Question about Dyson DC07 Bagless Upright Cyclonic Vacuum
Lack of suction in hose
Vacuum runs fine, then approx. 15 sec after the hose is taken out, a inhale and pop is heard, then there isn't any suction. Like a ball got caught in the intake valve. It's a Dyson DC15, 4 years old.
    Sniper:
  • 83 Answers
That popping sound is the bleed valve activating - it indicates that there is a blockage in the machine somewhere, probably in the wand if you're saying that there is no suction in the wand.
- Take the wand off the back of the machine - press the two gray buttons to separate it from the hose - hold the wand in the air and look through it - if you can't see the light coming through the other side there's a blockage in the wand - taka a long object like a meytal hanger and remove the blockage.
If that's not the problem, call the Dyson helpline for further troubleshooting, they know what they're doing.
Posted on Jul 30, 2009
  • nancytyson Aug 19, 2011
    Thanks for the info on the gray buttons -- the clog was in the bendy part and I couldn't tell just by looking down the wand. Suction (and clean carpeting on stairs) is restored! Yay!
Lack of suction
You don't say what type of vacuum but it still sounds like a blockage or a split in a pipe... have another thorough look..
Is exhaust air blowing out of the machine... Is the motor running at a higher pitch than normal...?
Apr 16, 2017 | Vacuums
Miele Silver Moon Losing Suction
if there's no blockages and filters all OK it's probably the suction fan that as worn down and not creating as much suction..
May 02, 2013 | Miele s558 Silver Moon Vacuum
No suction no blockages was working fine
I'm sorry to hear you've had difficulty with your DC18. If your machine isn't picking up as well as it should be, there may be a blockage in the machine. If you haven't been able to locate one in the cleaner head or internal hose, I'd encourage you to get in touch with us directly for further assistance.
You can reach us on 1-866-693-9766 (US), or 0800 298 0298 (UK). Please have the machine to hand when you call so one of our advisors can run through some checks over the phone with you.
We'll look forward to hearing from you.
Best wishes,
Jack
Dyson Online Customer Support
http://www.dyson.com
Jun 17, 2012 | Dyson Slim DC18 All Floors HEPA Bagless...
Why would the vacuum have no suction?
if the motor is running it could be a belt a clog or a hole somewhere else in the hose
Feb 16, 2012 | Kenmore 23612 Progressive PowerMate Bagged...
I cleaned out the hose and removed brush to clean and checked belt. Everything seems to work but will not pick up or suction on carpet. The hose is totally clear from clogs. I can see the floor from one...
Hi troupdavid,
I see that your Vacuum is having issues with it suction, you mentioned that you took it a part to clean it, see steps below.
  • Check if everything is inserted properly and is in place.
  • make sure the the Vacuum airflow does not have anywhere else to come out from, cause if there is, the vacuum suction will really not be really getting enough suction to be able to get dirt Off the floor.
  • Make sure the bag is correctly placed in the Vacuum and is tucked in properly for proper suction.
  • The hose should be twisted to be locked into Place, either clock wise or counter clockwise which ever makes it lock to the hose socket.
  • Also check the agitator shield beneath making sure that the Belt is not pinched in or squished by the Agitator and the Agitator shield, this can also cause lack of suction for the Vacuum.
I hope that this will be of help regarding your query.
Have a nice day,
mvincentc
May 01, 2011 | Hoover Tempo Widepath Upright Vacuum -...
Lack of suction on the main part of the vacuum
There are two easy things to consider if you have a lack of suction on the vacuum:
1. Replace the bag and check the hose leading to the bag to see that it's not blocked.
2. Replace the belt.
You may think that the belt doesn't have anything to do with suction, but it does. When belts are worn and stretched, they don't work efficiently.
Jul 07, 2009 | Kenmore Vacuums
Suction
hello tnwalkergal the hose may have a clog inside the hose at the bend you can take the hose loose and run a broomstick or a yardstick thorgh the hose this is how I find the clog
Jan 24, 2009 | Dirt Devil M086700 Vision Bagless Upright...
Vacuum not picking up
At the top of your wand, do you have a plastic swivel that cover a hole in the wand? This is for when you are cleaning curtains, and if that is open, or cracked you will loose suction there... also check your hose for cracks, or breaks. If it were in the shop I would put a gauge on it... normal suction is about 80-95 inches of water lift at the end of the hose. Once you have check each section of the hose, and wand, check the housing for cracks, a missing gasket (Very Good Reason For Lack Of Suction) As to your Filter, how long have you used that one filter, you can clean them for a while, but once a paper filter gets full of FINE dust you won't get it all out, you will have to replace the filter itself at that point. I hope this was helpful.
Jan 19, 2009 | Kenmore 22512 Bagged Canister Vacuum
Hose has no suction
Most uprights need to be in the up-right locked position to enable the hose pickup.
Jul 25, 2008 | Eureka 4874 Bagged Upright Vacuum
Willnt pick up good...
I had this problem once too. When the hose is inserted into the vacuum, the floor unit (where the spinning brushes are) becomes the head of the vacuum. In other words, the suction goes through the floor part and then up through the hose and into the vacuum. If the suction is good when the hose is out, the the problem is blockage at the bottom piece. Take the cover off of the rollers (it is one screw then it pops right off) and see if there is a bunch of lint/hair/gunk blocking the suction hole. You could also take the hose part out of the vacuum and look down the empty shaft with a flashlight and see if you see anything there. Hope this helps!
Apr 04, 2007 | Fantom Vacums FM760 Twister 500DX Bagless...
Dyson DC07 Bagless Upright Cyclonic Vacuum Logo
589 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Samyfam
Samyfam
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
