Question about Quantaray 7-Inch Digital Picture Frame - View your photos right from your memory car...
Quantaray 10.4" won't turn on
Received as part of Father's Day gift with camera, will not start or respond to remote. Red light on side is lit, but no response to anything, won't display or load photos. Is this just junk, or should it actually display photos ?
What is the best gifts for fathers day ?
I have ever custom my father's handsome photo in diy oil painting by numeber and he was very happy after receive this unique portrait on father day . You can have a try.
I think it means a lot as this one diy oil painting by numbers,not a finished painting. You need to finish it yourself and your father can feel you heart.
best-gifts-fathers-day-ouopwxbl3mydoi0t2bdx2nje-5-0.jpg Have a look:
http://alturl.com/b6hzj
May 26, 2016 | Event Planning & Celebration
Haier HLH406BB 40 in. LCD HDTV - tv will not turn on. is not responding to either panel or remote power buttons. red off input light is still lit.
hi sounds like a power supply fault could be capacitors, look for tech in your area good luck
regards
shaun
Jan 15, 2014 | Televison & Video
My samsung LED TV turns on sometines and other times the red light stays on and won't respond to remote control
leave the tv disconnected for a while because if you keep messing with it like my kids did and it will cause the bulb inside to burn out and will not even be worth fixing
Dec 13, 2011 | Televison & Video
Will not respond to remote
is the remote your using is the original one....well try to check the battery and it's terminal sometimes it needed to be clean...check the infra red LED of the remote using a cellphone camera...focus the lens on the LED of the remote..press once any key if the light responds once its good but if you see blinking of lights your infra red LED needs to be replaced....but if your remote is good but still no respond on your tv..the tv problem may be from the remote receiver...try for a technical assistance for repair..nice day..
Feb 13, 2011 | Sharp LC-C4655U 46 in. LCD TV
I bought this jumbo universal remote control from a spencers gifts store and i lost the manual of how to program the remote to my tv. its been sitting around and its a waste of room. can someone plz help...
hold "SET" untill the red light stays on (the light doesnt turn on at all by just touching it) once the red light stays on, press tv or whatever device you want to program, then put in the code. It took me all day to figure it out.
Mar 07, 2010 | Televison & Video
Mx 3000 universal lcd remote
There are 4 reasons why your unit is behaving this way:
1. Charger is the problem.
2. The docking station is the broken.
3. The battery is broken or not accepting charge.
4. The actual unit is the problem.
It is very hard to tell which one is causing this to happen.
Let us do some troubleshooting first:
1. Plug your charger in an A/C outlet and make sure the red power light (left) is lit, otherwise the charger or the docking station is broken.
2. You can test the charger with a multimeter. Unplug the charger from the docking station and measure the voltage across the outside and inside, it should register more than 5 volts DC. If there is a 5Volt DC the docking station is the problem otherwise the charger is broken.
3. If the red power light is lit and the status light (right) is lit too, your docking station is broken.
4. If the red power light is lit, dock the unit into the charger, the status light (left) should turn red when your battery is accepting charge or turn blue when your battery is fully charged.
5. If the status light will not lit at all (while the red power light is on), tap the screen while the unit is docked on the charger. If the unit will become alive, you need a new battery otherwise you need a new unit.
12 hours is very long time to charge, the status light should turn to blue in less than 2 hours especially for a new battery.
Aug 29, 2008 | Universal Remote Control MX-3000 LCD...
Quantaray 7-Inch Digital Picture Frame  - View your photos right from your memory car...  Logo
42 people viewed this question
Top Quantaray Photography Experts
JP Services
JP Services
jd83854
R.A. Ellis
R.A. Ellis
Are you a Quantaray Photography Expert? Answer questions, earn points and help others
