Question about Brother MFC 420CN All-In-One InkJet Printer
Hp j480 ink cartridge does not print black - Brother MFC 420CN All-In-One InkJet Printer
SOURCE: black ink not printing
Fix ink cartridge
I had same problem. I must have ran the clean cycle more than 30-50 times over a period of days. That never made any difference. I was about to toss the whole thing but figured I would try one more thing. If it didn't work I would be in no worse shape. Here is what I did.
Took an almost empty black cartridge and inject a lot of 100% Acetone to dilute ink. Left some black in it since I didn't want to think it was empty. Inserted this cartridge and ran the cleaning a few time. IT WORKED. I used my word processor program and filled a page with large bold font characters and printed a page or two. Each page cleared more nozzles. After doing this cleaning/printing a number of time, I put in the full good cartridge. Ran the cleaning a few time to eject any of the Acetone diluted ink. Ran the printed page a few time to remove more of the diluted ink.
Everything seems to work now.
Posted on Dec 20, 2008
  • 116 Answers
SOURCE: Black ink not printing
replace print head assembly
Posted on Aug 02, 2009
  • 7 Answers
SOURCE: printer won't print black ink
From multiple online sources, this appears to be a fairly common problem with this model. As a matter of fact, my 490CW is experiencing the same exact issue. Called tech support and they're issuing an exchange. I'd advise that you do the same.
Posted on Oct 12, 2009
alphacheese
  • 68 Answers
SOURCE: BROTHER MFC-210 PRINTING IN BLACK INK POOR QUALITY
Try cleaning the black printer heads several times in a row, at least 5 times then print a black document with best quality setting.
Press the ink button, then down to select select cleaning and then press menu/set and menu/set again to select black.
Posted on Jan 08, 2010
Sebin
  • 712 Answers
SOURCE: black ink will not print. Colours ok
Get a syringe, remove the needle, remove the ink cartridge and use the syringe to blow air GENTLY through the hole the cartridge connects to. Make sure you have a cleaning cloth to remove ink dislodged from pipe connected at the print head, do this gently to remove any obstruction and there should not be too much mess and can easily be cleaned up.
Posted on Feb 04, 2010
Hp 4480 how do you unpause it
The HP F4480 likely has a malfunctioning ink cartridge which is causing the printer hang (i.e. internal micro-electronics damage inside the HP 60 color or black ink cartridge). You can verify the electrical condition of both HP 60 ink cartridges by activating the Tap 41 diagnostic test report (see video here for complete instructions):
http://inkjet411.com/?page_id=440 (HP 60 - Deskjet F2400/F4400/F4500 models)
    1.While holding the Power button, press Cancel (X) button 4 times, then press the Color Copy button once.
    2.Release the Power button.
    3.The 'Tap 41' diagnostic test print should print.
    Providing the color cartridge is partially functioning the Tap 41 diagnostic test print will be printed (this is a forced service print test which is mainly used for the evaluation of ink cartridge electrical health). A good HP 60/60XL color cartridge should display 1248 good nozzles, while a good HP 60/60XL black ink cartridge should show 336 good nozzles. If the results yield anything different then the ink cartridge is likely damaged and will need to be replaced. Refer to 2nd video on how to read the printout.
    http://inkjet411.com/?page_id=444 (HP 60 - Deskjet F4200 model)
    If the printer attempts to print the diagnostic test pattern (1 page) then the printer is generally considered operational and functional, if nothing is printed, but the printer attempts to print the pattern, then the tri-color ink cartridge is either empty, clogged or severely electrically damaged (black ink cartridge is not used). You can remove the tri-color cartridge, reactivate the tap 41 test and the printer will print the diagnostic test print in black ink.
    For additional support please visit http://www.inkjet411.com
    -Thank you
Dec 09, 2013 | HP F4480 All-In-One Printer
Can I print on my hp 6122 deskjet with only a black ink cartridge? I have no color ink.
Yes, all HP Deskjet printer models feature a 'single cartridge print mode'. Just remove the cartridge you don't wish to print with; the printer will automatically revert into either greyscale printing (if color cartridge remains installed) or black only printing (if the black cartridge remains installed). However, if the installed ink cartridge is electrically damaged/defective the printer will display an alert message; it will need to be replaced with a new cartridge.
For more information on the use of refilled ink cartridges or advanced HP printer problem diagnosis please visit Inkjet411:
Sep 03, 2013 | HP Office Equipment & Supplies
Have hp d1430 printer, I only use the color print cartridge, the printer will print color but will no print normal black lettering, have tried two different hP22 cartridges. Is the printer done for?
YOU SHOULD USE HP 21 BLACK INK CARTRIDGE FOR BLACK PRINTING.IF YOU USE 22 COLOUR CARTRIDGE YOU WILL GET ONLY GREAY PRINTING ONLY.I AM RIGHT?IF YOU USE COLOUR CARTRIDGES MAY YOU WILL GET MONEY LOSE. BECOS IT WILL FINISH EARLY.BLACK INK COST IS LESSTHAN COLOUR INK CARTRIDGES. SO YOU SHOULD BUY BLACK CARTRIDGE FOR REAL BLACK PRINTING.
Jun 29, 2011 | HP Deskjet D1430 InkJet Printer
Photo black ink runs out b4 black on HP Photosmart C6380 printer
The black ink cartridge is larger than the photo black cartridge and black is used in photos to make the darker colors. Black text takes much less ink per page.
Jul 17, 2010 | HP Photosmart C6380 All-In-One InkJet...
I have an hp officejet 7110 all-in-one and I've been getting a message saying that supply expired on the black cartridge. i replace it and it still won't let me print. what else could be wrong
Hello there:
This problem is usually due to a print head that needs to be replaced
I have provided the information that you will need ok
best regards mike
This document provides information on how to replace a printhead or ink cartridge.A printhead may need replacing when print quality issues cannot be resolved by cleaning the printheads or a front-panel display message indicates a printhead needs to be replaced.An ink cartridge needs replacing when a front-panel display message indicates either:
  • Low ink levels
  • Ink cartridge approaching expiration date
CAUTION: Never remove an ink cartridge and a printhead at the same time. Use the table below to identify the correct ink cartridge part number: Ink cartridge Part number HP 14 black print cartridge C5011A HP 14 tri-color print cartridge C5010A Use the table below to identify the correct printhead part number: Printhead Part number HP 14 black printhead C4920A HP 14 cyan printhead C4921A HP 14 magenta printhead C4922A HP 14 yellow printhead C4923A Replacing the ink cartridges Follow the instructions below to replace the ink cartridges:
  1. Turn on the unit, and open the print-carriage access door by lifting the handle until the door locks into place. Figure 1: Opening the access doorc00064456.jpg
  2. The print carriage will move to the center of the unit.After the print carriage stops, remove the ink cartridge by pressing the gray release button, then lifting the cartridge up and out of its slot. Figure 2: Removing the ink cartridgec00064457.jpg
  3. Remove the new ink cartridge from its packaging and, being careful to touch only the black plastic, remove the tape. Figure 3: Removing the tapec00064458.jpg
  4. With the ink cartridge label face-up, push the new ink cartridge firmly down into the appropriate slot until it clicks into place.The color ink cartridge inserts into the right-hand slot as indicated by the rainbow colored oval. Figure 4: Inserting the new cartridgec00064459.jpg
  5. Close the print carriage access door. CAUTION: If the ink cartridge is removed before a replacement is available, close the print carriage access door and replace the ink cartridge within 24 hours.
Identifying parts of the printheads Use the table below to identify the parts:
  1. Printhead handle
  2. Printhead tower
  3. Copper contacts
  4. Plastic tape
  5. Ink nozzles
c00064460.jpg Do not touch:
  • Copper contacts
  • Ink nozzles
  • Printhead tower
Jan 24, 2010 | HP OfficeJet 7110 All-In-One Thermal...
Hp c4480 prints blue instead of black
Check the print properties and verify the black ink cartridge still has ink in it.
Otherwise, you may have a bad ink cartridge. If the cartridge has not been used for a while, the ink gums up the nozzle. You can try cleaning the ink cartridge and slot with alcohol. However, new color and black cartridges may be the best solution.
May 02, 2009 | HP PhotoSmart C4480 All-in-One Printer ...
Ink cartridge
Black HP 92
Color HP 93
Photo HP 99
Jan 11, 2009 | HP Photosmart C3180 All-In-One InkJet...
How to change black color inkonHp2175all in one
Supported HP ink cartridge part numbers The HP PSC 2100, 2170, and 2200 all-in-one series products use the ink cartridges listed in the table below. The HP 58 tri-color photo ink cartridge replaces the black ink cartridge for six-ink photo printing. Ink cartridges Part number HP 56 black ink cartridge (19 ml) C6656A HP 57 tri-color ink cartridge (17 ml) C6657A HP 58 tri-color photo cartridge* (17 ml) C6658A HP 27 low capacity black ink cartridge (10 ml) C8727A HP 28 low capacity tri-color ink cartridge (8 ml) C8728A * Replaces the black ink cartridge for six ink photo printing and includes cartridge holder. Replacing the ink cartridges The power must be turned ON to the all-in-one or the print carriage will not come to the center.
  1. Locate and raise the print cartridge access door on the front of the unit, just above the output tray. The print cartridge carriage will move into the middle of the access area. Figure 1: Raising the front access door and the ink cartridge latches c00224418.jpg
  2. Press down lightly on the top of the ink cartridge latch of the ink cartridge to be replaced and then pull the lower section of the latch toward you to unlatch the ink cartridge.
  3. Grasping the sides of the ink cartridge, pull the cartridge toward you to remove it as shown in Figure 2. Figure 2: Removing the cartridge after raising the latch c00224419.jpg
  4. Remove the replacement cartridge from its packaging, and touching only the black plastic, gently remove any tape covering the nozzles. Do not touch the gold-colored contacts. Figure 3: Removing the protective tape c00224420.jpg
  5. Holding the ink cartridge with the printed label up, slide the cartridges one at a time into the print carriage as shown in Figure 4. The black ink cartridge (HP 56 or HP 27) goes on the right side (with the gray latch) and the tri-color cartridge (HP 57 or HP 28) goes on the left side (with the blue latch). If the optional photo cartridge (HP 58) is installed for six-ink photo printing, it is installed in place of the black ink cartridge. Figure 4: Inserting the cartridge c00224421.jpg
  6. Place your hand on the latch as shown in Figure 5, with the thumb pulling the end of the latch toward you. While holding the end of the latch out, press down on the top of the latch until it stops and then release the lower portion of the latch with your thumb so that it catches under the tabs. Do not force the latches into place or damage to the unit might occur. Close the all-in-one after latching the ink cartridges in place. Figure 5: Latching the ink cartridges in place c00224422.jpg
  7. Close the print cartridge access door.
  8. A message will appear in the front panel display requesting that the ink cartridges be aligned. Press ENTER on the front panel to start the cartridge alignment. Two pages will print. Following the instructions printed on the second page, place the first page on the scanner glass in the lower-right corner and then press ENTER to finish aligning the cartridges. Remove the page from the scanner glass when complete.
Storing the option photo printing cartridge while not in use The optional photo print cartridge (HP 58) that may be purchased separately for six-ink photo printing includes an ink cartridge protector. The protector is designed to keep the photo cartridge from drying out when it is not in use and for holding and protecting the black cartridge when the photo cartridge is in use.
  • To insert a cartridge into the protector, slide it into the protector at a slight angle until it snaps in place.
  • To remove a cartridge from the protector, push down and back on the top of the protector to release the cartridge and then slide the cartridge out of the protector.
Figure 6: Inserting and removing ink cartridges from the ink cartridge protector c00224423.jpg Fixing error messages that appear after changing a cartridge After inserting the cartridge, one of the following messages appears:
  • Check the black (or color) cartridge
  • Replace the black (or color) cartridge
  • The wrong black (or color) cartridge is installed
These messages indicate that the ink cartridge is not making good electrical contact, is bad, or is the wrong cartridge. Complete the following steps to diagnose and correct the condition:
  1. Open the front of the unit to access the print cartridges (as shown in Figure 1).
  2. Remove the ink cartridge indicated in the message and inspect it.
  3. Verify that it is the correct part number and if it is, reinsert it.
  4. Close the lid to see if the problem is corrected.
  5. If the message is still displayed after a few seconds, remove the ink cartridge again.
  6. Unplug the power cord from the back of the unit.
  7. Clean the electrical contacts on the ink cartridge with a soft clean cloth, slightly dampened (not wet) with clean water. Each contact is very small and shaped like a rounded square. Figure 7: Cleaning the cartridge contacts c00224424.jpg
  8. Inside the HP all-in-one product, clean the contacts in the print carriage (the cartridge holder) with a clean cotton swab slightly dampened with clean water. Allow them to dry for five minutes before reinserting the cartridge(s) and turning on the printer. Figure 8: Contacts to be cleaned c00224425.jpg
  9. If the problem remains, replace the ink cartridge.
  10. If the problem still exists after trying all of the steps above, contact HP for assistance.
Oct 13, 2008 | HP Office Equipment & Supplies
Printer
Follow these instructions when the ink level is low.
Note When the ink level for the print cartridge is low, a message appears on
your computer screen. You can also check the ink levels by using the software
installed with the HP All-in-One.
When you receive a low-ink warning message, make sure you have a replacement
print cartridge available. You should also replace the print cartridges when you see
faded text or if you experience print quality issues related to the print cartridges.
To order print cartridges for the HP All-in-One, go to www.hp.com/learn/suresupply. If
prompted, choose your country/region, follow the prompts to select your product, and
then click one of the shopping links on the page.
For a list of print cartridge numbers, see the back cover of this guide.
To replace the print cartridges
1. Make sure the HP All-in-One is on.
Caution If the HP All-in-One is off when you open the print cartridge door
to access the print cartridges, the HP All-in-One will not release the
cartridges for changing. You might damage the HP All-in-One if the print
cartridges are not docked safely on the right side when you try to remove
them.
2. Open the print cartridge door.
The print carriage moves to the center of the HP All-in-One.
3. Wait until the print carriage is idle and silent, and then lightly press down on a
print cartridge to release it.
If you are replacing the tri-color print cartridge, remove the print cartridge from the
slot on the left.
If you are replacing the black or photo print cartridge, remove the print cartridge
from the slot on the right.
Chapter 8
28 HP Deskjet F300 All-in-One series
Maintain the HP All-in-One
1 Print cartridge slot for the tri-color print cartridge
2 Print cartridge slot for the black and photo print cartridges
4. Pull the print cartridge toward you out of its slot.
5. If you are removing the black print cartridge in order to install the photo print
cartridge, store the black print cartridge in the print cartridge protector or an
airtight plastic container.
If you are removing the print cartridge because it is low or out of ink, recycle the
print cartridge. The HP Inkjet Supplies Recycling Program is available in many
countries/regions, and lets you recycle used print cartridges free of charge. For
more information, go to the following website:
www.hp.com/hpinfo/globalcitizenship/environment/recycle/inkjet.html
6. Remove the new print cartridge from its packaging and, being careful to touch
only the black plastic, gently remove the plastic tape by using the pink pull tab.
1 Copper-colored contacts
2 Plastic tape with pink pull tab (must be removed before installing)
3 Ink nozzles under tape
Caution Do not touch the copper-colored contacts or ink nozzles.
Touching these parts can result in clogs, ink failure, and bad electrical
connections.
User Guide 29
7. Slide the new print cartridge forward into the empty slot. Then gently push on the
upper part of the print cartridge forward until it clicks into the socket.
If you are installing the tri-color print cartridge, slide it into the left slot.
If you are installing a black or photo print cartridge, slide it into the right slot.
8. Close the print cartridge door.
9. If the print cartridge alignment sheet prints, load it on the left front corner of the
glass with the top of the page to the left.
10. Press the Scan button.
The HP All-in-One aligns the print cartridges. Recycle or discard the print
cartridge alignment sheet.
Oct 29, 2007 | HP DeskJet F380 All-In-One Printer
Problem printing with HP Business inkjet 1200
I have a HP Business Inkjet 1220 Printer, and the block ink cartridge light is flashing. I replaced the cartridge with a brand new one, closed the door, and black ink light is still flashing. I put in another neew black ink cartridge, closed the door, and same issue- black cartidge ink light flashing. I cannot print- what to do?
Oct 28, 2007 | HP Business Inkjet 1200dtn Printer
Brother MFC 420CN All-In-One InkJet Printer Logo
29 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
