Question about Schwinn Exercise & Fitness
Looking for Endex Motor Control Board DCMD76 for Schwinn Treadmill
Getting E1 error code, after pressing start the belt moves about 8 inches and stops. the Motor, Fuses are alright.
  • 64 Answers
SOURCE: Treadmill runs then stops. E1 error and sometimes works fine.
Yes if speed sensor is too far from magnet it will not pick up belt movement. This confuses the computer and as a safety precaution it shuts the machine off. Find speed sensor and check for proper alighment with magnet.
Posted on Jun 08, 2009
SOURCE: tredmill error code e1
Trimline treadmill starts up then code E2 comes up, and the display shuts down.
Any ideas???
Posted on Dec 20, 2009
SOURCE: I have a horizon fitness, Quantum II treadmill.
im having this problem too if some one could email me how to fix it @ djbense@hotmail.com
cheers
Posted on Feb 26, 2010
  • 33 Answers
SOURCE: I have a BH treadmill that has an E1 Error messgae...
Your problem might be that a magnet has fallen off. Here's an illustrated guide that should make fixing it easy: http://fixmytreadmill.blogspot.com/2010/10/how-to-fix-treadmill-e1-error.html
Good luck.
Posted on Oct 09, 2010
  • 33 Answers
SOURCE: E1 error code
Your problem might be that the sensor magnet has fallen off. Here's an illustrated guide that should make fixing it easy: http://fixmytreadmill.blogspot.com/2010/10/how-to-fix-treadmill-e1-error.html
Good luck.
Merit 725 T plus reading E1
If you wish to get some details about treadmill error codes and repair; check the site linked here. Pull up older posts. http://electro-medical.blogspot.com/
Nov 28, 2016 | Exercise & Fitness
I keep getting an e1 error on the display.
Hi normally this error is coming from speed sensor in the main motor, and problem with the motor.
see the attached video. LED Blink Patterns on the Control Board Treadmill
Blessing
cuadra2016@yandex.com
cell+whatsAPP:+50588611441
Dec 14, 2017 | Nautilus T516 Treadmill
Endex dcmd76
This sounds like a Bodysolid brand machine - you can contact the MFG directly at this number
TECHNICAL SUPPORT
Available M-F 9:00am to 5:00pm CST
Toll Free - 800-556-3113
Fax - 708-427-3598
Dec 03, 2013 | Endurance T3 Treadmill
Cardiotech x7 e1 code
test the input terminal motor, if there are the motor is faulty, see my personal TIPS 2) test the output voltage from control board, if there ARE NOT for input voltage motor, the board is faulty. see the diagram attached. 3) the error coming from speed sensor, Run the software calibration for easy diagnostic and fix it. However you must LUBE the deck belt,+rollers bearing front +back see the video attached.
God bless you
Nov 27, 2013 | Exercise & Fitness
Endex DCMD 57 Treadmill power board, will not power up, cuts out almost immediately.
Hello from Greece!
If you see the red led (D1) on when you press the start button on your treadmill you have a short-circuit on your 20N60 transistor. replace this transistor and your DCMD67 circuit board will be new! but be careful, if this happen on your circuit board, In about 90% you must have problem with your treadmill motor or your treadmill belt.
If you have any other question just mail me.
Have a great day!
Oct 04, 2013 | Exercise & Fitness
Motor not going on York Optimum 60100 - after a while E 1 appears
Dear Sir:
This is probably a 1) faulty speed sensor or 2)the speed sensor is not plugged in properly. Its also possibly a 3) faulty motor control board or lower board 4) Main motor faulty. . The error codes will differ between makes and models but could be e1.You must test
see my personal TIPS for diagnose and troubleshooting.
See if you can run the software calibration for diagnose and trouble.
sincerely. God bless you.
ernesto cuadra
managua, nicaragua. c.a.
Mar 05, 2012 | York Exercise & Fitness
E1 error code
Lets eliminate the motor first, unplug unit remove motor shroud fin the 2 leads from motor to lower board. Connect a 18v DC battery to the leads this start the motor to move at approx. 1 mph if it does motor is good,if not you may worn motor brushes worst case open connection in the motor.
Now if the motor is good then reconnection the leads and plug in unit the lower board should have some LEDs lit up. Now find the LED that says PWM start unit if that light should start to flicker then the upper board and wire harness are work properly. Turn off the treadmill then turn it on and with a multi meter insert the leads into the connectors that go to the motor, then put the meter on 200v DC then start the treadmill you should get a reading 5 to 10v DC if you get 0v DC then the board will need replacing
Jul 07, 2010 | Cardiozone Supersport Hr Club Commercial...
I have a v-fit PST-04 treadmill, model no DK 2510. When I switch it on and try and use it, it comes up with the Error Code E1 what does thos mean
Most E1 codes are speed sensor or no belt movement.
You wil lneed to unplug your unit the remove the motor shroud then plug unit in most Motor Control boards have LEDs. First thing I would do is start the unit look down at the board one of the light should start flickering this is a signal being sent to the lower board from your upper console. This tells me that the upper console and cable connecting the upper and lower boards is working also notice if the drive motor moved if not then E1 will come up. Now turn your unit off then turn back on to reset , next manually push with one of your feet the belt you should notice another flickering light the faster you push the light will flicker faster this tells me that the speed sensor is working if not replace the speed sensor. Next procedure check the motor using a fully 18v drill battery or car battery which ever is handy connect the two motor leads usually red and black in some cases black and white to the battery, if the motor move at a speed of approx. 1 mph then you have a good motor if not you can have worn motor brushes or open winding the motor.
If the upper board and drive motor are good then the only thing left is the motor control board if you have a multi meter handy connect the lead to the two spades that motor lead came off of the press start you should get a DC voltage of about 5 to 10V DC if not replace the board.
May 31, 2010 | Exercise & Fitness
E1 error code
Good luck.
Jun 20, 2009 | Exercise & Fitness
Tredmill error code e1
Any ideas???
Apr 02, 2009 | Nautilus Tr300 Treadmill
Exercise & Fitness Logo
181 people viewed this question
Top Schwinn Exercise & Fitness Experts
Steve
David Payne
David Payne
Matt Olenzek
Matt Olenzek
Are you a Schwinn Exercise and Fitnes Expert? Answer questions, earn points and help others
