Question about Toshiba Satellite 2435-S255 Notebook
Pre programmed F5 Key
The F5 key on my Toshiba Satellite P55t-A5118 is pre-programmed to disable and enable the touchpad mouse. I need the F5 key for Powerpoint to display projector view but it won't work because it is pre-programmed from the factory.
  • 624 Answers
SOURCE: HOW TO ENABLE TOUCHPAD ON TOSHIBA SATELLITE PRO M15-S405
Press the Fn and F9 keys, that should turn it back on. Let us know if that solve your issue and please dont' forget to rate this posting.
Posted on Feb 09, 2007
  • 1015 Answers
SOURCE: i have a Toshiba Tecra M8 and the touchpad stopped
Check in the device manager and see if the touchpad is listed under pointing devices.If it is not there try add hardware and see if it detects the hardware. If it is there check to see if it says device is working properly. Sometimes touchpads require software to operate properly so check and see if software was uninstalled. You can also download the drivers/software from Toshiba, try removing the touchpad in the device manager and then re-booting the computer. When windows re-boots it should start installing new hardware found. Use the driver/software you downloaded from Toshiba. If none of these work your touchpad may be bad.
Posted on Sep 05, 2009
  • 1015 Answers
SOURCE: mouse pad cursor doesn't work
try using the FN key with the monitor/VGA output selection changer(usually F5). You will see a little icon that looks like two monitors. Mouse control may have been changed to the external monitor connection. See if pressing FN(function) and holding that key and then pressing the monitor key will bring back your mouse indicator. You may need to do it with the projector connected and on.
Posted on Sep 12, 2009
YouRnotGOD
  • 34 Answers
SOURCE: F5 KEY not working
Try going to control panel-install/remove hardware. Find your keyboard in the list, right click, go to properties, click on driver, then update driver. If that does not work, please inquire back for more assistance.
Posted on Oct 05, 2009
  • 23 Answers
SOURCE: Touchpad doesn't work on Toshiba Satellite 305 PSAGU-03601V
Go to
Use a mouse or Tab+Aly keys
Win XP
Start > Control Panel > System
Click the "Hardware" tab
Click the "Device" manager button.
Click the cross near "Mice and other pointing devices".
Right click, "Enable"
Vista
As above but
Start > Control Panel > Device Manager
Posted on Mar 19, 2010
Mouse touchpad not working
try installing the drivers for the mousepad
Mar 05, 2014 | Toshiba Computers & Internet
My touchpad and control buttons on toshiba satellite pro c850-FJ don't work
Contact seller. I'm a bit confused? Brand new Windows 8 install then Uninstalled ? Why? Is Win 8 still installed?
Feb 11, 2013 | Toshiba Satellite E205-S1904 Laptop
My mother just gave me a toshiba laptop and she had a wireless mouse for it before. I do not have the mouse on it now and the mouse pad is not working. How do I restore it to the original setting?
Hi parothead91...
To fix an unresponsive touchpad on your laptop, reactivate it by using the Function key on the keyboard and the Fn key.
This process is different for each computer manufacturer.
If unsure which Function key enables and disables the touchpad, try each one at a time and then
attempt to use the touchpad after each one.
A...Locate the "Fn" key of the laptop keyboard.
The "Fn" key has different colored text or the key is a different color.
B...Locate the function (F1 through F12) key at the top of the keyboard that disables or enables the touchpad on the laptop.
The key typically has an icon that resembles a touchpad with a finger touching it or a touchpad with a diagonal line through it.
C...Press both the "Fn" and touchpad Function key at the same time to reactive the touchpad on your laptop.
Move your finger along the touchpad to verify that it works. Press the combination at any time to disable the touchpad again.
Note: Mac computers use "F2" to enable and disable the touchpad.
Please take time to rate me
Sep 05, 2011 | Toshiba Computers & Internet
Toshiba A100 touchpad mouse not moving
Many toshibas have the facility to turn the mouse/trackpad on or off. I have seen it on the upper keys in blue text, meaning you need to hold the fn (Function) key down at the same time as the mouse enable/disable key.
Jul 25, 2010 | Toshiba Satellite A100-S8111TD Notebook
TOUCH PAD ISN'T WORKING, CURSOR WON'T MOVE
your touchpad might have a 'lock' button nearby it, to enable or disable its sensitivity. this is usually helpful while typing, so you can disable it so that the when the touchpad gets touched, the mouse won't make any reaction. You can then enable it to work with the mouse. This button is usually either near the top border or near one of the four borders. Alternately, some laptops have a function key for touchpad enable-diable thing. It is usually Fn + F3. The function key (Fn) is near the Ctrl key. The touchpad key, in the in colour of the Fn key will be somewhere in the Function keys.
May 02, 2010 | Toshiba Satellite A100-S8111TD Notebook
The touchpad stopped working after a powerpoint presentation i made. A friend helped me set up the laptop to the projector and he did press keys. Did he accidentally press some inactivating key in the...
FN + F9 should enable / disable the touchpad goto control panel - mouse - and see if you can change disable/enable touch pad from there Otherwise post back what windows version you have
Touchpads
you can enable and disable the touchpads Touchpad: - to enable or disable a touch pad/pointing device from the Start Menu > control panel > Change to classic view - {on left hand menu} click on the mouse icon Mouse Properties dialog box, click "Device Settings tab" select the device click to Enable or Disable OR You may need to enable in the bios/setup menu - as the PC boots - you should get a message on how to get into the bios/setup - usually using F2 or DEL Key or F10 see if touch pad needs to be enabled there OR one of the F keys may disable/enable - depends on the model of the Laptop - toshiba sometime use FN+F9 key
Apr 10, 2010 | Toshiba Satellite M55-S325 Notebook
Satellite P505 Model S8980 - unable to get TouchPad to work now where it did work before. The TouchPad ON/OFF button nor the Fn+F9 approach are no help. A USB-connected mouse worked fine, tho. Just no...
----- control panel - mouse - see if touch pad disabled there ----- have a look in the bios/setup and see if the touch pad is disabled there, as the PC boots - you should see which key to use to enter the bios/setup F2, F10, DEL KEY are often used ----- On some machines a combination of FN and F key can disable/enable the touch pad - F7 or F9 ----- If you point the mouse to the top of the screen you may get a menu dropdown, which will also tell which key to use to disable/enable the touchpad ----- control panel>system>{vista}lefthand side device manger or {XP}hardware>Device Manager>Mouse and other pointing devices>Touchpad>highlight touchpad and right click, Properties, may be an option here to Disable/enable,
Feb 18, 2010 | Toshiba Satellite P505-S8950 Notebook
Touchpad not funjctioning on Toshiba Satellite L40/45 laptop
You might have inadvertedly disabled the touchpad.
1. Press Fn + F9 to enable the touchpad.
This key combination acts as a switch, enabling or disabling the touchpad: press once to enable (if it is disabled), then press again to disable.
2. If the touchpad still doesn't respond, check the settings in the mouse control utility.
Click on the touchpad icon on the right side of the task bar if you see one or click Start button/Settings/Control Panel, select the Mouse icon and Press Enter.
Change the settings if necessary.
Aug 17, 2009 | Toshiba Computers & Internet
Touchpad not working
First check: Control Panel -> Mouse -> TouchPad On/Off
Second check for a button near the mouse pad, often there are buttons that will enable/disable the touchpad
Thrid use the shortcut key FN+F9(or what ever F key that is used by your laptop) to disable/enable the TouchPad.
Fourth try this software: http://www.kingzm.com/eng/files/download/MouseManager.zip
Fith
- Select Start, Settings, Control panel.
- Open System, click on Hardware, and Device Manager.
- Expand "Mice and other pointing devices", and double click on the entry below, that may be called "HID-Compliant mouse", or "Alps Pointing Device".
- Under "Device usage", choose "Do not use this device in the current hardware profile (disable)", and click OK.
Jan 20, 2009 | Toshiba Satellite A205-S4617 Notebook
Touchpad is not working - TOSHIBA Satellite A135-2386
Hey there... :D
Could you try the Fn+F9 Key to Disable/Enable your touchpad mouse?
Because just now i've experiencing the same problem as you guys... and turns out I can make my touchpad working just by pressing the Fn+F9 key.
Note: if your Fn key is not working try installing Toshiba utilities for A135 called FlashCard, run the program and there will be a dropdown menu at the upperside of your screen...
then click on F9 >> and choose Enable.... Thats It... :)
I hope it also solved your problem... :D
Mar 19, 2008 | Toshiba Satellite A135 Notebook
Toshiba Satellite 2435-S255 Notebook Logo
52 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
