11, 2010 | Sony Audio Players & Recorders
My PS3 will not play sound on my Sony Bravia HDX275 surround sound system. I have the HDMI cable plugged from the PS3 to the TV. I have another HDMI cable from the receiver to the TV as well as a opitcal...
Adjust the system's audio output settings. These settings are mainly used when the system is connected to audio devices that support digital audio output, such as AV amplifiers (receivers) for home entertainment systems.
1.
Confirm the formats supported by your audio device.
Settings vary depending on supported formats. For details, refer to the instructions supplied with the audio device.
2.
Select in_soundset.gif (Sound Settings) under in_setting.gif (Settings) in the home menu.
3.
Select [Audio Output Settings].
4.
Select the input connector on the audio device. Channel numbers and audio formats that are supported vary depending on the connector in use.
soundoutput001.jpg Input connectors on the TV or AV amplifier (receiver) PS3™ system output connectors Channels that can be used for output 2 Ch. 5.1 Ch. 7.1 Ch. HDMI HDMI OUT connector in_maru.gif in_maru.gif in_maru.gif Digital Out (Optical) Digital Out (Optical) connector in_maru.gif in_maru.gif - Audio Input Connector / SCART / AV MULTI AV MULTI OUT connector in_maru.gif - - 5.
Select audio output formats.
Select all output formats that are supported by the audio device in use. If [Audio Input Connector / SCART / AV MULTI] is selected in step 4, the screen for selecting audio output formats will not be displayed. If [HDMI] is selected, you can also select to automatically set the audio output format. (In this case, the HDMI device must be turned on.)
soundoutput003.jpg 6.
Check your settings.
You can go back to the previous screen and revise the settings by pressing the in_left_key.gif button.
soundoutput002.jpg 7.
Save your settings.
The audio output settings are saved on the system.
Hints
  • [Linear PCM 2 Ch.] audio is set to be output from all output connectors by default. If you change the audio output settings, audio will be output only from the connectors that were set.
  • If you change the audio output settings, the system will no longer be able to output audio from multiple output connectors at the same time. For example, if your system is connected to a TV via an HDMI cable and to an audio device via a digital optical cable and you switch to [Digital Out (Optical)] under [Audio Output Settings], audio will no longer be output from the TV. To output audio from the TV, switch the setting to [HDMI], or select in_setting.gif (Settings) > in_soundset.gif (Sound Settings) > [Audio Multi-Output] and set the option to [On].
  • If you select [Linear PCM 2 Ch. 88.2 kHz] or [Linear PCM 2 Ch. 176.4 kHz] in step 5, sound may be intermittent or may not be emitted from some audio devices.
  • When using an HDMI cable, only [Linear PCM 2 Ch.] audio will be output from PlayStation®2 and PlayStation® format software. To output Dolby Digital or DTS audio, you must connect the PS3™ system and the audio device using a digital optical cable and switch to [Digital Out (Optical)] under [Audio Output Settings].
  • If a device that is not compatible with the HDCP (High-bandwidth Digital Content Protection) standard is connected to the system using an HDMI cable, video and/or audio cannot be output from the system.
(Information taken from here)
Hope it helped.
Nov 18, 2009 | Sony Playstation 3 (PS3) Console
Sony PCM 48 Issue
As long as you continue to have both HDMI and optical outputs connected at same time from the cable box, it will probably always choose the default as HDMI. If you do not want to change any connections then the best thing to do in this case is to always leave the cable box turned on. Otherwise, disconnect the HDMI and connect it to the TV by component video.
Jun 17, 2009 | Sony STR-DE698 Receiver
8' Optical Cable from TV to Receiver and Signal is Breaking Up
Before you buy anything try checking the AUDIO Settings in the Menu of Each Device (Mostly TV) and see if they are set to PCM or BITSTREAM. HDMI is mostly set to PCM while Optical is generally Bitstream. The TV may be set to the opposite of what it needs to be. I would try to get PCM to work first cause it is Better, If not then set what you can to Bitstream and it should pass. Also check in TV Menu for SOUND OUT or AUDIO OUT or SPEAKERS. Some TV's have a problem passing Audio through when they are already Outputting them to it's own Speakers! I Hope this Helps out!
Apr 11, 2009 | Yamaha HTR-6130 Receiver
Televison & Video Logo
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
