Question about Janome Magnolia 7330 Sewing Machine
Magnolia 7312 Was sewing and went away for 5 minutes. When I returned the bobbin casing didn't spin anymore. Any ideas? The area appears clean and no stray threads.
Bfsas1
  • 258 Answers
SOURCE: Need to know how to thread the bobbin
Hi there noticed you still need help and have been asking for quite sometime, so I am going to try to help you, also if you have no luck on the websites below try asking a premium chat or premium question on fixya.com and you will get guaranteed assistance by our best experts but it might cost you $3-$10 but you will get fast guaranteed assistance ok and we will stick by you
try here, this might help, also ask yahooanswers a question on the top of this website......
http://answers.yahoo.com/question/index?qid=20090115223207AADSKXy
try this website below aswell and contact them to ask how to thread the bobbin, contact button on top of webpage ok
http://www.american-sewing.com/janome-magnolia-7312.html, your very welcome and good luck there, Brett, Fixya
Posted on Jul 01, 2009
Ironfist109
  • 3018 Answers
SOURCE: my Heart Truth 2008 sewing machine was sewing fine
  • Assuming you threaded your needle right I would start with looking at your bobbin. They do go bad and you could have that thread to tought around the bobbin. If you have a spare bobbin then string a fresh bobbin, and pull the old one out and replace with the new bobbin.
  • Also note that cheap thread will mess with a sewing machine something awefull. Had this Walmart thread one time that just tore and knotted. New quality thread took care of that.
  • Also bobbins are not a one size fits all. Make sure to use the same style bobbin every time. Again, as with thread, cheap bobbins are not always netter.
Regards, Tony
Posted on May 29, 2011
Gophering
  • 187 Answers
SOURCE: It stopped picking up the bobbin thread while
You can take the slide plate off, that your needle goes through and watch to see if the arm grabs the bobbin thread, if you can get it to pick up, than slide scissors or something flat under your needle and manually pull both threads through, replace the plate.
Your bobbin thread could be wound to tight or spliced threads on it, and your tension needs to be adjusted. If your using a pedal, try setting to a slower speed.
I would try a different bobbin and thread it manually as in the step I mentioned, if you can't see the arm grabbing it, you will need to check to see if you have loose threading jammed in youir machine, if this isn't the case and adjusting the tension dosen't help...than you will need to replace the bobbin casing.
Kind regards!
Posted on Sep 12, 2011
Tally Girl
  • 1128 Answers
SOURCE: janome memory craft 6500 sewing machine...all of a
Has the bobbin case dislodged and moved? there should be two red marks one on the bobbin case and one on the outer holder, are they lining up? Sometimes as these cases are held by a magnet, they will get dislodged and move slightly, especially in a jam up.
Take out the bobbin case and clean under it, then replace it matching up the red marks.
If the bobbin case has actaully been struck by the needle during a dislodgement, it may well pierce the bobbin case plastic, look for burring or marks on the outer flange area. If this has occured, the thread may catch on the burr as it comes over the bobbin and jam again.
You can buy a new bobbin case if yours is damaged or maybe just file the burring with an emery board (remove it from the machine first of course).
Lastly, check your needle hasn't been bent, burred, or put in backwards, any of these can prevent a stitch from forming.
If all the above fails, then it is possible that the timing has been knocked out and you will need to get it serviced by a technician.
Posted on Oct 17, 2011
SOURCE: janome 3000 bobbin thread will not catch. It just quit while I was sewing. I've cleaned the bobbin case and anything else I could but when I put the needle down the thread does not circle the b
try changing the needle
rethread the machine top & bobbin
make sure to use every thread guide
make sure the bobbin is not over wound
make sure the bobbin is turned the right way in the bobbin case
make sure the bobbin is not warped or damaged
if you've done all these things then it's also possible that the machine
is out of time & needs to be checked at a repair shop
Posted on Sep 03, 2012
My magnolia janome 7318 sewing machine is locked up and wont turn. What can I do?
Unless there is a wad of thread, lint, dust in the bobbin area that can be cleaned, your machine may need to be serviced.
Jul 07, 2017 | Janome Sewing Machines
My janome magnolia was working just fine and then all of the sudden the bobbin thread keeps knotting up. i've gone over all troubleshooting, cleaned out the lint, replaced the bobbin - all to no avail......
This happened to me on several occasions and finally one service tech told me not to use the needle down auto button. Instead when threading the bobbin just move the wheel toward you slowly until the thread catches.
Jul 08, 2014 | Janome Magnolia 7330 Sewing Machine
Bernina 1080 Solution for "back spin"? Top thread suddenly becomes very loose. Top thread forms loops under cloth being sewn.
Try these suggestions
1. Change the needle--use a needle that's for the fabric being sewed
2. Rethread the machine--top --make sure to use every thread guide
3. try a different bobbin--make sure bobbin is inserted correctly into the bobbin case
& make sure the bobbin is turned the correct way in the bobbin case
4. make sure the thread has not come off the thread take up lever
5. Clean under the needle plate & in the bobbin area for lint or threads
6. Check to make sure the bobbin is not warped or damaged
7. Make sure the bobbin case is correctly in the machine,, if it's a top loading bobbin you may need to have the bobbin case checked to see if it's damaged or see if the hook and hook race has a problem
8. Make sure the top thread tension is on the correct setting for the fabric being sewed.
9.Also could be a timing problem, and the machine would need to be checked.
Jun 05, 2014 | White Sewing 915
After 2 or 3 stitches needle gets locked with balled thread
Lint and or thread has collected behind or under the bobbin. use a q-tip (cotton) and swipe out and around the bobbin and bobbin case. Use a can of air and blow out and around the bobbin area. Remove the spool thread from the machine and rethread the spool and bobbin thread in machine.
Feb 03, 2014 | Janome Magnolia 7330 Sewing Machine
Machine eats bobbin thread
computerized so could be anything
tension or sewing action parts needs a service
Apr 28, 2017 | Janome Magnolia 7330 Sewing Machine
My machine will sew one or two stitches then the threads get all tangled under the plate. appears to be the top thread, not the bobbin
3. try a different bobbin--make sure bobbin is inserted correctly into the bobbin case, & make sure the bobbin is turned the correct way in the bobbin case
Aug 20, 2013 | Baby Lock Ellure
My Janome magnolia is 3 years old. Last week I was sewing and everything jammed, needle went to side and broke. It was trying to run but couldn't. I took bobbin out and cleaned it, oiled everything, where...
Try the process of elimination. Take out the needle, take off the needle plate, take out the bobbin case. Run the machine. Does if run full speed? You might have to let the machine run for about 5 minutes. If it runs slow or you hear it slow down, you might have a bad connecting link between the needle bar and the main shaft counter weight. They seize up sometimes. (Shop Repair).
May 03, 2011 | Sewing Machines
I've cleaned, oiled, bought new needles new thread new bobbins held the thread away 3-5 inches tried all tensions rethreaded ect.. and my thread always breaks when i start sewing...
clean under the needle plate where the feed dogs are for lint
also clean in the bobbin area for lint or loose threads
also check for burrs on the needle plate or on the bobbin & case
it could also be out of time
Nov 22, 2010 | Brother LS-1217 Mechanical Sewing Machine
I have a Huskystar C20 sewing machine and the bobbin case spins when i sew, causing the needle to hit it. How can I stop this?
Take off the needle plate. There is a bracket near the front right area of the bobbin case. It is the position bracket that supports the case. First smooth the case of any rough edges, the put it in place and loosen the screw of the position bracket and align it in an area that will keep the case from spinning. There should be about 0.5mm of distance available when you use your finger and push the case from left to right, between the case and the bracket. Remember that the thread flows through this area, the case is held in place by the bracket but not tightly.
Nov 19, 2009 | Husqvarna Viking 1
Need to know how to thread the bobbin on the Magnolia 7312!
Jul 01, 2009 | Janome MyLock 634D Mechanical Sewing...
Janome Magnolia 7330 Sewing Machine Logo
37 people viewed this question
Top Janome Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Irene Tulloch
Are you a Janome Sewing Machine Expert? Answer questions, earn points and help others
