Question about Snap Appliances Computers & Internet
Assign static ip/ Lost IP
I dont know the ip address of my old snap server 410. But I know the MAC address and Server number. I tried to reset it but seems my reset button is not working. Anyway to retrieve my ip address? Thanks.
    Master:
  • 680 Answers
It will be listed at the top.
http://www.whatsmyip.org/
Terry
Posted on Jun 21, 2015
4 Suggested Answers
  • 9 Answers
SOURCE: i can't connect to multiserver
well first let me ask you
your pc and the server are connected with the same conexion ?
are u using a dedicated fix ip or dinamic one ?
wich OS r u using (Redhat, FreeBSD, fedora, Unix...) ?
Posted on Nov 13, 2008
  • 17 Answers
SOURCE: It wont restart with a new IP address. Goes back to old one.
Hi there pls confirm whether you have tried to uninstall the network adpter and then restart ,or if physically the network adpter is installed in the PCI slot then change the slot and then reinstall I think this should workout or else the firmware for the server can be obtained frm HPupgrade with all the precaution as mentioned
Posted on Jan 24, 2009
MrObvious
  • 115 Answers
SOURCE: Remote Desktop via VPN problem
Make sure that the Active Directory setting for the User you are using to RDP with (LDAP FQN) has the remote access option turned on.
http://www.windowsecurity.com/articles/Securing_Remote_Access_Connections.html
Also make sure that the PC's you want to access have static IP addresses. Not sure if that was mentioned.
Posted on Jun 22, 2009
I'm using two Macintosh Computers. I followed the quick setup wizard, all the right lights are lit. I've reset my broadband modem, I've reset the Dynex Router. Yet I can't make contact...
Richard have you tried setting up static ip addresses on the MACs
If you have other p.c's on network with auto ip assignment then alter the DHCP server lease to 192.168.1.10 to 192.168.1.240
then make ip address static 192.168.1.241 subnet mask 255.255.255.0 default gateway 192.168.1.1 and on the other mac
make ip address static 192.168.1.242 subnet mask 255.255.255.0 default gateway 192.168.1.1
http://www.macinstruct.com/node/550
Jul 07, 2017 | Dynex DX-E402 Router
Tip
How to set up a static IP address in Windows Vista
Static IP addresses are often used for computers that host specific services, or for computers on small, manually managed networks. To set up a static IPv4 address on a Windows Vista computer, first find an IP address that is not currently in use and is outside the DHCP assignable range (if applicable). Then follow either of the procedures below.
From the taskbar:
1. Right click on the network connection icon in the system notification tray.
2. Select Network and Sharing Center.
3. Under Tasks, select Manage network connections.
4. Right click on the network connection that you want to set up the IP address for (Local Area Connection, Wireless Network Connection, etc.)
5. Select Properties.
6. If the User Account Control window pops up, select Continue.
7. Click on Internet Protocol Version 4 (TCP/IPv4).
8. In the Properties window, click the circle next to Use the following IP address.
9. Enter the IP address that you want to assign to the computer.
10. Enter the subnet mask and default gateway. (For small or home networks, these will typically be 255.255.255.0 and 192.168.1.1, respectively.)
11. Enter the IP address of the DNS server next to Preferred DNS server.
12. If you have an alternate DNS server, enter that IP address as well.
13. Click OK to save the changes.
From the Start menu:
1. Click the Vista orb.
2. Right click on Network.
3. Follow the procedure above from step #3.
Reserving an IP address under DHCP is different from setting up a static IP address. To reserve an IP address, log into your router's configuration utility and look for a heading such as DHCP or IP Address Distribution. You will probably need either the computer's Windows name or its MAC address to reserve an IP address for it.
on Jan 30, 2011 | Computers & Internet
Tip
IP Conflicts in a work place
An IP address conflict occurs when two computers on a LAN or the Internet have been assigned the same IP. IP conflicts between two computers normally render either one or both of them unusable for network operations.
How IP Address Conflicts Happen
Two computers can acquire conflicting IP addresses in any of several ways:
· A system administrator assigns two computers on the LAN the same Static IP Address.
· A system administrator assigns a computer a static IP address within the local network's DHCP range (dynamic IP range), and the same address is automatically assigned by the LAN DHCP server.
· A malfunction in the network's DHCP server allows the same dynamic address to automatically be assigned to multiple computers.
· An ISP accidentally assigns two customers the same IP address (either statically or dynamically).
· A mobile computer is put into standby / hibernate mode and then awakened later.
Note that other forms of IP conflicts can also occur on a network. For example, one computer may experience an IP address conflict with itself if that computer is configured with multiple Network Adapters. System administrators may also create IP conflicts by accidentally connecting two ports of a network switch or router to each other.
Recognizing IP Address Conflicts
On most Microsoft Windows computers, if you attempt to set a fixed (static) IP address that is already active on the local network, you will receive the following pop-up error message:
The static IP address that was just configured is already in use on the network. Please reconfigure a different IP address.
On newer Microsoft Windows computers having dynamic IP conflicts, you should receive a balloon error message in the Taskbar as soon as the operating system detects the issue:
There is an IP address conflict with another system on the network.
Sometimes, especially on older Windows computers, a message similar to the following may instead appear in a pop-up window:
The system has detected a conflict for IP address...
On Mac or Linux computers, a similar message will normally appear on screen.
Resolving IP Address Conflicts
Try the following remedies for IP conflicts:
1. For networks where IP addresses are fixed (statically assigned), ensure each local host is configured with a unique IP address.
2. If your computer has a dynamically assigned address, releasing and renewing its IP address can workaround IP address conflicts.
3. If your home router is believed to have a faulty DHCP server causing IP conflicts on the home network, upgrading the router firmware may resolve this problem.
on Nov 24, 2010 | Computers & Internet
Wireless connection goes of then will not connect
Hi
I get that you was connect to the internet by wireless connection .
so in you connect with access point connected directly to dsl modem so try to restart the access point and try to connect again ...and reset the wireless in your device... may be it works .
I think this problem occur cause access point or DHCP server cant give your device new IP address..
so you must clean the DHCP leased addresses by restart the access point or enter to server and do that from DHCP .
else you can try to assign static ip address has the same network id with router ..
for example : if router ip is 192.168.1.1 so you must assign ip address like :
192.168.1.x while x number between 2 and 254
hope that helps you
Apr 30, 2011 | Computers & Internet
I am having conflict ip in DHCP mode, I set a static ip still not list the server and not communicate with the network, how do I reset the device to factory settings?
There is no factory reset. If you set a static IP Address, you should be able to PING the L230 from another device on your network, i.e. the server. Please test that. Make sure the static IP address you assign to it is in fact available. Moving forward, it's best to turn on the Gratuitous ARP for your DHCP server so that it will verify if an address is already being used BEFORE giving it out.
Mar 12, 2011 | NComputing L230 Network Terminal
How to set my wrt300n router to use static ip,... i´ve have a problem whit my ps3, and want to use static ip, instead of dhcp(dynamic) should i do it before i do it on my pc and how to do it on the...
You may want to enable the DHCP reservation feature of the router.
What is DHCP Reservation and how do I configure it?
What is DHCP Reservation?
A DHCP reservation is a permanent IP address assignment. It is a specific IP address within a DHCP scope that is permanently reserved for leased use to a specific DHCP client.
You can configure a DHCP reservation in your DHCP server when you need to reserve a permanent IP address assignment. Use reservations for the DHCP enabled devices like print and file servers or other application servers which always have the fixed IP address on network.
Step 1: Access the router's web-based setup page. For instructions, click here
Step 2: When the router's web-based setup page appears, click Setup.
Step 3: Click on Basic Setup.
Step 4: Make sure that DHCP Server is Enabled. Then, click the DHCP Reservation button if you want to assign a fixed local IP address to a MAC address.
Aug 26, 2009 | Linksys WRT300N Wireless Router
The segement of the print server you select is different from your computer" on Vista,
Meaning that the IP Address of the print server is different from the computer's IP Address.
If you're computer has a static IP Address, you need to assign a static IP Address for your Print Server. To assign a static IP for the print server, you need to open the PSAdmin utility on your computer, locate the TCP/IP and click the plus (+) sign. Double-click the IP Address and you may change it from there.
Make sure that the IP Address of your computer, router and print server are in the same IP range. And make sure that you could ping the IP of the print server.
Then configure the printer port settings and you should be able to print.
Have a great day!
Jul 03, 2009 | IOGear GPSU21 Print Server
Cannot connect to AXIS 5600 print server
A Dlink's default IP range is 192.168.0.x, it would therefore hand out a address in that range. Since the router reports an IP of 10.43.14.125 I believe that it has been assigned a static IP Address. This is the manual.
https://www.axis.com/files/manuals/28049.pdf
You need to temporarily assign your computer an IP of 10.43.14.1
follow the instructions here
How to Assign Static IP Address in Windows 7 8 10 XP or Vista
Log into the printer server's webpage by opening your browser and going to 10.43.14.125
Turn on DHCP, save settings, reboot
Undo the changes you made to your computer. Reboot
Mar 06, 2017 | IBM AXIS 5600 (12r1361) Print Server
DPR-1260 ... prints but cannot access web config page
To get into the web configuration you need to know your firmware on the DPR-1260. If it is 1.12, us http://dlinkps-xxxxxx where the X's are the last 6 number of the mac address. If it is 1.20 and up, use http://dlink-xxxxxx, where the x's are the last 6 number of the mac address. If you do set it up as DHCP or static and know the ip address of the print server just type in the ip address of the print server on the address bar.
Oct 21, 2007 | D-Link RangeBooster G DPR-1260 (DPR1260)...
Computers & Internet Logo
235 people viewed this question
Top Snap Appliances Computers & Internet Experts
David Payne
David Payne
Are you a Snap Appliances Computer and Internet Expert? Answer questions, earn points and help others
