Question about Premium HP PhotoSmart 5512 Ink Cartridge Black PhotoSmart 5512 - 6800 Page
Canon iIXMA 4600 will not print black
Rplaced all ink cartridges all are functional except the two black. Did routine maintenance as suggessted no change
Canon printer is printing with smudged text, how do I resolve it?
Most Canon printers have a clean print heads function. Search the menus until you find it. This is maintenance you should perform on your printer routinely. Once you do that and it still is smudged, remove the ink cartridges and clean the end of them carefully (you don't want ink to go everywhere). Look where the cartridge(s) connect to the print head. They may be dirty as well and need to be cleaned. Go to the following website and they go into specifics on how to clean your printer:
How to Clean Clogged Printer Heads
Nov 15, 2017 | Canon Office Equipment & Supplies
Lexmark 300S is not printing black and all my ink is full. Whats the prob
Inkjet printers need to be used frequently to prevent ink drying out and blocking the print head nozzles.
If the print head cleaning maintenance routine does not clear the blockages, then print head needs replacing, but it may be expensive.
It may be more cost effective to buy a later model and better printer than replace the print head. This model Canon/Epson printer may only let you use genuine Canon/Epson printer cartridges. If you try to refill these ink cartridges it will not work because the Canon/Epson cartridges have an embedded chip in the cartridge that detects the empty cartridge even though it has been refilled.
Apr 09, 2013 | Office Equipment & Supplies
Cannon Pixma MP780 won't print. Just replaced black ink cartridge, do I have to replace all of them for it to print
Not normally but the black print head nozzles maybe blocked.
Mar 08, 2013 | Canon PIXMA MP780 All-In-One InkJet...
Canon mx860 printer not using ink from PGBK 220
Mar 07, 2013 | Canon PIXMA MX860 All-In-One InkJet...
Cannon mx860 fails to print in black ink. loaded new cartridge, still doesn't print in black. will print in color..
With the Canon MX860 you can removed the print head assembly quite easily and clean it with water. I have posted a youtube video for your reference.
Mar 06, 2013 | Canon PIXMA MX860 OFFICE AIO-2.5IN LCD...
The black ink keeps drying up and will not print out black print
INK PROBLEM
Jan 03, 2013 | Canon Cli526 Black Cyan Magenta Yellow 3x...
Black not printing
Canon Bubble Jet i560 Ink Jet Printer not printing black
Aug 01, 2010 | Canon BubbleJet i560 InkJet Printer
I tried to use a generic brand ink cartridge in my Canon MP520, which I couldn't get to work. I then gave up on it and installed a genuine canon cartridge, and while the printers says that the ink is full...
you do not say if your printer has it's own print heads or if they are on the cartridge.. if your printer has the print heads then the generic cartridge has probably blocked the heads nosils (cheap ink is NOT the same as the real thing and is usually sub-standard) use your maintenance section on either the printer or it's software on the computer and run head cleaning routine several times and do the occasional test print to see if it improves... hopefully you have not damaged the print head
Oct 14, 2008 | Canon Office Equipment & Supplies
Premium HP PhotoSmart 5512 Ink Cartridge Black PhotoSmart 5512 - 6800 Page Logo
69 people viewed this question
Top Premium Photography Experts
pontelemon
pontelemon
TC CAMERA REPAIR.Com...
Are you a Premium Photography Expert? Answer questions, earn points and help others
