Question about HP Officejet Pro 8500 Wireless All-In-One InkJet Printer
Need to replace the cmos battery on an hp officejet 8500
Need to know where the battery is located on this printer
    New Friend:
The HP OfficeJet Pro 8500 HAS a CMOS battery! I removed it myself. Totally there! Don't believe anything else.
When facing the printer it is on the Right Side, behind the green board. Get a Torx #10 and remove panel on right hand side and remove screws on the green board. It is close to the front on the right hand side.
Other things I learned over the years of searching to fix HP nonsense!:
ALSO PRINTER TEST MENU:
Press "*" + "#" simultaneously, then press 123
https://www.youtube.com/watch?v=4jeBbsvU6rA
PRINT TESTS MENU
then Bypass Pen Alignment
And If the constant Alignment wont stop:
Press "*" + "#" simultaneously, then press 3-2-9 t
Get to the service menu
Then using the right and left arrown go to RESET menu press OK.
Then Look for SEMI FULL reset and then press OK.
But better to buy a different MAKE of printer. I'm done with HP.
Posted on Jan 19, 2017
  • 225 Answers
SOURCE: hp officejet 7110 battery and cmos location
The battery is located behind the left front cover. Open the printer, grasp the left front cover from inside the printer and pull to open. Look inside the printer to left and you will see it.
It is enough to remove for a minute to reset the expiration.
But I'm afraid after that the printer may not keep the date and time when turn off.
Posted on Dec 17, 2008
parrotheadpc
  • 2600 Answers
SOURCE: I need tutorial on operating my HP Officejet Pro
Here is the link for all the guides and setup procedures for your priinter.
http://h10025.www1.hp.com/ewfrf/wc/manualCategory?lc=en&dlc=en&cc=us&lang=en&product=3752456&
Posted on Sep 20, 2009
SOURCE: HP Officejet Pro 8500 has a paper jam. Can't get
Hi! I will be glad to assist you in this issue, here is the link that will fix the issue:
Paper Jam' Message Displays on the All-in-One
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01617494&tmp_task=solveCategory&lc=en&dlc=en&cc=us&product=3752459&lang=en
Carriage Jam' Message Displays on the Control Panel Display
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01618201&tmp_task=solveCategory&lc=en&dlc=en&cc=us&product=3752459&lang=en
Posted on Oct 11, 2009
  • 42 Answers
SOURCE: Fax log full HP Officejet 8500 error; Delete not
Please press the set up menu on th eprinter which is like a tool(wrench)-----Arrow keys-----TOOLS-----OK-----Arrow Keys------Clear Fax Log------OK.
This will clear the fax log.
If still the issue persists, please follow the below steps.
1. Touch the Setup icon.
2. Scroll to and touch Tools.
3. Scroll to and touch Restore Factory Defaults. A Defaults Restored message displays.
4. Press the Cancel button to return to the main menu.
And then, again cleasr the fax log by following the below steps.
This will fix the issue.
Posted on Apr 12, 2010
SOURCE: Paper Jam HP OfficeJet 8500
etechrepair.jpg Constant jam indication. This gear is more than likely the cause after exhausting all other avenues. Also nearly impossible to get to let alone replace even if HP offered the part. There is a black cover over the clutch assy that can be removed to reveal the gear. In most cases the gear is either sitting in the bottom of the machine or split down one side. This is the second machine that I have diagnosed with this problem in a very short time. If you have this broken gear, consider it toast. Matt / E-tech Copier and printer repair.
Posted on Jan 19, 2011
Where is the CMOS battery located on an HP Officejet J5780?
It does not have a cmos battery. the printer has flash memory so no need for battery
can't help with factory reset or bios flash sorry
Jun 21, 2015 | HP Officejet J5780 All-In-One InkJet...
How do you scan wirelessly from hp officejet pro 8500 to computer?
If the software is installed properly then you can scan from either the computer or by pressing the scan button on the front panel of the printer .
Would liek to know which operating system you have and let me know if you need further assistance in it
Apr 08, 2011 | HP Officejet Pro 8500 Wireless All-In-One...
I have an HP Officejet Pro 8500 all in one printer. My magenta doesn't print. I can't print anything with red/pink in it. Can you help?
Try another cartridge first, making sure it is located properly in its seating and is the right spec.
You may not know, 8500 non wireless cartrigdes do not work in wireless A909.
Are you talking about replacing the cartridge at the left side front cartridge compartment or the printer heads under the scanner lid?
Feb 21, 2011 | HP Officejet Pro 8500 Wireless All-In-One...
Need HP officejet pro 8500 Service Manual
You can find one here: http://downloadfreemanuals.com/officejet-pro-8500a-manual/
Jan 20, 2011 | HP Officejet Pro 8500 Wireless All-In-One...
Need user manual for officejet printer 4 in 1 8500
Here is a link to the user manual and other documentation for the hp officejet 8500 multifunction printer
Feb 08, 2010 | HP Officejet Pro 8500 Wireless All-In-One...
Location of cmos battery on HP 7410 all in one printer?
Good luck because there is no CMOS on a printer..its on *********** board what is it you are trying to do.
Mar 11, 2009 | HP OfficeJet 7410 All-In-One InkJet...
HP Officejet Pro 8500 Wireless  All-In-One InkJet Printer Logo
243 people viewed this question
Ben Johnson
