Question about iPhone Apps
Pavilion dm1 doesn't rotate screen - iPhone Apps
3 Suggested Answers
TheSelkie
  • 734 Answers
SOURCE: how to re-install bluetooth on my hp pavilion dm1?
Since you only put dm1, go to this page and pick exactly which one of the 107 different models of dm1 you own and click on it. At the Drivers page, select the proper operating system (xp/vista/w7) you are using and you'll be shifted to the complete list of drivers for your computer.
You want to download the "bluetooth stack/software,driver (whatever...lol)" for your laptop and install it.
Regards,
TheSelkie
Posted on Jul 21, 2010
bronk50
  • 27725 Answers
SOURCE: only one speaker working in hp dm1
This could ba a hardware problem with the power connections or dust
Laptop speakers often suffer the consequences when you snack while using the laptop, usually while surfing the Web.
Small particles of chips, crackers and other sources of crumbs easily fall into the little holes of your laptop's speakers, therefore causing sound distortion.
This sound distortion problem can be fixed by cleaning out your laptop's speakers with a safe process that does not require any dismantling of the laptop.
Turn the laptop off, unplug the power cord and remove the battery to lower the risk of damage to the computer and electric shock.
Wipe away any exterior debris using a cotton swab.
Dip the cotton swab in rubbing alcohol and swab away to remove any sticky residue.
Rubbing alcohol dries quickly, making it ideal for cleaning electronics.
Use a hand-held vacuum with the brush attachment to vacuum out any debris in the speakers.
A full-sized vacuum may be too powerful and can damage the speakers.
Reinstall the battery, plug the computer back into the electrical outlet and start it up.
hope this helps
Posted on Oct 18, 2012
Loose hinges and screen trim comin off
screen trim should be able to be pressed together from front to back, loose hinges is caused by the screws at the hinges. you can pop the trim all the way off normally either by unscrewing the screws or in the case of most hp netbooks by simply applying some pressure between the 2 halves of the screen casing. i'd remove the front half and tighten the screws and then pop everything back together.
Dec 12, 2013 | HP Pavilion DM1-4050US 11.6-Inch Laptop
Hinges and screen trim loose
If you check out utube there is a video showing the disassembly of your machine. You need to remove the screen and hinges, tighten the fixings and re build it.
http://www.youtube.com/watch?v=8V2MwA6RIPE
Hp dv9800 service manual
1) http://www.tim.id.au/blog/tims-laptop-service-manuals/#toc-compaqhp
Scroll down to the subheading - HP Pavilion dm1. (dm1 in blue)
Go down to the second line in this 'paragraph', and scroll across.
Click on the blue dv9000.
This is a PDF file. The computer you are using now has Adobe Reader on it, which uses PDF files.
After you click on the file name (9000) it may take up to 30 seconds, before the first page comes up.
2) http://www.insidemylaptop.com/remove-lcd-screen-inverter-board-hp-pavilion-dv9000-laptop/
3) http://www.cesgeekbook.com/2010/01/dv9000-disassembly-tear-down-part-1.html
4) http://www.youtube.com/watch?v=bnkQNmKauEc
Not advertising, using for reference material.
Regards,
joecoolvette
Aug 22, 2012 | HP dv9819wm Notebook, 17.0 WXGA+...
Rotate screen back to horizotal
Try pressing Ctrl + Alt + UP Arrow Key, or try Ctrl + Alt + and a different Arrow Key.
If that does not work: Right-click on empty Desktop > Graphics Options > Rotation.
or
Press "Ctrl-Alt" and an arrow key (left, right, up or down) to rotate the screen.
Continue pressing the hotkeys and arrow keys until you reach the desired rotation. This works with most video drivers on Windows XP. If it doesn't,
Click "Start," then "Control Panel," then "Display," then the "Settings" tab. Click the "Advanced" button. Check for an "Orientation" option. Select your desired orientation.
hope this helps
Jul 25, 2012 | HP Pavilion tx1000z Notebook
Removing back cover of hp dv 6915nr
Back Cover?
1) Display Cover: The plastic cover that is on the opposite side of the LCD screen. Sometimes referred to as Top Cover.
Display Assembly is removed from laptop first, then LCD screen assembly is removed from the Display Cover.
2) Base Enclosure: The plastic bottom part of the notebook.
A laptop is disassembled from the Top down to the Bottom.
The bottom 'cover' (Base Enclosure) is not removed first. It is last.
3) There is no back cover per se. Half of the cover for the back (Bottom half) is part of the Base Enclosure. The top half is part of the Palm Rest.
(The back has the Vent in it)
http://www.insidemylaptop.com/remove-replace-lcd-screen-inverter-hp-pavilion-dv6000-laptop/
[Use the dv6700 service manual. Go down to the subheading HP Pavilion dm1 (dm1 is in blue)
Scroll to the right, click on dv6700. Note that it is a PDF file, and may take up to 30 seconds, before you see the first page come up ]
What is it you are trying to do? What hardware component are you trying to access?
Post back in a Comment.
Regards,
joecoolvette
Display assembly is removed. Palm Rest Cover is removed, and so on.
Jan 14, 2012 | HP Pavilion dv6915nr Notebook
I need a manual for HP DM1-4027S A
HP Ireland Support > Pavilion DM1-4027sa Notebook PC > Main Support page,
http://h10025.www1.hp.com/ewfrf/wc/product?product=5177008&lc=en&cc=ie&dlc=en&lang=en&cc=ie
Click on - Manuals - in the right column.
In the list;
HP Pavilion dm1 Entertainment PC - Maintenance and Service Guide,
is a Service Manual. (Free)
It is a PDF file. After you click, it may take up to 30 seconds before the first page comes up.
HP Notebook Reference Guide - Windows Vista and Windows 7,
is a User Manual.
For additional questions please post in a Comment.
Regards,
joecoolvette
Nov 29, 2011 | HEWLETT-PACKARD Computers & Internet
How to re-install bluetooth on my hp pavilion dm1?
Regards,
TheSelkie
Jul 21, 2010 | HP Computers & Internet
iPhone Apps Logo
91 people viewed this question
Top Apps Experts
Lesley Cameron
Lesley Cameron
ray gallant
Are you an App Expert? Answer questions, earn points and help others
