Question about Emerson SpongeBob SquarePants TV
Spongebob tv ge universal remote code
I have a ge universal remote no codes are working help
  • 979 Answers
SOURCE: spongebob remote
Contact Emerson Electronics customer service to acquire a replacement remote for this set, as this set does not have the extensive circuitry inside to duplicate the functions of said remote...accordianman
Posted on Oct 20, 2007
pjszilard
  • 72 Answers
SOURCE: Which brand of universal remote control works for WEF2702 27" TV?
Try to call the phillips costumer service first!
Posted on Nov 11, 2007
ebrus
  • 30 Answers
SOURCE: Emerson Spongbob tv broken remote...cant change input?
Then the only way to reach your tv is through coaxial antenna port. So you can buy an rf modulator ( very cheap) and connect your red yellow and white cables (rca cables from a dvd, game console etc) to the modulator then connect the modulator to your antenna with a coax cable. This worked for me.
Posted on Oct 15, 2008
SOURCE: universal remote codes
here are some codes that might work 0456-0004-0009-0044-0135-0049 the first one might be it if you don't know how to set it here's how press setup and hold it until the light stays on then press t.v. and then the code. hope this helps
Posted on Oct 31, 2008
e-Guru
  • 3917 Answers
SOURCE: I have a spongebob TV
Please contact Fox-International.com for replacement remote. it's where I got mine or
just get a generic remote and any tv shop .
Actually I found there are several remotes that work. The first is the Bright House networks remote, the larger one that they provide you when you get digial service.
The second is The Universal Remove Control by GE. It's numbered 24944 in the upper right hand corner of the paper. It's sold for $4.94 at Walmart in the checkout area...
I found that manually inputting the code for the remote doesn't work. You have to do a search for the code using their method...on this particular remote from Walmart, its hold the setup button down until it lights up, then press and depress the TV button...then press channel up until the TV changes channels. It worked once, but I just kept going, the 2nd time it worked, then I pressed the mute button [to keep the code] and it works...you simply press input and it switches to AV.
I have to admit I thought it was ridiculous that you can't use this particular TV without the remote, but I was happy that I went through the effort the first time to keep trying remotes...
This is the first kids TV that I have found that you can't find the AV channel by going through the channels AND you can't hook up two items to the AV outlets because you have to disconnect the back or front ones, to use the other....PLUS it only comes with a dual AV outlet, instead of the 3 plugs [red, white, yellow] only has the white and yellow.
Thanks for contacting Fixya.
Posted on Jul 01, 2009
I have a ge universal remote and my tv is a Magnavox can I find the code for my tv with this remote
You can use code search to find something that works. If a search through all codes stored in the remote fails, you may have to try a different universal remote (such as Philips). All universal remotes do not store all possible codes.
Jul 07, 2016 | GE Televison & Video
How do you program it to a GE universal remote
these are the codes
LG: 004 005 009 012 050 057 080 156 227 338
  • How to Program a GE Universal Remote ' Techwalla https://techwalla.com/content/program-ge-universal-remote Lost your Remote? Need help programming your GE Universal Remote? Most TV's, VCR's, DVD Player's, Cable and Satellite Boxes will work with a GE universal...
  • How to Program GE Universal Remote: Quick Steps www.brighthub.com > Electronics > Home Theater > Home Media 2011-04-18 · How to Program GE Universal Remote Using the Code Search Function. If you've tried the codes listed for your device brand and are unable to get your ...
  • GE Universal Remote Codes and Instructions ' direcTutor www.directutor.com/content/ge-universal-remote-instructions Goto GE remote Codes. Direct Code Entry for GE remotes with 4 digit codes. 1. Manually turn on the device (TV, VCR, DVD, etc.) you wish to program.
  • How to Program a GE TV Remote ' Techwalla https://techwalla.com/content/program-ge-tv-remote GE universal remote controls allow users to program multiple devices onto a single remote. The remote control uses codes to detect the device, and you can...
  • GE Universal Remote Quick Start Guide - YouTube Youtube
    • BY JASCOPRODUCTSCOMPANY
    • 3 MIN
    • 216K VIEWS
    2013-04-18 · Video embedded · http://www.jascoproducts.com Eliminate remote clutter with GE Universal Remotes
  • How to Program a GE Universal Remote Control ' eHow www.ehow.com > Tech > TVs > Remote Controls
    • BY EHOW ELECTRONICS EDITOR
    Programming a Jasco/GE Universal Remote Control takes about seven steps. As with programming other remotes, you need to know the code of the component you are ...
  • May 09, 2016 | LG "32"" inch New 2011 HD LCD TV With HD...
    We have a naxa converter box with a GE universal remote searching for the code
    About 17,100 results (0.72 seconds) Search Results
      Enter the three or four digit code for your device using the number buttons in the GE Universal Remote. After your code is entered the INDICATOR LIGHT will ...Missing: naxa
      Apex Digital TV Converter Box DT250 code ' ManualsOnline ...
      tv.manualsonline.com/support/...digital/tv-converter-box/code-1082992
      Nov 15, 2008 - Brock Search data: Universal remote control code apex dv converter... 4 I NEED CODE FOR APEX CONVERTER BOX FOR GE UNIVERSAL ...
      Trouble programming Universal Remote to a DTV Converter ...
      www.fixya.com/.../t2045188-trouble_programming_universal_remote_d...
      Apr 21, 2009 - So I'm trying to program my GE Universal Remote to work with my Digital Stream Converter Box but I can't find the codes to do it... If someone ...
      Control It All With Universal Remote Codes - Digital Landing '
    Feb 08, 2016 | GE Televison & Video
    I need help i have a GE universal remote RC430A Date code1636 I need to program the remote to the tv but i don't have the code. Please help.
    Look inside the battery compartment and check the label. There may be a version code listed on that label. The GE remotes were manufactured by Jasco and the code lists are here: http://jascoproducts.com/support/ge-universal-remote-codes . Use the correct code list for the version for your remote. Note: these codes work for remotes sold in 2006 and later. For older GE remotes that use a 3-digit code, try this site: http://www.eliztech.com/remotes/ge-new-3digit-tv-codes.php .
    I hope this helps.
    (the remote control codes will often be limited to TVs that were sold at least 6 months before the remote was programmed. If your TV is newer than the remote, you may need to update your universal remote.)
    Jul 10, 2015 | GE Televison & Video
    Universal remote code for spongebob tv
    I doubt you will find any that work---no one so far has--Google for a replacement remote other than the universal.
    Dec 03, 2012 | Emerson SpongeBob SquarePants TV
    Lost remote will universal remote work
    Universal remote codes for Emerson Brand TVs are: 0004 0009 0044 0135 0049 0051 0189 0053 0147 0039 0130 0227 0233 0250 0252 0254 0257 0265 0266 0310 0325 0456 0040 0041 0042 0021 0023 0024 0179 0045 0025 0027 0030 0032 0034 0035 0037 Buy one universal remote control, which have these setup codes with its attached code list. Such remote controls will work with this TV.
    Oct 26, 2012 | Emerson SpongeBob SquarePants TV
    Where can i find a remote control for a spongebob television?
    Try website like Remotes.com to buy the exact same remote.Don't tries universal remote on this tv,there no codes for it,because these tvs was limited production tv for Disney corporation.
    Sep 04, 2010 | Emerson SpongeBob SquarePants TV
    GE Universal Remote
    here are the codes, 020,024,028,030,186,187,096,054....hope this helps....
    Apr 27, 2010 | Universal Remote Control GE174Universal...
    Lost sponge bob tv remote control
    Get the RCA 4 device universal remote from radio shack. model #RCR4383N $10.00. It wouldn't work using the emerson codes in the manual. Let it find the code automatically. input button on bottom will switch to and from AV input.
    Oct 10, 2009 | Emerson SpongeBob SquarePants TV
    Help me find a code
    http://www.xdiv.com/remotes/ MAYBE THIS SITE CAN HELP U IT HAS ALL THE CODES FOR UNIVERSAL REMOTES JUST LOOK FOR YOUR REMOTE BRAND.
    Jan 14, 2009 | GE RM24912 Universal Remote Control
    Emerson SpongeBob SquarePants TV Logo
    97 people viewed this question
    Top Emerson Televison & Video Experts
    matt martin
    matt martin
     Grubhead
    Grubhead
    Are you an Emerson Televison and Video Expert? Answer questions, earn points and help others
