Question about Dual XD-7500 CD Player
Wont come on at all all wires hooked up - Dual XD-7500 CD Player
84 dodge wont charge battery
hook a test lit at the alt big wire this wire must be hot all times and most of the times is protected with a fusible link prone to burn when hooked backward
Dec 22, 2013 | Dodge Cars & Trucks
I am tring to put a cd player on my 2004 pontiac but it wont work the sterio wont turn on so i ran a wire from the fuse box on the side of the dore and it turn on but it has no sound wat am i doung wrong
hook up all your wires to the harness and the cd player EXCEPT the ground take and run both wires to the firewall or something metal instead of hooking them up together
Aug 30, 2011 | 2004 Pontiac Grand Am
I wont the speakers hooked to the cd player no the amp
check were the speakers are installed for pre existing wiring they probly left it there.. if not then you will have to run speaker wire from your stereo wiring harness to your speakers. if the speakers were hooked up to the amp then the wire in the harness should be vacant and you can use it if all the wires are connected then that means that you just have to find were that wire leads and hook your speakers up to it.
Jun 03, 2010 | Pioneer DEH-P6400 CD Player
My boyfriend hooked up my speakers in my car to my cdx-gt200, now my cd player wont even come on. He never touched any of the connection wires for the player. At first he could not find the remote turn on...
change the fuse behind the system.
"so he hooked it up to the left front speaker wire, then found the remote turn on wire and hooked it up to it." will have burned the sound system or not. remove the new installation, test it, reinstall, test again.
Jun 01, 2010 | Sony XPLOD CDX-GT200 CD Player
I have a 99 grand am and have the starter hooked up but car wont
you have the switch wire on the wrong cylanoid post switch the little wire and try agin
Jul 06, 2009 | 1999 Pontiac Grand Am GT
Sub jacks play but door speakers wont play when hooked up to proper wires why
your car has a stock amp for the speakers hook up the blue wire that is on the stock lead wire harness to the remote wire along with the remote for the amp
Jun 29, 2009 | Audiovox VM9311TS
Clarion 3475 speakers wired, player wont turn on
The RED from the clarion wire must be hooked up to a switched power source ... that was wired to your old radio, then press the reset switch, and it should then turn on.
May 05, 2009 | Clarion DRB2475
Fan on alternator wont spin
I think you should check your connections on the back of the altenator, something is wired incorrectly, if necessary hook up one wire at a time and see what you get. There should be only one large red wire on the BATT connection, and the rest should be in a molded clip that plugs into the altenator, check and ensure that they have a good connection when you hook them up.
Mar 20, 2009 | 1992 Oldsmobile 88
Wont play
Try resetting the unit by pressing the small, recessed button on the faceplate with the tip of a pen. If this doesn't work, the player may be defective. There is no wiring error (including failure to hook up the parking brake input) that will prevent the unit from playing CDs.
Mar 09, 2007 | JVC KD-AVX1 Car DVD Player
Dual XD-7500 CD Player Logo
18 people viewed this question
Top Dual Car Audio & Video Experts
xxxxxx xxx
Jeffrey Turcotte
Jeffrey Turcotte
Are you a Dual Car Audio and Video Expert? Answer questions, earn points and help others
