Question about Dishwashers
Dishwasher LG ld-2120wh has a F on the Auto switch, what does this mean
  • 3,512 Answers
It means that is testing the washing cycle , It uses only what it needs to use of your powerball dishwashing detergent by testing the water . The F is displayed while it tests the water in the dishwasher to determine how much detergent it needs.
Posted on Apr 15, 2014
My lg Le 1415m1 has limited flow pressure have replaced wash pump motor still did not fix
LG LD-1415M1 Support: Find Manuals & Warranty Info ' LG ...
www.lg.com/au/support-product/lg-LD-1415M1
LG ElectronicsProduct Support. Home Appliances; Dishwashers; LD-1415M1. LD-1415M1 ... What should I do Low Rinse Aid indicator lightens up? Why is water not supplied ...
LG ElectronicsHome Appliances; Dishwashers; LD-1415M1. LD-1415M1. Search For ... What should I do when dishes are kept in a dishwasher after a cycle? Are plastic or ...
Nov 19, 2015 | LG Dishwashers
HOW DO I GET A MANUAL ON HOW THE DISH WASHER WORKS
Try MFG customer service or google make model or try:
http://www.manualslib.com/
Mar 13, 2015 | LG Dishwashers
Dishwasher LG ld-2120wh have F on the Auto switch, what does this mean
F is displayed when the dish washer is testing the water to see if more dishwashing powder should be used when in Auto mode. To do with saving the environment to use the least amount of detergent
Apr 15, 2014 | Dishwashers
Operating manual for L G LD 2120WH dishwasher
You may download a copy of the manual from here.
Sep 18, 2012 | Dishwashers
I have an LG dishwasher, Model LD-2120WH and lately it starts" -- water goes in but it throws up a E1 message on the display screen, send off an alarm and stops
I've just solved the same problem on my 2120. It started when the pump motor bearing failed and continued after I'd replaced the bearing. According to my handbook the E1 fault is theoretically a water leak but practically it is that the pump is not delivering enough water. In this case the failed bearing had allowed the shaft to wobble about and damage either the rotor or the inside of the pump (it's sealed so you can't strip it). Solution was to replace the pump.
Paul H
Nov 08, 2010 | LG Dishwashers
How much salt do you have to place into LG
just use dishwasher tabs.no salt needed or rinse aid,lots greener too...
Sep 19, 2009 | LG Dishwashers
Dishwasher states there is a water leak when visually there isn't
Assuming that you have checked under the dishwasher for a leak (through a faulty sump gasket):
Since there is not actual leak, check the following:
-Confirm that the height of Drain Hose connection (sink-Drain Hose) rises greater than 20′ _minimum_ as it travels to the drain connection.
-If that does not solve the problen, it is probably a worn/broken Impeller of the Washing Pump.
Unless you are mechanicly incliend, a service call is probably the way to do. If you need further steps, please reply. Otherwise, after you ahve used the advise, please accept this solution.
Mar 28, 2009 | Dishwashers
LG dishwasher model LD-14AT2
normally means not heating check element and use less soap
Nov 25, 2007 | LG 24 in. LD-12BW5 Free-standing...
Dishwashers Logo
107 people viewed this question
Top Dishwashers Experts
Owen Barnes
