Question about OEM Achi Ir 6000 Ir Pro Replacement Thermocouple Upgrade
Replacement Thermocouple for ACHI IR 6000 - OEM Achi Ir 6000 Ir Pro Replacement Thermocouple Upgrade
Error e350 canon ir 6000
pls help canon ir6000 error E350-3000 solved the problems
Jun 27, 2012 | Canon Service Manual For Ir 6000
Canon ir 6000 service support tool
I need sst firmware of canon ir6000 can anyone help me out my email id is orangeinfotech13@gmail.com
Jun 06, 2012 | Canon imageRUNNER 5000 Copier
My oven is on warming mode from last six hours. Please adivse
First, check the back of the oven. See if the lil red button can be pressed in. Then check the IR Element, usually you can see the wires burned or damaged where it enters the oven by the snap rings. This was a design flaw from the manufacturer of the element of which turbochef has taken care of.
COMPONENTS
IR Element
The IR element - a dual coil type heater - is located
in the bottom of the oven cavity. The first coil is the
heating coil. The second is the IR thermocouple
wire. The heating coil outputs 3000 watts at 208
VAC. The heating coil's resistance is 14.4 ohms at
room temperature.
The thermocouple coil is a Type K thermocouple
with a resistance of approximately 20 ohms at the
splices located approximately 6 inches from the
heater and 40 ohms measured at the extension wires
at the I/O control board.
The IR element is controlled via the K5 solid state
relay and the IR thermocouple via the I/O control
board.
Its typically an easy quick fix.
Nov 02, 2010 | TurboChef TORNADO Electric Oven
Tornado ngc oven has an F6 code. IR heats up to 1160 degrees but never says ready
unplug oven. Discharge Caps- if you don't know how to do this stop here and call a professional.
push the small red reset switch rear lower corner of oven. IR is a little higher than i like to see.
Test electrical compartment thermal-couple. located under top cover about 2 inches from the rear in center.
Test Electrical compartment cooling fan.
EC Thermocouple (P/N 700-1199)
Type K Thermocouple. Thermocouple measures the
temperature of the electrical compartment. If the
temperature within the electrical compartment is
above 158?F (70?C), the control displays F6: EC
TEMP. The control board checks the EC temperature
every 60 seconds.
Oct 26, 2010 | TurboChef TORNADO Electric Oven
How to fix F7 in turbochef
F7: Thermocouple Open
CC Thermocouple
Reads 999?F/C or
IR Thermocouple
Reads 1999?F/C
1. Check the connection of open thermocouple on the I/O control board.
If the connection is OK, verify thermocouple is not an open circuit
by using your ohm meter. The cook cavity thermocouple should
measure approximately 4-5 ohms and the IR thermocouple should
measure approximately 30-40 ohms. Measure at the I/O control board
40-pin connector.
o Thermocouple indicates open circuit: Replace defective thermocouple.
o Thermocouple OK: Replace the I/O control board.
Oct 04, 2010 | TurboChef TORNADO Electric Oven
F2 low temp
The most common probem is burned wires going to the heater on the top of the oven cavity. Typically you will see the coating on the wire close to the heater all cracked and bare. You can usually just cut the wire back an inch and pull some slack up and reconnect the wire and you will be good. In some cases the wire will be burned to much and the whole wire will need to be changed. Any oven repair shop will sell you these high temp wires. DO NOT use regular wires they MUST be high temp rated.
Here is some other things to check if the heater wires look good.
COMPONENTS
IR Element
room temperature.
board.
Also try this
1. Verify the high-limit thermostat is not tripped.
o If high-limit is tripped, reset and allow the oven to warm up.
o If high-limit is not tripped, follow the instructions below.
High-limit thermostat is not tripped.
Place a small water load in a microwave/heat-resistant container
(approx. 275 ml) in the oven and place the oven in TEST MODE. Press
the MGTRON key to actuate the microwave. While holding down the
MGTRON key, watch the CC and IR temperatures. If either temperature
bounces substantially, there may be a noise (EMI) problem.
To correct this problem, examine the wire routing for each
thermocouple wire. If the wires are routed near any high voltage
components such as the magnetron or high voltage transformers, reroute
the wires. If this does not correct the problem, verify that both
magnetrons are securely mounted.
Good Luck
May 20, 2010 | TurboChef TORNADO Electric Oven
Ir5000
sst itu Service Support Tool kl sm apa ya? kalo mau sst nih linkya
http://techchatter.servehttp.com/yabbse/index.php?topic=356.0
n nih frmware ir 5000-6000
http://rs147.rapidshare.com/files/197499533/__304_R5000-6000.rar
Feb 01, 2009 | Canon imageRUNNER 5000 Copier
ERROR c-6000
Hi, enter 10871087 on keyboard of machine, then enter 163.After that press "execute" and start button.machine will restart and will be ready to copy.Otherwise,call service.
BR
Jan 26, 2008 | Kyocera RI-3530 Black and White Copier
OEM Achi Ir 6000 Ir Pro Replacement Thermocouple Upgrade Logo
432 people viewed this question
Top OEM Plumbing Experts
Donni Steen
Tom Chichester
Are you an OEM Plumbing Expert? Answer questions, earn points and help others
