Question about Lexmark X2650 All-In-One InkJet Printer
Ec5 error code on lexmark 2600 printer - Lexmark X2650 All-In-One InkJet Printer
5 Suggested Answers
  • 320 Answers
SOURCE: Lexmark Printer/Scanner
Please mention your problem properly. To install a printer click on the below link or copy the URL and paste it in your web browser. Follow the steps.
http://kb.iu.edu/data/aksl.html
To download the drivers for your printer, Click on the below link and download the drivers. Select your operating system.
http://downloads.lexmark.com/perl/downloads/downloads.cgi
Thank you......
Posted on Sep 17, 2008
printmastert
  • 3344 Answers
Creating Customers For Life
    Verified Fixya Pro
    SOURCE: Can you furnish me the operating Instructions on my Lexmark 2600
    Here's the link to download the Lexmark X2600 printer User's Guide: http://www.lexmark.com/publications/pdfs/2007/2600/v7649663_en.pdf. Hope this helps.
    Posted on May 26, 2010
    printmastert
    • 3344 Answers
      Verified Fixya Pro
      SOURCE: hi my lexmark x2650 keeps
      The EC5 error code indicates a short has been detected in one of your cartridges. Open the printer and remove both cartridges. Close the cover. Unplug and replug the printer into the power source to reset it. When the printer turns on, reinsert one cartridge first. Close the cover and check for any errors. Open the printer cover again and reinsert the other cartridge. Replace whichever cartridge is causing the error to pop up. Or you can try to insert a different known working cartridge to determine if the other is faulty.
      Posted on Jun 01, 2011
      printmastert
      • 3344 Answers
        Verified Fixya Pro
        SOURCE: lexmark 2600
        A quick fix for most communication errors can be achieved by resetting the printer and/or rebooting the PC. Simply disconnect the printer from your computer (if USB connected)> reboot your pc > unplug and re-plug the printer into the power source to reset it. When the printer turns on, reconnect it to your computer (if USB connected). Then try to print again once the computer fully recognizes the USB connection or when the WiFi light on the printer turns solid green (if WiFi connected.).
        If that doesn't help, try the steps below:
        1. Disconnect the USB cable connecting the printer from your computer.
        2. On your computer, go to Control Panel > Printers and Faxes.
        3. Delete the Lexmark print object.
        4. Reboot computer.
        5. Re-brick your printer by pulling out the power supply - black box where the power cord is plugged into on the back of the printer, and re-plug after 30 seconds.
        6. When the printer turns on, reconnect it to the computer.
        7. Wait until your computer fully recognizes the USB connection. To check, go to Control Panel > Printers and Faxes. If you see a new Lexmark print object in the list, try to print a document to verify that the problem is fixed.
        You may also try to update your printer driver by visiting the Lexmark website at http://bit.ly/aNGYmW. Select your operating system, download and execute the file.
        Posted on Jan 13, 2012
        Lexmark service centre
        EC5 means short test detected: short circuit in printhead. The cartridge needs to be replaced.
        Oct 29, 2012 | Lexmark X2600 All-In-One InkJet Printer
        Wont let me print
        The error code "EC5" indicates a short in one of your cartridges. Please follow the steps below to identify and fix the problem:
        1. Make sure the printer is on.
        2. Open the printer cover. The print cartridge carrier moves and stops at the loading position, unless the All-In-One is busy. Note: If the carrier does not automatically move to the center, turn off the printer or unplug the printer from the power source and then carefully slide the carrier to the center.
        3. Remove both cartridges from the carrier.
        4. Close the printer cover.
        5. Re-brick your printer by pulling out the power supply - black box behind the printer where the power cord is plugged in to, and re-plug after 30 seconds.
        6. When the printer turns on, reinsert one cartridge first. Close the printer cover and check for any errors.
        7. If no error appears, reinsert the other cartridge. Close the printer cover.
        Replace whichever cartridge is causing the error to appear with a new genuine Lexmark cartridge. Try to print a document again to verify that the problem is fixed.
        Jan 07, 2012 | Lexmark X2670 All-In-One Printer
        What's C 5 E blinking in the printer screen?
        The EC5 error code indicates that there is a short in one of your print cartridges. Please follow the steps below to identify and fix the issue:
        2. Open the printer cover. The print cartridge carrier moves and stops at the loading position, unless the All-in-One is busy.
        Note: If the carrier does not automatically move to the center, turn off the printer/unplug the printer from the power source and then slide the carrier to the center.
        5. Re-brick your printer. Pull out the power supply, black box where the power cord is plugged in at the back of the printer, and put it back after 30 seconds.
        7. Close the printer cover and check for any errors.
        8. If no error appears, reinsert the other cartridge. Close the printer cover.
        9. Replace whichever cartridge is causing the error to appear with a new cartridge.
        Should the problem persists, please contact Lexmark Technical Support Center for additional assistance.
        Oct 10, 2011 | Lexmark X2600 InkJet Printer
        Hi my lexmark x2650 keeps flashing error code ec5, how do i correct this?
        May 30, 2011 | Lexmark X2650 All-In-One InkJet Printer
        I just replaced my ink cartiges and now it's flashes E C 5
        Hello. You can check the error codes that Lexmark printers show on this web page . . . . .
        http://support.lexmark.com/index?page=content&id=SO4438&actp=search&viewlocale=en_US&userlocale=EN_US&segment=SUPPORT&productCode=&searchid=1275158659149
        If your inks are new, just take the cartridge back to the supplier as sometimes a new one can be defective slightly.
        Most likely though, the error can be got around by taking the cartridge back out, and finding its copper contacts panel, and very very gently cleaning that with something suitable. Make sure that you DO NOT get any cleaning fluid on the actual print nozzles as this will cause chaos when printing later.
        I use foam cleaner, or SERVICOL spray to clean such things when working on them.
        I hope that helps.
        May 14, 2011 | Lexmark X2670 All-In-One Printer
        Printer wont print showing C 5 E on display
        EC5 error code indicates a short has been detected in one of your cartridges. Try to remove both your cartridges from the printer. Close the cover. Unplug and replug the printer into the power source to reset it. When the printer turns on, reinsert one cartridge first. Close the cover and check for any error. If none, open the cover and reinsert the other cartridge. Close the cover and check for any error. Replace whichever cartridge is causing the error to appear. You may also try to insert a different known working cartridge to determine if the other is faulty.
        May 04, 2011 | Lexmark X2670 All-In-One Printer
        My Lexmark X2670 has stopped printing on my MacBook and I receive the following error message Missing component: /Library/Printers/Lexmark/Drivers/.Resources/2600 Series Color 2.lut How do I fix this
        go to applications, utilities, and open terminal in the window, paste this: open /Library/Printers/Lexmark/Drivers/.Resources/ It will open the folder where the missing component should be. You will find the "2600 Series Color 1.lut" file. Duplicate it and change the name to 2600 Series Color 2.lut close the folder, and shoot a print, it should work.
        Mar 07, 2011 | Office Equipment & Supplies
        Problem with cartriges
        EC5 = Print Head Short. Short test detected short circuit in printhead. Fix is to replace print cartridge(s).
        Sounds like one or both of your new cartridges are defective and need to be returned to where you purchased them.
        Mar 02, 2009 | Lexmark X2600 InkJet Printer
        Lexmark 2600 printing problem
        You might try deleting the printer from the 'Printers and faxes' folder in the Control Panel, reboot with the printer connected and turned on. Win should 'find' it again and reinstall the driver.
        Dec 22, 2008 | Lexmark X2600 InkJet Printer
        Lexmark 2600 working well as copier but error USB cable to dell computer
        hmmm...that is a bit odd..
        does the 2600 work in standalone mode?
        Aug 20, 2008 | Office Equipment & Supplies
        Lexmark X2650 All-In-One InkJet Printer Logo
        79 people viewed this question
        Top Lexmark Office Equipment & Supplies Experts
        mukhtar21 shaikh
        mukhtar21 shaikh
        Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
