Question about Memorex MVD2016 DVD Player
Unit does not display movie
After clicking play unit does not show film screen is dark
Icant get full screen on computer when watching films
Hello, when you are watching films, have you tried to to use the 'alt-enter' shortcut or F11 to make the screen size go to full screen view?
without the application or steps you go through this will be a pretty generic response. If you add more details I can try and figure out why you may be getting that error.
Knowledge is power
Jon Justiniano
Customer Service rep with:
Web Hosting Dedicated Server Hosting Domains AIT com
Oct 13, 2014 | Computers & Internet
Tv full screen picture
thats called letterbox mode it all depends on how the movie or show was filmed years ago it was called cinemascope you can change it manually via your tv remote
May 04, 2014 | Televison & Video
How do I play downloaded movies from Samsung M3 Portable hard drive to tv
Most TVs will play AVI movies from USB connected drives except Sony TVs. Sony has prevented downloaded movies playing on their TVs.
Jan 27, 2013 | Computers & Internet
How to insert video in the PowerPoint 2003?
Insert a movie and play it automatically
In PowerPoint 2003, you can run your movies full screen. This is a very excellent feature.
  • On the Insert menu, point to Movies and Sounds, and then click Movie from File.
  • Click the video you want to use and then click OK.
  • Tips: Always put the movie in the same folder as your PowerPoint presentation. If you later move the PowerPoint presentation to another computer, copy the movie too. Keeping your movie in the same folder as your presentation ensures the link will still work. However, you should always test the movie on a new machine just to be certain. Re-insert the movie, if necessary.
  • After you click OK, you' are promoted with a message asking how you want the movie to start in the slide show.
    I recommend choosing Automatically even if you want the movie to play when clicked- I will talk about how to set this part too. (If you choose when clicked you have to click the black box to start the movie. Because I don't like to show the black box on the slide, I do this a little differently.)
  • You should now have a small rectangle sitting on your slide.
  • Insert a movie using a file on your computer or in another location, such as a server.
  • The movie appears as a still frame on your slide.
  • The trick I use is to move that rectangle off the slide, so it is sitting next to it, but not on it. You can size it down if you like. Click the movie (that is, the rectangle) and then drag it off the slide.
    Play the movie full screen
  • Right-click the movie object (the small rectangle) and on the shortcut menu, click Edit Movie Object.
  • The Movie Options dialog box appears. Under Display Options, select the Zoom to full screen check box, and then click OK.
  • If you want your movie to play automatically when you advance to this slide, you can stop here.
Test this now to see how it workd by starting the slide show. (On the Slide Show menu, click View Show.) Advance to the slide with the movie, (best if you have the title of the movie on it). Within a couple of seconds, the movie starts to play full screen. When the movie finishes, you return to the same slide (but no unsightly box appears). Click to advance to your next slide.
Add an On Click effect to start the movie
If you prefer, you can click to start the movie. This requires one more step, setting an On Click animation effect.
1. On the Slide Show menu, click Custom Animation. The Custom Animation task pane appears on the right side of the PowerPoint window.
2. Click the movie object (the rectangle) to select it.
3. In the Custom Animation task pane, click Add Effect, point to Entrance and then click Appear.
You have added an On Click effect. The animation effect you added is the one with the Green star next to it and a gray rectangle around it. If it doesn't have a gray rectangle, click it to select it. Your Custom Animation task pane should look like the picture below (except with the name of your movie in the list).
4. The last step is to move that animation up to the top of the effects list.
To do this, make sure the animation effect is selected, and then click the Up Re-order arrow at the bottom of the Custom Animation task pane. Or simply click and drag the animation effect to the top of the effects list.
5. Your effects list should now look like this:
6. You are done. Test this to make sure it works by starting the slide show.
(On the Slide Show menu, click View Show.) When you advance to the slide with the movie, you should not see the movie. When you click the slide, the movie zooms to full screen and plays. When it finishes playing, you are returned to the same slide. Click to advance to the next slide.
Souce: How to insert a Movie (or video) into PowerPoint 2003?
Jul 06, 2010 | Microsoft Office Professional 2007 Full...
The screen went dark on jmv 111
Dark as in gone or dark as in the image is still viewable?  How does the onscreen menu look when the image is dark/gone?  If the onscreen menu looks right and the image is still dark, you might want to check the cables or another input.  If another device using different cables and another input looks fine, you may only have a problem with the input/cable you are using to view the movie.  If the onscreen menu is also dark, then I would think there is an internal problem that needs looking into.
Mar 23, 2009 | Jensen Car Audio & Video
Not all scenes in full screen
Hey!
The full screen shots are the actions scenes that were filmed in IMAX... there's nothing wrong with your player or disc!
Dec 29, 2008 | Sony BDP-S350 Blu-Ray Player
How to video on my camera
twist the options wheel around to select the little icon that looks like a movie camera (directly across from the green camera). When you want to start filming, just click the shutter button (the one u press when ur taking pictures). The time recording will pop up on the display screen and it will show you how long you've been recording. To discontinue filming just hit the shutter button again.
Dec 20, 2008 | Samsung Digimax 4010 Digital Camera
Attention Fixya site I have a Canon Camcorder 750i Unit does not display in record mode either with screen closed for eye piece vision or screen vision fully open. This applies to either when...
Symptoms in your Canon camera shows problem with CCD Image Sensor. Canon website has advisory for this issue. Please click above link and see it. I couldn't find your model for Free of Cost repair list but you can ask Canon about your camera. Hope this info will help you.
Aug 17, 2008 | Cameras
Movie Files will not display on the TV.
Its quite possible your laptop has lost its association with your TV as a "secondy monitor".
To check this, minimise everything and right click on the desktop and go to Properties. Then navigate to the settings tab. This will show you how many displays it considers itself to have.
Click on number 2 (if visable) and click on extend my windows desktop to this monitor.
You should now be able to go between screens
Apr 22, 2008 | Toshiba Satellite A105 Notebook
How to stop light flickering in movies
Trying to film a movie in a darkened theatre is not what camcorders were intended to do, and sounds both illegal and unethical. Perhaps you should provide more explanation of what you are doing.
Sep 06, 2005 | Panasonic AG-185 Camcorder
Memorex MVD2016 DVD Player Logo
Top Memorex Televison & Video Experts
 Grubhead
Grubhead
Radames Pagan
Radames Pagan
Are you a Memorex Televison and Video Expert? Answer questions, earn points and help others
