Question about Intel DG31PR Motherboard
No display cpu fan only running no display out
Amilo 1450 display not working and in external diplay also not working
What fan is not running? The case cooling fan or the CPU cooling fan? Did you try to boot into Safe Mode, and did the computer/screen start working then?
May 10, 2014 | Computers & Internet
Does not boot, no beep, no display, fans running on high speed
Try blowing the dust out of the inside, around the vents, around the fans and by the cpu and heat sink.
Also remove the fan as it sits on the cpu and heat sink. Then remove the heat sink that sits on the cpu, then remove the cpu by releasing the latch on the side of the bay it sits in (remember how the cpu goes back into the bay). Now clean off the old dried up thermal paste on top of the cpu and on the heat sink that sits on the cpu. Put the cpu back into the bay and secure the latch. Apply a fresh coat of Thermal Paste to the CPU and Heat Sink. Put everything back together then reboot.
If the thermal paste has dried or is too thin to keep the unit cool it's like metal touching metal and shorts out the system so it can't boot.
May 31, 2012 | Computers & Internet
P4M900T-M2 Motherboard cant display anything on display, Power supply fan & CPU fan is running. I changed processor, RAM, Power Supply, Capacitors around CPU, but am still getting nothing on the...
It seem that changing the mother board was needed to confirm as there seems to be a problem related to non communication of the mother board with the CPU, RAM and sections.
Swap and confirm.
Aug 08, 2011 | Computers & Internet
With asus m4a785-m motherboard and amd phenom x4 9600b quad core cpu why does monitor displays a cpu fan error when fan is running full speed.
Hmm, I've never seen a computer give a CPU fan error. Maybe if the fan is really dusty it's clogging it up, try getting some canned air and spraying it out.
Dec 17, 2010 | ASUS M4A785M Motherboard
No display cpu fan are'nt running though there is green and orange light on server
Hello there,
Check your power supply and see if its functioning.
CPU fan that does not run means there is no power getting into the motherboard.
Thank you for using Fixya
Apr 06, 2009 | Fujitsu Siemens PRIMERGY P200 Server
When cpu switch on processor & power supply fan runs, no display
if you have swolen capacitors you are on the road the failure
buy a new mb and save yourself some time.
hope this helps
Dec 30, 2008 | EliteGroup P4IBMS Motherboard
No beep,No Display on my monitor,only CPU heatsink fan is moving
have you thought about changing the battery on the motherboard, also checking that the fan on the cpu is seated properly with enough heatsink paste as both these issues will stop the pc from booting
Oct 29, 2008 | Asrock K7S41GX Motherboard
Sony vaio VGN FS 570 no display
Try having your battery tested. There may be not enough power to run everything on your comp.
Anotherthing to consider, if your CPU fan isnt working the bios wont start the O.S. as the CPU will overheat and shut down automatically. Good Luck
Oct 14, 2008 | Computers & Internet
Motherboard problem
If your cpu fan is faster,it may be due to a higher frequency setting.
The frequency that it runs best at is 60 hz, but it can be running at 70 hz or higher.
Jun 14, 2008 | ASUS P4P800-X Pentium Motherboard
Intel DG31PR Motherboard Logo
Top Intel Computers & Internet Experts
Tony
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
