Question about Konica Minolta bizhub Office Equipment & Supplies
What is L1 warning in Konica Minolta C360 MFP printer
IT says L1 warning - something to do with the drum unit
  • Konica Minolta Master
  • 6,161 Answers
Replace the cyan (blue) drum unit
Posted on Jan 10, 2016
SOURCE: Need a USED DRUM UNIT -- Complete, not just the drum!
EBAY!!!!!
Posted on May 13, 2009
  • 7 Answers
SOURCE: PRINTER TROUBLE CODE C-0210 KONICA MINOLTA
on previous models with this code check that there is no paper caught behind the tray open and close door to clear code
Posted on Mar 04, 2010
  • 8 Answers
SOURCE: to change opc drum in konica minolta
To Change OPC DRUM UNIT in KONICA MINOLTA 2300 w
Switch Printer Off
Open Front Door Cover
Remove Waste Toner Box
Lift Transfer Belts Blue Knob until it's placed at 11 o'clock. (it's directly behind the waste toner box)
The OPC DRUM UNIT is directly under the BLUE KNOB
SQUEEZE HANDLE and PULL OUT the OPC UNIT
Be VERY CAREFUL NOT TO SCRATCH THE GREEN COLOURED ROLLER on the OPC DRUM UNIT.
Replace new OPC DRUM and turn BLUE KNOB of TRANSFER BELT back to 7 o'clock position
Replace Waste Toner Box, Close Front Cover and Switch On.
Status Display will show OPC Drum at 100%
(You can also replace the fuse in the OPC DRUM UNIT and save yourself HUNDREDS on a new one)
I posted this on another solve problem previously, worth looking at.
Posted on Mar 13, 2011
  • 158 Answers
SOURCE: an error on my c360 konica minolta c-3721
fuser temp too high to reset turn off machine then turn on while holding down the utility/counter button when the trouble reset button comes up on the touch screen touch it and make sure it says ok then turn the machine off wait 10 seconds and turn back on if error code comes back fuser unit will have to be replaced
Posted on Feb 06, 2013
  • 1294 Answers
SOURCE: i want to change the setting of my drum unit on a konica minolta C-360
Enter in the service mode by press following keys:
Utility - Meter count-Check details - Stop - 0 - 0- Stop - 0 - 1 - Stop -0 -C - setting IU life stop setting and select NO STOP.
Posted on Feb 20, 2013
Error sortout
Conduct the following setting.
[Service Mode] ? [Memory/HDD Adj.] ? [Memory Check]
? [Detail Check].
When "NG" is displayed, replace the appropriate memory or
PWB.
WORK0: DIMM0
WORK1: DIMM1
FILE0,1: MFP board
Sep 28, 2016 | Konica Minolta Bizhub C360
C-F907 bizhub C360 -
sir, MFP board (MFPB) not receiving SIO receiving port...ADF ADF (Document feeder) not talking to main board.have tech come out might need to be re-flashed worse case both board need to be replaced
Sep 22, 2016 | Konica Minolta Bizhub C360
Bizhub c224
In order to enable this function, you will need AU-101 / AU-102 Biometric Finger Vein Authentication Device. These biometric finger vein readers connect directly to the MFP and work in conjunction with the machine's internal authentication capabilities, or integrate with Konica Minolta's PageScope Enterprise Suite.
Konica Minolta Error Codes & Solutions - http://www.kmcodes.com
Drum, Transfer Belt and Fusing Unit Firmware Reset - http://www.bizhubreset.com
Drum and Toner Chip Reset - http://www.chipreset.eu
Transfer Belt and Fusing Unit Reset Kit - http://www.resetkit.eu
Aug 19, 2014 | Konica Minolta Bizhub C224 Color Copier /...
Konica c2253
One of the drums is unable to turn, pull each one out. check them, physical turn drum make sure you turn them correctly, and use the edge of the drum not just put fingers on any part of the drum, might. one at atime hav to get a color drum and black drum they are different and replace the black if not that the replace the color one
Jun 23, 2014 | Konica Minolta Bizhub C360
THE KONICA MINOLTA C360 COPIER SHOWS ERROR CODE C6103
• Scanner home sensor (PS201)
• Scanner motor (M201)
• Scanner relay board (REYB/SCAN)
• MFP board (MFPB)
Scanner is located under the big glass. reset open close right door
Jan 21, 2014 | Konica Minolta Office Equipment & Supplies
Can i repair a developer unit of the konica minolta C360, the parts are so expensive
yup , u can repair it if you have enough knowledge and resources of the parts...
Oct 12, 2013 | Konica Minolta Bizhub C360
I have changed the setting of the dev unit of the Konica minolta C360 to No life But it still says replace unit. The printer is still giving excellent prints
it continue to showing this error and u have to press ok
just make prints till print are coming ok
after that u have to change unit
Aug 06, 2013 | Konica Minolta Bizhub C360
How to solve model c360 konica minolta the printer displaied change image transfer belt
There are two ways to solve this issue, First you can replace the whole transfer unit or you can install a new un blown fuse to rest the internal counter.
Nov 19, 2010 | Konica Minolta KONICAMINOLTA Transfer Belt...
Feb 11, 2010 | Konica Minolta bizhub 350 All-In-One Laser...
242 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Ben
Ben
David Burkhart
David Burkhart
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
