Question about Exercise & Fitness
Healthstream treadmill error code 91
When high speed Mc auto stop
  • 246 Answers
SOURCE: I have a healthstream treadmill model LS3T and it
if you take the motor shroud off the front of the treadmill, you'll find wiring and connectors. check them and make sure none are loose, cracked, corroded, pinched, rubbing, or frayed and touching metal. also check under the display, there should be an access panel you can unscrew and remove to check the connections in there as well.
Posted on Feb 17, 2010
maxtreadmill
  • 832 Answers
SOURCE: speed sensor error
Your speed sensor may have failed and cause this condition Call Accell Fitness Of North America @ 1-888-388-6887 they are the Tunturi Distributors
Posted on May 06, 2010
maxtreadmill
  • 832 Answers
SOURCE: treadmill stop then display an error speed
If the is a Next Gen unit need to enter Diagnostic menu by pressing and holding pause then press clear twice. Continue to hold pause until until read service menu. press any arrow up and select system test ,then press enter the display will begin to automatically scroll thru available options. press enter to access Main Motor Module the next window will be Speed Automatic.
Upon entering this test mode you will able to check the drive motor and motor control board. By using the the speed arrows you will be able see the actual speed if functioning if not it could possibly be the speed sensor or wire harness ( SIMPLE CONTINUITY CHECK WILL RULE IN OR OUT THE HARNESS ) and point the problem. Now if their is no belt movement then hit clear and proceed over to SPEED CONTROL ERRORS hit enter this test allows seeing the motor controller conditions that are being displayed on the motor controller display if any of these come up then the controller need s to repair or replaced:
Max Temperature, Maximum voltage, Fault Line 1 error, Static current trip and dynamic current trip ( this also can a running belt tension this can result in a cannot obtain speed error message ) hit clear to get out of diagnostic once you eliminated the problem. Good Luck!!!
Posted on May 21, 2010
  • 15 Answers
SOURCE: the treadmill stop when i increase the speed and t...
Error 26 is what's known as a Motor Pulse Width Incorrect. It basically monitors the sensor signal and verifies that it's appropriate for the requested speed. If your machine uses an infrared sensor, check the line of sight between the optical eye and the sensor target, an array of black and silver wedges arranged like a pie. Ensure that it is 3/16" apart and that it's pointed at the larger point of the wedge section. Use an electronic cleaning compressed air cleaner to blow out any particles that could block it. Have a close look at the target, if it's torn or badly scratched, it will need to be replaced.
If the machine uses a hall effect sensor (magnetic) ensure the distance between the flywheel tooth and sensor is 3/16".
You can sometimes get this error if the speed sensor is faulty, but usually it will happen without you even touching the controls at that point because the lower board isn't receiving any signals from the sensor, or you will get a different error code.
Posted on May 28, 2010
  • 218 Answers
SOURCE: how can fix my healthstream LS720T treadmill?
You will need to check the speed sensor for proper alignment and function. it should be located near the front roller or mounted on the motor. It should be within a credit cards width of the magnet or toothed wheel. If properly adjusted check with an ammeter to see if it is opening and closing by manually spinning the front roller or motor flywheel. If it isn't replace the sensor. If it is functioning make sure you are getting 5vdc to it across the wires. If you are not replace the upper control board(console). If you are getting the proper voltage then replace the lower control board(motor controller).
Posted on Aug 11, 2010
Testimonial: "awesome!!!! just briliant.........i just follow the procedure do a bit of adjustment then presto!!!problem solved !!!! thanks a lot !!!!!!!!!!!"
How do I fix E7 error message on Healthstream Elite treadmill?
If you wish to get some details about treadmill error codes; check the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/
Aug 04, 2016 | Exercise & Fitness
Healthstream Evo Treadmill. When I turn machine on, all I get is 3 Beeps. The screen display has 8 rows,The 6th row is fully on. The bottom the alpha numerals,the center led of each unit is also lit.
Sounds like a fault in in the treadmills computer system the beep3 are error alert sound meaning somethings has gone wrong inside or the motor is reporting jamb fault code etc and its displaying with the lights upon the display board an error code a treadmill enginer will understand
Jul 12, 2016 | Washing Machines
My treadmill runs for 9 secons and stops and shows E1
Ok. So the first thing to try is to calibrate the speed.
You do this by doing the following:
  • With the SAFETY KEY in place, hold the ELEVATION UP and SPEED DOWN buttons for five seconds. The console will beep twice, "ENG0" will appear in the Distance window, and a number will appear in the Elevation window.
  • Press SELECT until "ENG3" appears; this is for Auto-Calibration.
  • Press START to Auto-Calibrate.
  • The treadmill will calibrate minimum and maximum speed, and minimum and maximum elevation. When Auto-Calibration is complete, the treadmill will reset to User's start screen. This process takes three to five minutes.
Make sure there are no errors. . .and that the speed goes from super slow to super fast and then stops. . .. if it stays slow. . or stays fast. .or error code appears during calibration, there is a problem.
If after a good calibration sequence, if it still does the stopping and E-1 after 10 seconds. ., then you need to (Power off and disconnect treadmill). . .then unplug the speed sensor from the lower power board, blow into the connector on the wire, and add a little contact cleaner spray to the connector on the board.
Recap: If it actually runs. . .but stops after a few seconds. . but the calibration runs and passes fine. .. .more than likely it is a speed sensor misread or a faulty speed sensor.
Sep 30, 2014 | Triumph 400T Treadmill
Healthstream manual I have a GE3400T healthstream
go please to www.fitness.manualsonline.com or www. retrevo.com
and download for free.
God bless you
Oct 31, 2013 | Exercise & Fitness
Healthstream gold series model no GS1160T is coming up with E1error code. What does this mean? Treadmill will run for a few seconds then switch off
ERR 1 - Motor Movement
ERR1 indicates a speed issue. In this case, the motor speed as reported from the optic sensor differs
from the speed setting.
Analysis: Optic sensor signal issue -- Either the optic sensor signal is not right, or it is read incorrectly, or
the signal is not reaching the display.
Adjust the Speed sensor according . Test for open or faulty458ecb9c-392b-4a17-8105-4b76ec52d9b4.gif192107ed-2567-439d-9172-83a32cb4381b.gif
May 31, 2013 | Exercise & Fitness
High speed and error 91 and treadmill stop
Please recalibrate the machine with software calibration, for easy diagnose, troubleshooting and fix it
If the problem persist, you must need some basic parts or need service for repair. See hte block diagram attached.
God bless you
Jan 07, 2013 | Kettler TX1 Treadmill with FREE INSIDE...
I have a T802 Healthstream treadmill that has an error 2 on it? Can't clear it.
follow this steps and fix it. God bless you
Instructions
    • 1 Unplug the treadmill. Locate the console key and place the safety or reset key into the treadmill console. Replace any parts that need replacing, or move on to the next step.
    • 2 Locate the reset switch on the underside of the treadmill console. Usually the button is large enough to trigger with a pencil eraser or Q-tip. Plug the treadmill plug back into the wall. Use the Q-tip to press the reset button. It may be necessary to hold the reset button down for a few seconds. "CL11" will appear in the display of the treadmill.
    • 3 Press the reset button one more time with the Q-tip. "CL21" should appear on the screen. Press the enter key. The display will change again and show "CL22." Keep pressing the enter key until the numbers cycle through to the number "CL26." Press enter one more time. The letter E should appear on the display screen.
    • 4 Press enter twice more. The letters "SS" should appear on the screen. When this happens, press the start/stop key. Making sure to keep well away from the tread, press enter to start the treadmill. The treadmill will start on its own. The treadmill will stop on its own after a few seconds. When it stops, press the power key two times. Remove the safety key and put in a safe place. Your treadmill is reset.
Oct 15, 2012 | Exercise & Fitness
Healthstream Elation HS 2200T - E3 code - incline not working
1) Lube the shaft and gear from elevation motor
2) Tight the connection motor very well.
3) Adjust the potentiomenter from elevation motor
4) Measure the voltage input.
5) Try to RUN the software calibration for diagnose, and troubleshooting see the block diagram.
God bless you
Jun 13, 2012 | Exercise & Fitness
Error E6 on Healthstream treadmill
If you wish to get some details about treadmill error codes ; check the site linked here. Pull up older posts.
Mar 16, 2012 | Exercise & Fitness
How can fix my healthstream LS720T treadmill? my healthstream LS720T treadmill after i turn it on it slowly run then it will go faster then stop and will indicate error message E1, what is wrong with it?
Jul 30, 2010 | Exercise & Fitness
Exercise & Fitness Logo
Top Exercise & Fitness Experts
Electro Med Services...
Howard
Howard
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
