Question about Bosch Washing Machines
Washing machine will not engage drum in wash or spin mode
I have a Bosch 800 MAX WFL1660AU washing machine about a month a go it was washing and did not finish the cycle with the spin mode. I have removed the lid to check and can see no wires loose I have removed the back and floor and accessed the motor and see no wires loose. I then reassemble and the machine worked for around 3 -4 cycles. Then the same problem persisted. Again i opened up the machine and gave it a clean with the vacuum thinking there may have been dust or something blocking some sort of connection. The machine when reassembled again worked for 1-2 cycles. I have since removed the motor and replaced the Carbon brushes on re assembly the machine engaged the motor for the first sort of spin ( (about 10 secs) and then stopped. I have just taken it apart again and the same occurred around 10 secs worth of spin then nothing !!!!!! frustrating. It seems all of the mechanics are ok and since it has washed full cycle a few time , it seems the electrics are ok??? Any idea on what i could trouble shoot now? I don't have the money at the money to engage a expensive mechanic.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 38 Answers
It sounded like the brushes have gone but you said you replaced them right? usually when the drum stops spinning its because the brushes have completely worn down and there is nothing left are you sure you snapped them into place properly or brought the correct model numbered ones? then are very difficult to get into the correct place I had a very similar problem and it took four attemps to get them in thr right place they are not the most easiest of things to do. if you have then it might be the motherboard electrical component if this is the case you will need a new machine im afraid if you dont have that much disposable funds try the freecycle website the offer free stuff look for you nearest area and take a look
Posted on Apr 15, 2014
Testimonial: "Ha thanks for your feedback i took the brushes out and then re fitted it spunn a little then stopped 1 of the brushed was a little hard to fit or rather a little tight i sandit down a fraction and made smooth re fitted both just to be sure she is now working fine very happy after persistence hope this helps others"
duby1990
  • 370 Answers
SOURCE: Washing machine won't spin
Sounds like you a broken coupler. This is what makes the washer spin. You can check this by leaning the machine back and feeling for a rubber coupler between the motor and transmission. if this part wiggles or is missing replace it, its broke. Another sign of it being broke is rubber under the machine when you tilt it back.
Posted on Nov 20, 2008
Contronics
  • 20 Answers
SOURCE: Maytag Atlantis 7700 - Noisy agitation/wash cycle from motor
Your drive motor may be fine. Check the water pump that is located in the back behind the small metal door on the left bottom corner and see if thats where your noise/water is coming from. These extraction pumps have bearings casing that gets mangled and locked up. Look right above the flywheel that the belt rides on in the W-pump.
Posted on Jun 03, 2009
  • 2509 Answers
SOURCE: Bosch washing machine model WFF1401GB/01, 10 years
Check the motor control board for dry joints, poor contact, signs of excessive heat around plugs/pins
I would try new brushes again or thoroughly inspect whether they are contacting the commutator.
I hope I have been of help but please do not hesitate to ask if you have any further questions.
I appreciate your vote if you appreciate my reply.
Posted on Mar 01, 2011
  • 6277 Answers
SOURCE: Have a Bosch washing
This sounds very much like the motor IS failing. Following are my pre-typed general guidance notes and include a comment about changing brushes- sorry!
Motors- and belts, which is sensible to change at the same time- are easy to be changed by a competent person:-
REMOVE POWER FROM THE MACHINE AND REMOVE THE BACK.
The motor support bolts, normally 2, should be loosened and the belt removed then remove the bolts completely
With the motor it is false economy to just have the brushes changed. Experience of others is that the brushes may only last months unless, that is, the motor is totally refurbished. Refurbishing includes skimming the commutator on which the brushes run. Without skimming the brushes do not sit firmly on the commutator but straddle it- the centre is often more worn than the outer part.
Unfortunately motors are not cheap- the motor for our 18+ yearold Bosch cost GBP250 but it will probably outlive us!
Often putting the new belt on is a bit of a struggle, even with the motor 'loose', because it is new and smaller!
Once on it should be tensioned by pulling the motor against the belt firmly- but not over tight- and the motor support bolts tightened.
ON NO ACCOUNT SHOULD ANY FORM OF LEVERAGE BE USED TO TENSION THE BELT. THAT COULD LEAD TO DAMAGE TO THE BELT, MOTOR AND BEARINGS- EXPENSIVE!
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck,
John C
Posted on Jun 14, 2011
Testimonial: "Think I will get a new machine as motor is expensive . Thanks for advise"
  • 15 Answers
SOURCE: Washer agitates, drains OK, but spin doesn't start
LID SWITCH
If you need further help, I’m available over the phone at https://www.6ya.com/expert/elite_9cbd96cb0728162b
Posted on Jan 18, 2013
I have a Bosch Nexxt 700 Series Washing Machine. We have been emptying our washer by shop vac for a couple months now. Nothing in the pump. Once through the wash cycle it will try to drain and then flash...
Is the pump pumping? Have you cleaned all the drain lines including the discharge hose? You may have nothing in the pump but it could be blocked somewhere else.
Apr 24, 2014 | Bosch Nexxt 700 Series WFMC6401UC Front...
Bosch classixx 1400 express
have you cleared the filter
Feb 03, 2014 | Washing Machines
Bosch WFL1660AU drum not spinning.
hello check the pump first it has to pump water out first before it spins if the pump is ok then the module control board could be the cause this controls the motor speed if this ok the brushes on the motor can also cause spins problems hope it helps
regards
shaun
Mar 26, 2011 | Washing Machines
Bosch washing machine spins but not dry enough when spun as if it is on 800 not 1400
This seems to be a common problem for Bosch WF02862. If the end result is not dry enough for you, you can try running an extra spin cycle. You can also try checking the machine if you can tweak its spin speed. Modern washers such as this model tend to have different spin levels.
Source: http://www.washingmachineadvisor.com
Mar 25, 2011 | Bosch WFO2862 Front Load
My bosch front loading washer on the small cycles will not spin the water out of the clothes..why?
Does it sound like the machine is spinning as fast as on longer cycles?Some machines run a slower spin speed on small cycles which can leave clothes wetter than normal. I've got this on mine and all I do is when the wash has finished I change over to the fast spin only program which then takes it to it's highest spin speed.
Jan 25, 2010 | Bosch Washing Machines
I cannot choose max spin. When I hit the spin
some lower cycles wont allow high speed spin, try heavy duty.
Nov 24, 2009 | Bosch Axxis WFL 2060 Front Load Washer
Bosch Nexxt 700 spin problems
yes it could be normal if the balance control senses that the load is uneven however the same problem could be caused by a blocked filter or blocked sump hose.
Dec 30, 2007 | Bosch Nexxt Premium WFMC6400UC Front Load...
Bosch max wfl2000 washing machine
Just been through this with our Bosch Maxx, problem was the pump discharge pipe was blocked with soap deposits. I also removed the large black rubber pipe from the drum/pump and cleaned this out as well.
All working fine now.
SteveN
Sep 08, 2007 | Washing Machines
Long wash times
I've had this problem, particularly with towels - it's quite annoying & not energy or water efficient at all. According to the manual, the unit has a sensor that senses if there is too much soap & it will continue to wash until the soap is removed. I found that this happened frequently on the "cotton" cycles & max spin. I've tried to make sure I use less soap, but I also use the perm-a-press cycle & the spin 1 down from max. Hope this helps
Sep 07, 2007 | Bosch WFMC 3200 Front Load Washer
Washing Machines Logo
131 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Craig Butler
Craig Butler
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
